Init Tilting Wall Mount for Most 13" - 25" Flat-Panel TVs - Graphite
#57
4.9
based on 10 reviews
from $26.99
Ratings Distribution
5 star
8
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
$26.99 at Best Buy
Find it at Amazon
Find it at Ebay
Provided by Best Buy
The smooth tilting motion provided by this wall mount makes it easy for you to find the right viewing angles.
Init Tilting Wall Mount for Most 13" - 25" Flat-Panel TVs - Graphite Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 15, 2009
Init Tilting Wall Mount for Most 13" - 25" Flat-Panel TVs - Graphite Reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Does the job for a low price!
5.0
"Don't be fooled by the low price. This wall mount does the job, it also comes with a tilt. I used this for a 19" Insignia DVD Combo TV. It has worked great. The mount was easy to install. You drill two holes in a stud, insert the screws, level the mount with the level that is included, mount your tv …"  Read Full Review »
Was this TV Wall Mount review on the Init Tilting Wall Mount for Most 13" - 25" Flat-Panel TVs - Graphite helpful to you?
Apr 29 2008
Kobe24
Undisclosed
Reviewed at:
Price: $26.99
Ok wall mount for price
4.0
"I got this from bestbuy.com. Online it was on sale,cheaper than store.
I used to this to install 20" LCD tv at my kitchen. I could not find any stud at the place where I want to hang my TV. So need to use special drywall screws and better use more..
I check some other mount bracket. But few of them …"  Read Full Review »
Jan 19 2009
tiber
santa clara, ca
Reviewed at:
Price: $26.99
Good wall mount
5.0
"This is a very easy to install wall mount. You will need a socket wrench set, A screw driver and stud finder and thats it. It even comes with a level. I installed this in about 15 minutes. It works well and the tilt works and holds it where i want it. Plus it comes with the parts so you can lock you …"  Read Full Review »
Jun 25 2008
HDDVDer
Charlotte NC
Reviewed at:
Price: $26.99
Great price, Easy mount
5.0
"This product is great. I have a 22in Samsung LCD I hung using this bracket. It sits beautifully in my bedroom. It's low profile Install was a breeze and came with a level that sits perfectly in the top of the bracket so I got a perfectly aligned set up. I now enjoy television in bed and have a great …"  Read Full Review »
Sep 15 2009
AtlTheater09
Atlanta, Ga
Reviewed at:
Price: $26.99
I absolutely love this ...
5.0
"I absolutely love this mount. It's so easy to use and I actually put it on a 32" Dynex with no problems. Not all 32" TVs will fit this mount, but it did on the 32" dynex. It's really easy to use. I only had to put 2 bolts in the wall and then a simple screw turn allowed me to adjust the tilt. Don't …"  Read Full Review »
Jul 22 2009
JHSpartan
Ann Arbor, MI
Reviewed at:
Price: $26.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
