HP 2009m 20 LCD Monitor
#1
4.6
based on 56 reviews
Ratings Distribution
5 star
205
4 star
99
3 star
10
2 star
3
1 star
1
Category Average
4.4
$129.99 - $179.00
from 10 stores
More Images
Pros
  • Vivid colors (254)
  • Sharp image (249)
  • Easy setup (235)
  • Lightweight (206)
  • Adjustable (183)
  • Versatile (11)
  • Amazed at easy setup (1)
  • Bigger than expected (1)
  • Bright screen (1)
  • Cables included (1)
See less See more
Cons
  • Poor adjustability (17)
  • Little detail (6)
  • Inaccurate colors (3)
  • Dead pixels (2)
  • Poor sound quality (2)
  • Poor speakers (2)
  • Audio level is not good (1)
  • Base too short (1)
  • Confusing / difficult controls (1)
Best Uses
  • Home computer (221)
  • Multimedia (95)
  • Gaming (57)
  • Hooked to a laptop (35)
  • Business (2)
  • Desktop (2)
  • Home office (2)
  • Office (2)
  • 360 screen (1)
  • Day trading (1)
Provided by OnSale
2009m 20-inch 16:9 HD Ready Widescreen Monitor 20"diagonal widescreen TFT LCD active matrix, 160/160 (H/V) viewing angle, 300 nits brightness, 1000:1 contrast ratio, 0.2768mm pixel pitch, 5ms response rate, 1600 x 900 @ 60Hz native resolution Want a spacious screen with high-resolution picture quality and total flexibility? Check out our 2009m 20" 16:9 HD Ready Widescreen Monitor. It boasts a 16:9 aspect ratio to greatly enhance both your computing and entertainment, and it lets you capture movies in their original format.
Specification Description
Model 2009M, 2009m, FV583AA#ABA
UPC 884420327684
Accessory Indicator Yes
Benefits Expand your view to include more room for Web pages, wide documents and online gamesView details clearly with a maximum resolution of
Cables Included VGA cable, Audio cable
Capacity UOM mAh
Connections VGA (1)DVI-D (1)
Country Of Origin China
Description Header Look at this.
Diagonal Size 20"
Display Catalog Number 55033691
Display Languages Multiple language support
Display Screen Coating High-gloss, anti-reflective
Dot Pitch / Pixel Pitch .28
Enclosure Color Black/Gray
Flat Panel Mount Interface VESA 100x100mm
Image Brightness 300 nits (typical)
Image Contrast Ratio 1000:1
Included in the Box HP 2009m monitorPower cableVGA cableAudio cableCD with instructions
Interfaces VGA, DVI-D
Manufacturer Labor Warranty 12
Manufacturer Part Number FV583AA#ABA
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Resolution 1600x900
Model 2009M
Monitor Screen Size 20 inches
Monitor Type LCD
Monitor Weight 13.23 lbs
Operating Temperature UOM ° F
Output Power / Total 2 watts
Placing / Mounting Stand or wall mount
Power Consumption Operational 47W
Power Consumption Stand by / Sleep < 2W
Product Depth 7.2
Product Dimensions UOM inches
Product Height 19.8
Product Type LCD
Product Weight 13.23
Product Weight UOM pounds
Product Width 14.6
Response Time 5ms
Speaker(s) Built-in
Supported Languages English, French, German, Italian, Japanese, Portuguese, Dutch, Simplified Chinese
Type Widescreen Thin-film Transistor LCD active matrix
Voltage Required 110VAC
HP 2009m 20 LCD Monitor Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
HP 2009m 20 LCD Monitor Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
Beautiful, just beautiful
"This is a birthday gift from my daughter; she knew I wanted a new monitor and gave me the option to select which one. Was at first, going for the Acer 22 inch widescreen, that is until I went to Staples and actually saw it. Then I saw this one and was instantly in love. The text was so sharp and crisp and the graphics so vivid. I compared all the other 20/22 inch monitors at my Staples store and they paled i..." Read Full Review »
Jun 12, 2009 by CherryPearl23
See more positive HP 2009m 20 LCD Monitor reviews
3.0
Just need one
"The stand that it comes with is flimsy. Screen is extremely reflective when viewing a black background. Text appears squishy. Increasing volume is unintuitive (need to press decreasing volume button first to activate volume menu). Sounds from speakers are okay. For better ergonomics, attach monitor to LCD monitor stand (VESA 100 in back of monitor). The wow factor is the shiny glossy monitor frame compared to..." Read Full Review »
Oct 04, 2009 by Buying electronic gadgets when needed
See more negative HP 2009m 20 LCD Monitor reviews
Displaying 1 - 5 of 56 Reviews
Show
Sort by
Great Product
5.0
    Pros
  • Easy Setup
    Cons
  • None
    Best Uses
  • Gaming
  • Home Computer
  • Hooked To A Laptop
  • Multimedia
"This computer is great, along with the lcd monitor, JR offered the cheapest price, and this computer is worth well more than listed. "
Was this LCD Monitor review on the HP 2009m 20 LCD Monitor helpful to you?
Nov 10 2009
Friend
Maryland
I am:
  • Quality Oriented
Reviewed at:
Price: $139.99
[2 of 2 customers found this review helpful]
This is a great monitor worth every cent
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • No remoteIR Sensor
    Best Uses
  • 360 screen
  • Home Computer
  • Multimedia
"This monitor has loads of features, and is also at a great price, I have it currently connected Via VGA Still looks freakin' awesome. The video viewing is great, the games on the 360 looks much more realistic. Cons: No IR Sensor for remote control for volume adjusting.
Pros: Bright, saves space. V …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jul 1 2009
Phil_Dawg2009
Dahinda, IL
I am:
  • Quality Oriented
Reviewed at:
Price: $139.99
Built-in speakers
3.0
    Pros
  • Easy Setup
  • Sharp Image
    Cons
  • Poor Speakers
    Best Uses
  • None
"I bought this model because of the built-in speakers. I had to hook up external speakers anyway because the ones on this monitor are just not loud enough. Nice picture. "
Nov 9 2009
Andy
Clewiston, FL
I am:
  • Value Oriented
Reviewed at:
Price: $139.99
[1 of 1 customers found this review helpful]
Great Monitor
5.0
    Pros
  • Adjustable
  • Easy Setup
  • Lightweight
  • Sharp Image
  • Vivid Colors
    Cons
  • None
    Best Uses
  • Home Computer
  • Multimedia
"I looked locally at different monitors connected to a single source, using the same video card, and found the HP to give the best picture for color and clarity of text, which I think is most important for extended viewing. The other monitors in the display were cheaper, but certainly not better. I …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 18 2009
Skip Straight
Cleveland, OH
I am:
  • Quality Oriented
Reviewed at:
Price: $139.99
Just need one
3.0
    Pros
  • Easy Setup
  • Vivid Colors
    Cons
  • Little Detail
  • Poor Adjustability
    Best Uses
  • Home Computer
For better ergonomics, attach moni …"  Read Full Review »
Oct 4 2009
new york, ny
I am:
  • Quality Oriented
Reviewed at:
Price: $139.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
