Interfit Flat Panel Reversible Silver / Gold Reflector, 35" x 70" with Stand & Tilting Bracket
#63
4.4
based on 10 reviews
from $79.95
Ratings Distribution
5 star
6
4 star
3
3 star
0
2 star
1
1 star
0
Category Average
4.2
Low Price:
$79.95 at B&H Photo Video
 Trusted:
$79.95 at Adorama
Find it at Amazon
More Images
Pros
  • Durable (5)
  • Attach securely (3)
  • Long-lasting (3)
  • Good color value (2)
  • Powerful (2)
  • Flat (1)
  • Folds compactly (1)
  • Good price / value (1)
  • No twist-o-flex tricks (1)
See less See more
Cons
  • Flimsy (2)
  • A more work to erect (1)
Best Uses
  • Indoor (7)
  • General purpose (4)
  • Outdoors (4)
  • Low light (1)
  • Professional work (1)
Provided by B&H Photo Video
The Paterson Flat Panel Reflector Kit features a large 35 x 70 reversible Silver/Gold reflector ideal for full length portraits or fashion shots. The reflector is complete with stand and special tilting bracket which allows the reflector to be used in either vertical or horizontal mode.
Specification Description
Model INT269
Select Outfits
Interfit Flat Panel Reversible Silver / Gold Reflector, 35" x 70" with Stand & Tilting Bracket Questions
Questions and Answers
Where to Buy
$79.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$79.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Oct 25, 2009
Interfit Flat Panel Reversible Silver / Gold Reflector, 35" x 70" with Stand & Tilting Bracket Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
5.0
For the true professional
"I purchased one of the items a year and half ago and after so many stunning photographs, I am purchasing another one just to push my work to the next level. It works great...you will have some problems if it is windy for outdoors and may require an assitant. Inside it works great and can be used to reflect sunlight from the window to an area of the room that might be not well light and you don't want to use a f..." Read Full Review »
Apr 18, 2007 by Jerry Boles Photography
See more positive Interfit Flat Panel Reversible Silver / Gold Reflector, 35" x 70" with Stand & Tilting Bracket reviews
2.0
Stand is nice reflector seemed cheap
"I bought this product to use in my portrait studio. The stand and the reflector go together well. But when it arrived, the reflector fabric was rolled and the layers were all stuck together. In the process of unrolling the reflector little peices of the layers stuck to each other causing the reflective surfaces to be mildly scuffed or shredded. I'm unsure how much this reduces it's effectiveness. Also I find ..." Read Full Review »
Oct 15, 2008 by Margaret
See more negative Interfit Flat Panel Reversible Silver / Gold Reflector, 35" x 70" with Stand & Tilting Bracket reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Attach Securely
  • Durable
  • Good Color Value
  • Long-Lasting
  • Powerful
    Cons
  • None
    Best Uses
  • General Use
  • Indoors
  • Outdoors
  • Professional Work
"I purchased one of the items a year and half ago and after so many stunning photographs, I am purchasing another one just to push my work to the next level. It works great...you will have some problems if it is windy for outdoors and may require an assitant. Inside it works great and can be used to …"  Read Full Review »
Sweat
Sweat
  • Using Product
Was this Camera Light Accessory review on the Interfit Flat Panel Reversible Silver / Gold Reflector, 35" x 70" with Stand & Tilting Bracket helpful to you?
 Report Abuse  (5)  (0)  0 comments
Apr 18 2007
Atlanta, Georgia
Reviewed at:
Price: $79.95
Nearly my favorite, but better priced
4.0
    Pros
  • Flat
  • Folds compactly
  • Good Price
    Cons
    Best Uses
  • Indoors
"I've been a big Reflectasol fan for over twenty years--they fold more compactly than any of the twist-o-flex reflectors without presto-chango magic tricks, they stay perfectly flat, they last forever (I've got a couple that are twenty years old), the fabric is both dry-cleanable and interchangeable, …"  Read Full Review »
Oct 25 2009
RDKirk
Illinois
I am:
  • Pro Photographer
Reviewed at:
Price: $79.95
More specs
4.0
"For those of you hoping, as I did, that this kit would fit into your 34" tripod bag, here are some more specs:
Stand, collapsed: 33" (yay!)
Reflector, rolled: 35" (you knew that)
Stretcher poles (4): 43"
The fabric is lightweight and coated with a metallic vinyl, and looks like it will no …"  Read Full Review »
Oct 4 2009
Craig
San Jose, CA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $79.95
2.0
    Pros
  • Attach Securely
    Cons
  • Flimsy
    Best Uses
  • General Use
  • Indoors
"I bought this product to use in my portrait studio. The stand and the reflector go together well. But when it arrived, the reflector fabric was rolled and the layers were all stuck together. In the process of unrolling the reflector little peices of the layers stuck to each other causing the refle …"  Read Full Review »
Oct 15 2008
Margaret
Maryland
I am:
  • Photo Enthusiast
[1 of 1 customers found this review helpful]
Turn a two light sytem into three.
5.0
    Pros
  • Attach Securely
  • Durable
    Cons
  • None
    Best Uses
  • Indoors
  • Outdoors
"If you are using a two light system and sacrificing a hair light, this is the answer. This works great as a fill light. I can now shoot from both sides of my garage and speed up my sessions using studio lights with the flat panel at one end, and using the outdoor light at the other end with the fl …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 8 2009
Lukester
East Tawas, MI
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $79.95
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
