based on 12 reviews
Ratings Distribution
| 5 star |
4 |
| 4 star |
5 |
| 3 star |
0 |
| 2 star |
1 |
| 1 star |
2 |
Category Average
Pros
Cons
Best Uses
Where to Buy
at Amazon.com | ||||
eBay listings for: ™ iHM2B Portable Speaker System
See all eBay results |
at eBay.com | |||
Product Reviews
"I give this 4 stars rather than 5 only because of sound quality: this is not the product for you if you like your music loud because it gets scratchy-sounding if the volume is too high. Otherwise, it's cheap, portable, incredibly easy to set-up and accommodates both of the iPod models I have . It's also quite small and has no cords so it fits anywhere you go without trouble...." Read Full Review »
Jan 02, 2008 by Mary
See more positive iHome ™ iHM2B Portable Speaker System reviews
"Like the other reviewer, mine also started breaking down after 2 months of use. It buzzes really badly and has this spacey sound when I try to use it at a reasonable volume. But I give it 2 stars instead of 1 because the sound coming out of it was great in the beginning. I guess just don't play it too loud...." Read Full Review »
Mar 13, 2009 by Apple sauce
See more negative iHome ™ iHM2B Portable Speaker System reviews
Displaying 1 - 5 of 12 Reviews
iHome ™ iHM2B Portable Speaker System Review
Pros
Cons
Best Uses
"I give this 4 stars rather than 5 only because of sound quality: this is not the product for you if you like your music loud because it gets scratchy-sounding if the volume is too high. Otherwise, it's cheap, portable, incredibly easy to set-up and accommodates both of the iPod models I have . It's …" Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"The iHome is very easy to set up. The sound is great for it being only[$]. It's pretty small so you can put it anywhere. You don't need to worry about loosing plugs and worrying about setting it up. The only thing is is that I wish it was able to charge my iPod while I listened to it. Overall it's w …" Read Full Review »
Pros
Cons
Best Uses
"Like the other reviewer, mine also started breaking down after 2 months of use. It buzzes really badly and has this spacey sound when I try to use it at a reasonable volume. But I give it 2 stars instead of 1 because the sound coming out of it was great in the beginning. I guess just don't play it t …" Read Full Review »
Pros
Cons
Best Uses
"As a first time radioshack.com purchaser, I was worried that these speakers wouldn't meet my standards. I usually buy something cheap, then it breaks down, and i give up or buy the expensive counterpart. But what a surprise!
Very clear, very easy to use, and very sleek.
LOVE IT!
Pros
Cons
Best Uses
"The volume is decent for its size, but if you play it too loud too often, the sound will eventually start to go. Mine broke within 2 months of completely normal use. Do not buy! It's not worth any of your money. Very cheap product. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
at eBay.com | |||
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
