Inland Pro Notebook Cooling Pad with Built-In Fans
#255
3.7
based on 9 reviews
Ratings Distribution
5 star
2
4 star
5
3 star
0
2 star
1
1 star
1
Category Average
3.8
$14.49 at NothingButSoftware
Find it at Amazon
Find it at Ebay
$14.49
from 1 store
Pros
  • Lightweight (8)
  • Easy to configure (5)
  • Durable (4)
  • Versatile (2)
  • Cheap (1)
See less See more
Cons
  • Doesn't always start fan (1)
  • Flimsy (1)
  • Little nosiy but not bad (1)
  • Noisy (1)
Best Uses
  • Travel (2)
  • Back-up (1)
Provided by NothingButSoftware
Cool down your notebook with cooling pad and built-in fans!
Inland Pro Notebook Cooling Pad 3033 Notebook Cooler Pad features a dual fan cooling system that pulls heat away from your notebook preventing it from overheating and two sliding panels that open for use and can be closed to fit comfortable in your notebook bag!  The USB powered Cooler Pad powers the two built-in fans and stows neatly under your laptop/.
Slim and smart design of the cooling pad system with large, high-performance and extra quiet 2 Fans built-in which absolutely helps to dissipate the heat-air away from underneath the notebook computer for cooling down the overall temperature of your system.
  • Extremely heavy-duty construction of the cooling pad to afford any weight or pressure put-on.
  • No AC Adapter or Batteries Required
  • Power source supported easily by the plug-and-play USB connection as a self-power mode
  • Pulls heat away from your notebook PC to prevent overheating
  • Fits comfortably in any notebook bag - Convenient, reliable, and comfortable to carry
  • Dual Fan Cooling System
  • USB Powered
  • 2 Built-in Fans
  • No need for any installation
  • Compatible with any notebook computers up to 17", plus
  • Notebook Cooling Pad with Built-in Fans
  • USB Cable
  • Quick Installation Guide
  • Warranty Information
  • Air Flow:28CFM
  • Speed:1500rpm
  • Fan: 80x80x10mm(LxWxH)
  • Dimensions: 11.8x9.1x0.5 inches (LxWxH)
Inland Pro Notebook Cooling Pad with Built-In Fans Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 5, 2009
Inland Pro Notebook Cooling Pad with Built-In Fans Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Noisier than my old one.
2.0
    Pros
  • Cheap
    Cons
  • Noisy
    Best Uses
  • None
"I bought this because it was cheap and my old cooler already had one of the two fans die and the other was getting noisy. This unit was as noisy as the older unit right out of the box. I pried the cheap plastic covers apart to gain access to the fan motors. I yanked the noisy fan/rotor and lubed the …"  Read Full Review »
Was this Laptop Computer Accessory review on the Inland Pro Notebook Cooling Pad with Built-In Fans helpful to you?
Oct 8 2009
Stan
Round Rock, TX
I am:
  • Tech Savvy
Reviewed at:
Price: $14.49
Good Value for the money
4.0
    Pros
  • Easy To Configure
  • Lightweight
    Cons
    Best Uses
  • None
"I use on a tray, then put the laptop. Now I don't worry about overheating. It has a USB connection and runs from the battery of the comoputer. "
Nov 5 2009
SewNana
Columbia, MO
I am:
  • Tech Savvy
Reviewed at:
Price: $14.49
Reasonably priced insurance
4.0
    Pros
  • Durable
  • Easy To Configure
  • Lightweight
    Cons
    Best Uses
  • None
"Use with laptops and netbooks to maintain good working temperature for machines (even in summer conditions) and comfort when used on lap. Requires no external power (runs from USB). "
Oct 3 2009
Dee
Denver, CO
I am:
  • Tech Savvy
Reviewed at:
Price: $14.49
A good buy
4.0
    Pros
  • Lightweight
    Cons
  • None
    Best Uses
  • None
"Does what one expects ... keeps air moving so to avoid over-heating. Additional value is that you can feel certain that your clothing is not blocking the laptop's fan when holding in your lap. Well worth the cost. "
Sep 28 2009
bob with beachfront condo
Wilmington, NC
I am:
  • Tech Savvy
Reviewed at:
Price: $14.49
disappointed...
1.0
    Pros
  • Lightweight
    Cons
  • None
    Best Uses
  • Travel
"Although the product was new - it had two fans and only one worked when connected. "
Oct 26 2009
WManning
Erwin, Tennessee
I am:
  • Tech Savvy
Reviewed at:
Price: $14.49
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
