Impact Acoustics 1.5ft Velocity™ Mini-Coax F-type Cable
#409
4.7
based on 3 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$4.00 - $13.18
from 8 stores
More Images
Pros
  • Consistent performance (2)
  • Good length (2)
  • Versatile (2)
  • Adequate (1)
  • Flexible (1)
  • Rugged (1)
See less See more
Cons
  • Availability of length (1)
Best Uses
  • Hiding the cable (1)
  • Home tv pc setup (1)
  • Travel (1)
Provided by Cables To Go
Velocity™ Mini-Coax F-Type Interconnects from Impact Acoustics perform the same job as large, stiff, unsightly coaxial cables. These cost-effective high-performance cables give you maximum video quality in a super-thin design. Low-loss 75ohm pure copper wire and foam dielectric ensure optimum picture resolution and color. A Mylar® foil and braid shield protect against unwanted noise and interference. The molded connectors attach to an ultra-flexible jacket, and allow for easy installation. The 24K gold plated heavy-duty connectors ensure long-lasting, high-performance connections.
Features:
  • Connectors: F-Type Plug to F-Type Plug
  • Pure copper center conductor delivers high-quality video
  • Super-thin, high-quality cable hides neatly between carpet and baseboard
  • Mylar® foil and braid shield provide a clear, noise-free, vivid picture
  • Ultra-flexible PVC jacket for easy installation
  • Corrosion-resistant, precision-made 24K gold plated connectors ensure long-lasting quality
  • Fully molded connectors provide excellent strain relief
  • Ideal for attaching cable boxes, VCRs, WebTV or any video source with F-type output connections to any TV with matching F-type input jacks
Impact Acoustics 1.5ft Velocity™ Mini-Coax F-type Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 25, 2009
Impact Acoustics 1.5ft Velocity™ Mini-Coax F-type Cable Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Quick and Correct
4.0
    Pros
  • Good Length
    Cons
  • None
    Best Uses
  • Travel
"I ordered the 1.5 ft velocity cables on line. [...] They were a smaller diameter that I expected, I have used coaxial cable in other projects. This time, in order to install a digital converter, smaller was better. I was modifying the TV in our motor home. Space is at a premium in the TV cabinet. Co …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Impact Acoustics 1.5ft Velocity™ Mini-Coax F-type Cable helpful to you?
 Report Abuse  (1)  (0)  0 comments
May 5 2009
NA
Tracy, CA
I am:
  • Casual User
Reviewed at:
Price: $8.99
Great easy to work with quality cables
5.0
    Pros
  • Consistent Performance
  • Flexible
  • Versatile
    Cons
    Best Uses
  • Hiding the cable
"I bought these cables again for coax hook up and for the flexibility and great value. Easy to run and hide rather than bending bulky coax cable. I would use these for all F type connections. "
Aug 25 2009
Erich
Orefield Pa
I am:
  • Casual User
Reviewed at:
Price: $8.99
Ease of selection
5.0
    Pros
  • Adequate
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Home TV PC setup
"I got what I ordered and it did what I needed done. [...] price competitive with other suppliers "
May 25 2009
ferlady
Santa Rosa, CA
I am:
  • Casual User
Reviewed at:
Price: $8.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
