Iomega 160GB Portable USB Hard Drive
3.5
based on 8 reviews
from
Ratings Distribution
5 star
3
4 star
2
3 star
0
2 star
2
1 star
1
Category Average
4.1
More Images
Pros
  • Reliable (5)
  • Fast connectivity (4)
  • Quiet (4)
  • Easy setup (3)
  • Easy to use (3)
  • Portable (3)
  • Durable (2)
  • Fast (2)
  • Large capacity / good size (2)
  • Versatile (2)
See less See more
Cons
  • Freezes easily (1)
  • Haven't encountered any (1)
  • I wish it had rubber feet (1)
  • Unreliable (1)
Best Uses
  • Back-up (4)
  • Laptops (3)
  • Travel (3)
  • Additional storage (2)
  • File transfer (2)
  • Music (2)
  • Video (2)
  • Large projects (1)
  • Multimedia (1)
Provided by RitzCamera.com
This ultra compact USB-powered Portable Hard Drive requires no external power supply - just plug it in and go. It is a high capacity travel companion that lets you take your important files, photos and music anywhere - a perfect storage solution for the mobile professional.
Main Features
  • Manufacturer: Iomega Corporation
  • Manufacturer Part Number: 33600
  • Manufacturer Website Address: www.iomega.com
  • Storage Capacity: 160GB
  • Rotational Speed: 5400 rpm
  • Data Transfer Rate: 480Mbps External Maximum USB 2.0
  • Interfaces/Ports: 4-pin USB 2.0 USB
  • Form Factor: External Hot-swappable Portable
  • Dimensions: 0.50" Height x 2.93" Width x 5.075" Length
  • Weight: 0.38 lb
  • Standard Warranty: 1 Year(s) Limited
  • Specification Description
    Model 33600
    UPC 742709336003
    Buffer 8MB
    Data Transfer Rate 480Mbps External Maximum USB 2.0
    Interface 4-pin USB 2.0 USB
    Rotational Speed 5400 rpm
    Select Pocket Hard Drives
    Select Capacity 160 GB
    Storage Capacity 160GB
    Iomega 160GB Portable USB Hard Drive Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: 160GB Portable USB Hard Drive
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Oct 13, 2008
    Iomega 160GB Portable USB Hard Drive Reviews
    Displaying 1 - 5 of 8 Reviews
    Show
    Sort by
    Amazing
    5.0
      Pros
    • Easy To Setup
    • Easy to use
    • Fast
    • High Capacity
    • Portable
    • More »
      Cons
    • None
      Best Uses
    • Additional Storage
    • Backup
    • File Transfer
    • Music
    • Video
    "This drive is exactly as it is pictured. its small lightweight and compact. i bought mine a couple weeks ago and have had no problems with the way it works. i would have to recommend this to anyone who needs a little more space on their computer or to anyone who just needs an easier way to transport …"  Read Full Review »
    Was this External Computer Hard Drive review on the Iomega 160GB Portable USB Hard Drive helpful to you?
    Sep 9 2008
    MereWolf
    Hamilton, New York
    I am:
    • Power user
    Reviewed at:
    Great buy and great performance
    5.0
      Pros
    • Durable
    • Fast Connectivity
    • Quiet
    • Reliable
    • Versatile
      Cons
      Best Uses
    • Laptops
    • Travel
    "Since i'm a older studet, i need to get the most bang for my dollar and i did here. It's fast and definately easy to connect. i just wish it had some rubber or some thing on the bottom so that it would not be so easy to slide off of the table or desk.
    And it looks EXACTLY like the picture and the …"  Read Full Review »
    Jun 30 2008
    MAC
    Albq, New Mexico
    I am:
    • Student and music hound
    • Tech Savvy
    Reviewed at:
    disappointing software
    2.0
      Pros
    • Fast Connectivity
    • Quiet
    • Super small size
      Cons
    • Freezes Easily
      Best Uses
    • None
    "The RETROSPECT backup software was not very user friendly. I want to create progressive b/ups that are not compressed but did not get any cooperation from the software as it is. Also, the very first TOTAL backup froze at about 20% and would not disconnect or allow a shut down without holding down th …"  Read Full Review »
    Mar 26 2008
    Hotshot
    Central Illinois
    I am:
    • Tech Savvy
    Reviewed at:
    I'm happy
    4.0
      Pros
    • Fast Connectivity
    • Portable
    • Quiet
    • Reliable
      Cons
    • Haven't Encountered Any
      Best Uses
    • Backup
    • Laptops
    • Travel
    "This thing did everything I wanted it to do. For the most part, it was plug and play. It's certainly compact and downloaded my files, music and images quickly. I take it with me almost every day and I haven't had any problems with it. "
    Jun 26 2008
    Par Golfer
    Phoenix, AZ
    I am:
    • Tech Savvy
    Reviewed at:
    Not a good drive for Mac
    1.0
      Pros
    • Easy To Setup
    • Easy to use
      Cons
    • Unreliable
      Best Uses
    • None
    "I have had this drive for about 1.5 years and it worked fine until recently. It started disconnecting on it's own and wouldn't allow me to retrieve my data. I have most backed up elsewhere thank god but for what I don't I am now trying t struggle to retrieve. I would suggest purchasing something …"  Read Full Review »
    Oct 7 2008
    K Sparrow
    New Jersey
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
