HP Wireless Laser Mini Mouse
#356
4.0
based on 43 reviews
Ratings Distribution
5 star
56
4 star
33
3 star
5
2 star
8
1 star
11
Category Average
4.3
$23.99 - $39.99
from 14 stores
Pros
  • Comfortable design (68)
  • Glides smoothly (68)
  • Fast response (62)
  • Accurate tracking (59)
  • Works on any surface (47)
  • Great features (40)
  • It works like i expected (1)
See less See more
Cons
  • Limited surface compatibility (4)
  • Poor battery life (4)
  • Slow response (3)
  • Catches easily (2)
  • Inaccurate tracking (2)
  • Bad usb receiver (1)
  • Doesn't left click at all (1)
  • Flimsy usb adaptor (1)
  • Gliding issue (1)
  • Reqs flat surface (1)
Best Uses
  • Everyday (60)
  • Web browsing (47)
  • Travel (33)
  • Professional (21)
  • Gaming (13)
  • Graphic design (1)
Provided by NothingButSoftware
Compact, lightweight mini mouse great for those on the go!
The HP Wireless Laser Mini Mouse is an affordable and talented wireless wireless laser mouse solution that is elegant and stylish in design. Wireless technology for freedom of movement – no more wires to to get in the way!  Laser sensor works on more surfaces than optical mice.  Perfect size for travel or for kids.
  • Stylish shape and color
  • Ambidextrous to fit all hands
  • Low battery indicator
  • Programmable buttons for your needs: Magnifier, Web Browser, Browser, Minimize, Maximize and many more.*
  • Three Button functions including Zoom
  • Tilt wheel for four-way scrolling
  • Slimline USB Receiver stores in bottom of mouse (never lost)
  • Power Saving modes of standby and sleep
  • Factory linked components for plug and play
  • 800dpi laser sensor
  • Tilt scroll wheel (four-way)
  • Power saving modes of Standby and Sleep
  • Manual connect button on bottom of mouse
  • USB Slimline Receiver with manual connect button and indicator indicator light
  • Battery Life Indicator Light
  • Weight:  0.202 lb
  • Dimensions:  3.55" x 2.06" x 1.41"  (L x W x H)
  • HP Wireless Laser Mini Mouse
  • Carrying Pouch
* Programmable buttons may require the download of the programming software from the or from .
For full documentation and mouse synchronization,
  • Windows 98SE, Me, 2000, XP or Vista
  • Available USB Port
  • CD-ROM drive
Specification Description
Model EY018AA, EY018AA#ABA, GT909AA
UPC 882780530799
BPP Bucket 3781960
BPP Eligible Yes
Can Be Giftwrapped Yes
Connection Type Wireless
Corp National Status A
Date 1st Available Online 22-APR-09
Freight Class ANY
Hazmat Warning N
Manufacturer Part Number HPEY018AATRU
Movement Detection Laser
Movement Resolution 800 dpi
Notify Me When Available Yes
Registerable Yes
TRU SKN 239736
HP Wireless Laser Mini Mouse Questions
Questions and Answers
Where to Buy
$27.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$23.99
Free Shipping (some exclusions)
BizRate Rating Outstanding 9.2
$25.99
Show all 14 stores
Product Reviews
Last update: Nov 17, 2009
HP Wireless Laser Mini Mouse Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
I really like it
"very easy to plug in and use. the thing that plugs into the computer fit right into the bottom of the mouse so it can't get lost when not in use. I thought that was pretty cool.And it comes with a nice little storage bag...." Read Full Review »
Apr 10, 2008 by Hunter
See more positive HP Wireless Laser Mini Mouse reviews
2.0
Recurring difficulties with this mouse
"While I cannot determine whether this is a software (e.g. driver) or hardware problem, I will note that the mouse, in close proximity to the USB transmitter, frequently fails to allow me to select text or location across Microsoft apps - Office Outlook 2007 and Office Word 2007, on HP Pavilion notebook running Windows Vista, 64-bit system. Extensive research has not yielded solution, and HP site is not helpful...." Read Full Review »
Apr 12, 2009 by JNC
See more negative HP Wireless Laser Mini Mouse reviews
Displaying 1 - 5 of 43 Reviews
Show
Sort by
2.0
    Pros
  • Comfortable Design
    Cons
  • Inaccurate Tracking
  • Limited Surface Compatibility
  • Slow Response
  • Tracking failures X-app
    Best Uses
  • None
"While I cannot determine whether this is a software (e.g. driver) or hardware problem, I will note that the mouse, in close proximity to the USB transmitter, frequently fails to allow me to select text or location across Microsoft apps - Office Outlook 2007 and Office Word 2007, on HP Pavilion noteb …"  Read Full Review »
Was this Computer Mice review on the HP Wireless Laser Mini Mouse helpful to you?
Apr 12 2009
JNC
Woodinville, WA
I am:
  • Power user
Reviewed at:
Price: $27.95
I really like it
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Traveling
"very easy to plug in and use. the thing that plugs into the computer fit right into the bottom of the mouse so it can't get lost when not in use. I thought that was pretty cool.And it comes with a nice little storage bag. "
 Report Abuse  (2)  (0)  0 comments
Apr 10 2008
Hunter
Lander Wyoming
I am:
  • Casual User
Reviewed at:
Price: $27.95
Not recommended
2.0
    Pros
  • Glides Smoothly
  • Works On Any Surface
    Cons
  • None
    Best Uses
  • Everyday Use
  • Gaming
  • Traveling
  • Web Browsing
"The design and size is great for the laptop, easy to carry around, but ran into many problems with the connection. I would often have to disconnect USB and replug it in or remove and put battery back in. Now my transmitter isn't transmitting anymore, computer recognizes it but does not transmit to t …"  Read Full Review »
Sep 4 2009
Nao
Vancouver, Canada
I am:
  • Casual User
Reviewed at:
Price: $27.95
Would Not Recommend
2.0
    Pros
  • Accurate Tracking
  • Glides Smoothly
    Cons
  • Catches Easily
  • Poor Battery Life
  • Temp Stops working
  • Uncomfortable Design
    Best Uses
  • Everyday Use
  • Professional
  • Web Browsing
"I would definitely not recommend this mouse. It constantly just stops working and you have to either pull out the usb and put back in or you have to pull out the battery and put it back in. The only good thing about this mouse is that it tracks very well but not worth the money. "
Jul 3 2009
Ty
St. Louis, MO
I am:
  • Power user
Reviewed at:
Price: $27.95
Awesome
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Gaming
  • Professional
  • Web Browsing
"I think it is awesome. I am getting another one. "
Nov 8 2009
Bobby
Florida
I am:
  • Power user
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
