Imation 8GB USB 2.0 Clip Flash Drive
#222
3.6
based on 8 reviews
Ratings Distribution
5 star
4
4 star
1
3 star
0
2 star
2
1 star
1
Category Average
4.3
Low Price:
$26.00 at www.sayera.com
 Trusted:
$27.99 at MacMall
$26.99 at ClubMac
see all stores
$26.00 - $115.56
from 9 stores
More Images
Pros
  • Easy setup (1)
  • Easy to use (1)
  • Fast (1)
  • Large capacity / good size (1)
  • Portable (1)
See less See more
Best Uses
  • File transfer (1)
Provided by Super Warehouse
For the ultimate in portable data storage- the Imation Clip Flash Drive is the easy answer. Safely encased in a tough rubberized shell- this extremely compact flash drive can be quickly removed from its case to share or transfer files while fitting into the tightest USB slots. An ultra-durable clip attaches the drive quickly and easily to backpacks- shoulder bags or belt loops to ensure that the drive is ready to go anywhere it's needed. Students and business professionals alike will enjoy the ease and simplicity of transferring data files- music- photos or videos with the Imation Clip Flash Drive.
  • Product Description: Imation Clip Flash Drive USB flash drive- 8 GB
  • Product Type: USB flash drive
  • Storage Capacity: 8 GB
  • Interface Type: Hi-Speed USB
  • OS Required: Microsoft Windows 2000- Apple MacOS 9- Microsoft Windows Millennium Edition- Microsoft Windows XP- Linux 2.4 or later- Microsoft Windows Vista
  • Manufacturer Warranty: 5 years warranty
Specification Description
Model 26657, 26657-
UPC 051122266577
Storage Capacity 8 GB
Imation 8GB USB 2.0 Clip Flash Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 26, 2009
Imation 8GB USB 2.0 Clip Flash Drive Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
Awesome!
5.0
    Pros
  • Easy To Setup
  • Easy to use
  • Fast
  • High Capacity
  • Portable
    Cons
  • None
    Best Uses
  • File Transfer
"Did a lot of research before purchasing this particular Flash Drive. Have had more than one Flash Drive break ( at least the connector ) while connected to my key chain. Was initially concerned when looking at this one that the FD would fall out of the casing -- but it's secure and I feel very com …"  Read Full Review »
Was this Flash Stick review on the Imation 8GB USB 2.0 Clip Flash Drive helpful to you?
Jun 25 2008
Lance
Madison, WI
I am:
  • Power user
Reviewed at:
[2 of 2 customers found this review helpful]
Imation USB Flash Drive
5.0
"I like the design with the clip. Clip it to your laptop case or belt loop and no worries about losing it. Flash drive itself also works well. Pop it out of the carry case and it is small so you have no trouble inserting into a USB port with other devices plugged in around it. I have the 4GB siz …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 21 2008
Richard Eldridge
Kentucky USA
Reviewed at:
Price: $115.56
[1 of 1 customers found this review helpful]
So Far So Good
4.0
"I think they could have made the rubber holder a bit smaller so that it works on a key chain better. With that said, the larger size gives the holder and the clip more durability. I can understand why they went in the direction they did. The USB works as you would expect, there are no complaints her …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 26 2009
Paul J. Nus
Amazon
Reviewed at:
Price: $115.56
Excellent
5.0
"I bought the same imation 528mb flash drive before I started school, but then realized I needed more capacity for all my projects that I was constantly working on between the dorm and library. This flash drive is extreamly easy to use and works when going from a Mac to PC. Only downside I was not aw …"  Read Full Review »
Apr 25 2009
Lease M.
Amazon
Reviewed at:
Price: $115.56
[1 of 3 customers found this review helpful]
Definitely not worth the time or the money.
1.0
"The USB drive itself is flimsy. Removing it from the housing just bends the connector over time. If you're the absent-minded type, the small size of the USB drive itself guarantees you'll leave this behind more than once. The cheap plastic surface of the drive itself wears out quickly, so if you're …"  Read Full Review »
 Report Abuse  (1)  (2)  0 comments
Jan 24 2009
Jun Kayama
Amazon
Reviewed at:
Price: $115.56
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
