#413
based on 85 reviews
Ratings Distribution
| 5 star |
40 |
| 4 star |
25 |
| 3 star |
6 |
| 2 star |
4 |
| 1 star |
10 |
Category Average
$79.95
from 1 storePros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
Product Reviews
"I was in search of an inexpensive green screen that was portable and found this bundle of a collapsible, reversible green/blue screen that seemed to fit my needs, and it came with its own stand, how perfect.Well the stand wasn't designed specifically for the green screen. [...] The handle seemed easy but did not tighten enough to secure the boom. That's when I went through the box in hopes of an instruction..." Read Full Review »
Aug 28, 2009 by TacoRick
See more positive Impact Multiboom Light Stand/Reflector Holder - 13' (4m) reviews
"This stand broke before I could use it. The design is poor. Before I was able to actually use the stand, the threads in the body of the stand that a tensioning screw threads into, stripped out. As a mechanic I feel that I am qualified to comment on the durability of fasteners and threading a metal 'T' screw into plastic is only going to last so long. The screw threads that failed are the ones used to tighten ..." Read Full Review »
Sep 16, 2009 by Tom
See more negative Impact Multiboom Light Stand/Reflector Holder - 13' (4m) reviews
Displaying 1 - 5 of 85 Reviews
Impact Multiboom Light Stand/Reflector Holder - 13' (4m) Review
Pros
Cons
Best Uses
Read Full Review »
Pros
Cons
Best Uses
"I was in search of an inexpensive green screen that was portable and found this bundle of a collapsible, reversible green/blue screen that seemed to fit my needs, and it came with its own stand, how perfect.Well the stand wasn't designed specifically for the green screen. [...] The handle seemed …" Read Full Review »
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"I bought this as part of a kit with the Impact 32 reflector.It works okay for what it is, but pops apart when lifted sometimes.When used with the reflector, it does its job...
Problems Encountered: I have two of these, and the boom arm at times will pop off when lifting the stand.I don't trust th
Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Every boom needs to be counterweithed, and incidentally sanded at its base, if you work with gravity, like everyone.
Don't ask yourself were is the counterweight, This stand is made to be as light as possible. there is a hole at the end of the boom, to hang a hook or a very small carabiner,they ev
Read Full Review »
[0 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"OK so at first I had no problems with this stand. After all it is my first light stand so I don't have a lot to compare it to anyways. However, after about 5 uses the boom portion started to get stuck and I had to use all my might to extend and retract it. The problem seemed to be somewhere inside t …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
