Infinity 4627cfp 4" X 6" Two-way Plate Lousdpeakers (pair)
5.0
based on 1 review
from
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.3
Pros
  • Compact (1)
See less See more
Best Uses
Provided by Beach Audio
New for 2005 is the redesigned .7-Series that features UniPivot a patented rotating tweeter system for perfecting sound imaging regardless of mounting location. The tweeter is also tunable on the spot! With a turn of the tweeter, you can adjust the emphasis level without having to access the external crossover. These new edge-driven Metal Matrix Diaphragm (M.M.D.) tweeters are similar to those found in high-end home audio speakers. That means mobile audiophiles will appreciate the increased power handling and reduced distortion at high output levels. The SLI (Super Low Impedance) high-output design extracts every last watt from the amplifiers source, increasing overall system output and efficiency. Also new for 2005 is the Neodymium motor structure with integrated heatsink. This cutting-edge motor technology provides massive power handling while maintaining a minimal mounting depth. The integrated heatsink wicks heat away from the motor structure, increasing power while reducing distortion. The redesigned .7-Series mid and woofer cones feature woven-glass fiber material for unmatched stiffness and damping ability. The result is the cleanest, snappiest mid-bass with absolutely no coloration or distortion. The cone also features Plus One sizing and a hi-roll butyl rubber surround, which maximizes the cone area and excursion capability for maximum performance at high volume. Redesigned, nonconductive, cast polymer baskets are tooled for shallow mount applications. Each Kappa speaker comes with a computer designed outboard crossover that has been voice-matched for total accuracy.
Infinity 4627cfp 4" X 6" Two-way Plate Lousdpeakers (pair) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 4627cfp 4" X 6" Two-way Plate Lousdpeakers (pair)
See all eBay results
  at eBay.com
Product Reviews
Last update: May 6, 2009
Infinity 4627cfp 4" X 6" Two-way Plate Lousdpeakers (pair) Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Sounds great!
5.0
    Pros
  • Compact
    Cons
  • None
    Best Uses
  • None
"Fit my camaro great. Right in the hole just like factory "
Was this Car Speaker & Subwoofer review on the Infinity 4627cfp 4" X 6" Two-way Plate Lousdpeakers (pair) helpful to you?
May 6 2009
SJ
Chicago, IL
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
