Impact Acoustics 250ft RG59/U Dual Shield In Wall Coaxial Cable
#600
4.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$29.99 at Cables To Go
Find it at Amazon
Find it at Ebay
$29.99
from 1 store
Pros
  • Versatile (2)
  • Consistent performance (1)
  • Good length (1)
  • Rugged (1)
See less See more
Best Uses
  • Cctv (1)
  • High-end equipment (1)
Provided by Cables To Go
Impact Acoustics RG59/U Dual Shield is ideal for antenna and cable television installations. This cable is 20AWG copper clad steel center conductor surrounded by a foam polyethylene dielectric. A bonded aluminum foil and 60% aluminum braid provide 100% shield coverage. Use for CL1, CL2, CM, CMX and CMG installations. Swept tested to 3GHz to ensure performance at applicable frequencies. To help you keep track of cable used, the cable jacket is sequentially marked every two feet.
Features:
  • 20AWG copper clad steel center conductor
  • 60% aluminum braid over foil provide 100% shield coverage
  • Foam polyethylene dielectric
  • CM/CL2 rated PVC jacket
  • Swept tested to 3GHz
  • Sequential foot marking
  • Inner Conductor: 1/0.813 mm (20AWG) Copper Clad Steel
  • Insulation: 3.71mm foam PE
  • Outer Conductor: Al/P-Foil (Bonded) + 0.12mm x 64 Al Wire Braiding
  • Coverage: 60%
  • Sheath: 6.10mm Black PVC (C/UL CMG CL2)
  • Ideal for RF applications like outdoor TV antennas and cable television
Impact Acoustics 250ft RG59/U Dual Shield In Wall Coaxial Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 26, 2009
Impact Acoustics 250ft RG59/U Dual Shield In Wall Coaxial Cable Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Very affordable solution
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • CCTV
"Our facility had to do multiple long runs (500' or more) for CCTV security camera installations. This cable was an affordable choice for us due to the sheer quantity that we needed. We are very pleased and would use it again for additional runs. "
Was this Audio Visual Cable & Connector review on the Impact Acoustics 250ft RG59/U Dual Shield In Wall Coaxial Cable helpful to you?
May 26 2009
Gary Vincent
Shinnston, WV
I am:
  • Power User
Reviewed at:
Price: $29.99
I would buy this product again
4.0
    Pros
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
"A lot of cable for the price. "
May 5 2009
ctechpap
North Carolina
I am:
  • Power User
Reviewed at:
Price: $29.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
