Humax 20'' LCD TV W/ Built In DIRECTV Receiver
4.3
based on 4 reviews
from
Ratings Distribution
5 star
2
4 star
1
3 star
1
2 star
0
1 star
0
Category Average
4.4
Pros
  • Attractive design (2)
  • Fast setup (2)
  • Simple controls (1)
See less See more
Best Uses
  • Home (2)
  • Movies (1)
Provided by Beach Audio
As a DIRECTV subscriber, when you are furnishing a kitchen, bedroom or office with a new TV, you have many factors to consider, and finding the ideal location for the TV is only half the challenge. You have to consider the set top box. Now, with the HUMAX LD2060, that features a built in DIRECTV Receiver, you can turn your focus to what is importantthe perfect placement for your TV. No more hiding additional cables behind bookshelves, or turning to the kitchen cabinet to change channels!
Simply point the remote at the TV and click, just as it was meant to be. And of course the LD2060, combined with DIRECTV service, delivers access to over 250 channels of superb digital-quality video and audio in any environment, with an eye-pleasing design that is certain to complementnot competewith any interior styling. Quality, aesthetics, and unmatched convenience, brought to you the "Easy Digital" way. Only from HUMAX.
Features:
DIRECTV Receiver BUILT IN by eliminating the need for an external DIRECTV Receiver, this television streamlines your living space and simplifies your user experience.
BRIGHT 20 LCD large enough to view over 250 available channels of digital quality video only from DIRECTV, yet compact enough to fit just about anywhere, this television is the ideal size for a kitchen, bedroom, office, garage and more.
THIN sleek dimensions allow this TV to tuck neatly into small spaces or fit closely and firmly to a wall.
STYLISH DESIGN the elegant and sophisticated design will complement not compete with any interior styling.
TRADITIONAL 4:3 ASPECT RATIO WITH 640x480 RESOLUTION industry standard viewing resolution prevents unwanted image distortion associated with many widescreen TVs displaying standard definition programming.
VIVID 450 cd/m2 LUMINANCE the display is crisp and clear in practically any lighting environment, with brilliant colors, subtle tones and the deepest blacks.
WIDE 160H/140V VIEWING ANGLE with clear pictures from virtually any angle, this feature makes every seat in the room the best seat in the house.
VESA WALL MOUNT COMPATIBLE industry standard wall mounting provides quick, secure and adjustable installations with versatile mounts offered by most retailers.
Specifications:
LCD Screen: Size 20.1
Resolution: 640 x 480
Aspect Ratio: 4:3
Contrast Ratio: 500:1
Brightness: 450 cd/
Viewing Angle: H160/V140
Pixel Response: 16ms
AV Inputs
o Composite Video 2 Phono
o Component Video 1 3 Phono (Y/Pb/Pr)
Audio: 3 Phono L/R
AV Outputs
o Composite Video 1 Phono
o Audio 1 Phono L/R
Audio/Sound
Amplifier 3W + 3W (max.)
Sound Effects Flat, Speech, Movie, Music, User
DIRECTV TUNER
Input Connector 1 F-TYPE
Frequency Range 950 to 2150 MHz
Signal Level -25 to -75 dBm
LNB Voltage 3/18volt=500mA max.
LNB Polarization V:+13.5V, H:+18V (V:+14V, H:+18.5V)
22kHz Tone Frequency: 22+-4kHz, Amplitude 0.6 +-0.2
Video Features
De-Interlacing 3-D Motion Adaptive
3-D Comb Filter Y
Noise Reduction Y
Sharpness LTI/CTI
Color Enhancement Flesh Tone Enhancement
Picture Mode Standard, Dynamic, Movie, Mild, Game, User
Other
Power Supply 110V, 50/60Hz
Power Consumption TBD
USB 2.0 1
Modem 1 RJ-11
Dimensions
Unit Dimensions (WHD) 24.2 x 16.3 x 7.1
Unit Weight 19.36lbs.
VESA Wall Mount 100 x 100 (VESA Hole 4 Each)
Humax 20'' LCD TV W/ Built In DIRECTV Receiver Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 20'' LCD TV W/ Built In DIRECTV Receiver
See all eBay results
  at eBay.com
Product Reviews
Last update: May 30, 2007
Humax 20'' LCD TV W/ Built In DIRECTV Receiver Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
overpriced, but...
3.0
    Pros
  • Attractive Design
  • Fast Setup
    Cons
  • None
    Best Uses
  • Home
"This product is as advertised 4:3 directv etc. Poor sound, good to excelent picture depending on the lighting. On a scale of 1-10, 8. No HDTV or widescreen. Second best price I've found online. I'm satisfied. "
Was this LCD TV review on the Humax 20'' LCD TV W/ Built In DIRECTV Receiver helpful to you?
May 30 2007
AmazinMike
Chicago
I am:
  • Gearhead
Reviewed at:
"My opinion of the Humax ...
5.0
"My opinion of the Humax LCD 20"" with DirecTV is a good one. I bought this product because I needed a small tv in the kitchen but didn't have room for a receiver. This tv mounts to the wall or sits on the counter. The picture quality is good. It is not HD but most dish programming is not in HD anywa …"  Read Full Review »
Nov 15 2006
Ana from Houston, TX
Undisclosed
Reviewed at:
"I am very happy with my ...
5.0
"I am very happy with my Humax Direct TV receivers. They were easy to install and work great. The only draw back to them I can find is that they are not HD Compatible. I did know that before I bought them, but convenience of not having another Direct TV box was more important to me in locactions I wa …"  Read Full Review »
Nov 13 2006
Stephen A
Undisclosed
Reviewed at:
Great compact package
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"Easy setup, great compact package, and no separate reciever necessary! I love this TV "
Apr 3 2007
THAR
Lititz, PA
I am:
  • Practical
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
