HP ® 2159m 21.5" Diagonal 16:9 Full HD LCD Monitor
#14
4.9
based on 30 reviews
Ratings Distribution
5 star
28
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
$194.95 - $249.99
from 15 stores
More Images
Pros
  • Sharp image (7)
  • Vivid colors (7)
  • Adjustable (6)
  • Easy setup (6)
  • Lightweight (6)
  • Reasonable price (1)
  • Vga hdmi dvi inputs (1)
See less See more
Cons
  • Narrow viewing angle (1)
Best Uses
  • Home computer (6)
  • Multimedia (5)
  • Hooked to a laptop (2)
Provided by MacMall
2159m 21.5-inch 16:9 Full HD Widescreen Monitor 21.5" diagonal Widescreen TFT LCD active matrix, 160/160 (H/V) viewing angle, 300 nits brightness, 1000:1 contrast ratio, 0.248mm pixel pitch, 5ms response rate, 1920 x 1080 @ 60Hz native resolution Watch movies, edit photos, and play games in HD with brilliant color and clarity on our 2159m 21.5" 16:9 Full HD Widescreen Monitor. It's so spacious and versatile that you can display two Windows side by side, and you'll love the crisp, clear picture.
Specification Description
Model 2159M, 2159m, FV585AA#ABA
UPC 884420328018
Accessory Indicator Yes
Benefits Get deeper blacks, brighter whites and subtle colors with the 3000:1 dynamic contrast ratioReduce blur during sports, action movies a
Cables Included DVI-D cableAudio cable
Capacity UOM mAh
Connections DVI-D (1)VGA (1)HDMI (1)
Country Of Origin China
Description Header A display with the wow factor.
Display Catalog Number 55032794
Display Features Tilts +25° to -5°
Display Languages German, Simplified Chinese, Traditional Chinese, Japanese, English, Spanish, French, Italian
Dot Pitch / Pixel Pitch 0.24825mm
Enclosure Color Black/Gray
Flat Panel Mount Interface VESA std
Image Brightness 300 nits (typical)
Image Contrast Ratio 1000:1
Included in the Box HP 2159M monitorPower cableDVI-D cableAudio cableInstallation CD
Interfaces DVI-DVGAHDMI
Manufacturer Labor Warranty 12
Manufacturer Part Number FV585AA#ABA
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Resolution 1920x1080
Model 2159M
Monitor Screen Size 21 inches
Monitor Type LCD
Monitor Weight 11.4 lbs
Operating Temperature UOM ° F
Placing / Mounting VESA 4 hole
Power Consumption Operational <55 watts
Power Consumption Stand by / Sleep <2 watts
Power Device AC
Product Depth 15.5
Product Dimensions UOM inches
Product Height 8
Product Type LCD
Product Weight 13.23
Product Weight UOM pounds
Product Width 21
Response Time 5 ms (on-off)
Speaker(s) 2 built-in
Supported Languages English, Simplified Chinese, Japanese, German, Spanish, French, Korean, Italian
Type 21.5" diagonal Widescreen Thin-Film Transistor LCD active matrix
Viewable Size 21
HP ® 2159m 21.5" Diagonal 16:9 Full HD LCD Monitor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
HP ® 2159m 21.5" Diagonal 16:9 Full HD LCD Monitor Reviews
Displaying 1 - 5 of 30 Reviews
Show
Sort by
" I love my large screen"!
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • None
    Best Uses
  • Home Computer
  • Hooked To A Laptop
  • Multimedia
"I have a laptop so this "enlarges" my visuals. I love to do photography and the image I get with the monitor is quite nice.
I was excited with the ease of setting up. I did myself without help which is a first! "
Sunset in the Bisti Wilderness
  • Using Product
Was this LCD Monitor review on the HP ® 2159m 21.5" Diagonal 16:9 Full HD LCD Monitor helpful to you?
Nov 14 2009
Peggy
San Luis Obispo, CA
I am:
  • Value Oriented
Reviewed at:
Price: $199.99
Nice monitor for pictures and video
4.0
    Pros
  • Easy Setup
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • Low viewing angle
    Best Uses
  • Home Computer
  • Multimedia
"There are a number of matte finish monitors out there and a few glossy. Most of the matte monitors have similar picture, with photos and videos looking rather two-dimensional. This monitor (along with other glossy screens) seems capable of providing more three-dimensional detail. To notice this diff …"  Read Full Review »
Nov 9 2009
Serniter
Piscataway, NJ
I am:
  • Quality Oriented
Reviewed at:
Price: $199.99
Great Value, Great Images
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • none
    Best Uses
  • Home Computer
  • Multimedia
"I was pleasantly surprised today when the monitor arrived and it was so easy to install. The new pedistal is a great improvement. Adjusting the position of the monitor is much easer. The color is vibrant and so much better than the old 22" monitor also from HP that it is replacing. "
Nov 11 2009
Anne B
Bothell, WA
I am:
  • Value Oriented
Reviewed at:
Price: $199.99
Bought two for home and working from home
5.0
"SUMMARY
I bought two. Will discuss my usage, installation experience, picture quality, glossy screen, cables, and graphics resolution issues.
DETAILS
Running on an old work laptop at home (Dell Latitude 610) without high video resolution. Using it for working from home occasionally (doing softwar …"  Read Full Review »
Oct 1 2009
SomebodyGotMyName
Little Rock
Reviewed at:
Price: $219.99
[1 of 1 customers found this review helpful]
Great monitor for the future
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Lightweight
  • Reasonable price
  • Sharp Image
  • More »
    Cons
  • None yet
    Best Uses
  • Home Computer
  • Multimedia
"when i purchased this monitor i was thinking of the future. when and if i need to upgrade to a newer computer, this monitor has 3 inputs (vga,dvi,hdmi)to accomadate it. screen image is bright, colorful, and crystal clear. price was similar for brands i new little about, but this has hp's reputation …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 1 2009
busy dad
howell, n.j.
I am:
  • Quality Oriented
Reviewed at:
Price: $199.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
