Iogear 4-Port USB 2.0 MicroHub - GUH274
#48
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$9.99 - $24.99
from 16 stores
More Images
Pros
  • Easily expanded (1)
  • Easy setup (1)
  • Fast (1)
  • Reliable (1)
  • Small (1)
See less See more
Best Uses
  • Can be used anywhere (1)
Provided by Super Warehouse
IOGEAR's 4-port USB 2.0 hub provides 4 Hi-Speed USB 2.0 ports for your high-speed connectivity needs. This device is fully compliant to USB 2.0 specifications and provides a data transfer rate of up to 480 Mbps. The GUH274 is an updated- portable version of IOGEAR's first USB 2.0 hub- model GUH204; this updated version features a smaller form factor and new design. It supports Windows 98SE- 2000- ME- XP- and Mac OS X or later. The MicroHub 2.0 also supports USB 1.1 devices since it is backward compatible with USB 1.1 specifications. It is very easy to use- Plug-n-Play- hot swappable and portable.
  • Product Description: IOGEAR MicroHub GUH274- hub- 4 ports
  • Device Type: Hub
  • Form Factor: External
  • Dimensions (WxDxH): 9.5 in x 2.5 in x 6.5 in
  • Ports Qty: 4
  • Data Transfer Rate: 480 Mbps
  • Data Link Protocol: Hi-Speed USB
  • System Requirements: Apple MacOS 8.6 or later- Microsoft Windows 98 Second Edition / Windows ME- Microsoft Windows 2000 / XP- Apple MacOS X 10.2 or later
  • Manufacturer Warranty: 3 years warranty
Specification Description
Model GUH274
UPC 672792502965
#per pack 1
Accessory Indicator Yes
Benefits 4 USB 2.0 ports for easy expansionSupports a data transfer rate of up to 480Mbps40 times faster than USB 1.1 products
Body Material Plastic
Capacity UOM mAh
Compatible Platforms Windows, Mac
Compliant Standards USB 2.9, 1.1
Description Header Easy expansion.
Display Catalog Number 55007499
Features Plug-and-play and hot swappable for added convenienceBackward compatible with USB 1.1 specifications so you can use your older equipm
Humidity Range Operating 20-80
Included in the Box GUH274 Hi-Speed USB 2.0 hubWarranty registration cardPower adapter
Manufacturer Labor Warranty 3
Manufacturer Part Number GUH274
Manufacturer Parts Warranty 3
MAP Price 0.0
Max Operating Temperature 50 Fahrenheit
Min Operating Temperature 20 Fahrenheit
Model GUH274
Operating Temperature UOM ° C
Product Depth 1.5
Product Dimensions UOM inches
Product Height 0.5
Product Length 3.5
Product Type Hubs
Product Weight 1.6
Product Weight UOM ounces
Product Width 3.5
Required to function Windows®98SE, 2000, ME, XPFor MAC UsersMac 8.6 or greater. Requires OS X for USB 2.0 supportAvailable USB 2.0 p
Supported Languages English
Iogear 4-Port USB 2.0 MicroHub - GUH274 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 2, 2009
Iogear 4-Port USB 2.0 MicroHub - GUH274 Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
USB Microhub easily adds ports
5.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
"I ran out of USB ports and this device easily and quickly solved the problem "
Was this Networking Hub & Switch review on the Iogear 4-Port USB 2.0 MicroHub - GUH274 helpful to you?
Oct 2 2009
john
forest hills, new york
I am:
  • High bandwidth user
Reviewed at:
Price: $19.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
