HP 19" Widescreen Flat-Panel TFT-LCD Monitor
4.5
based on 81 reviews
Ratings Distribution
5 star
85
4 star
37
3 star
4
2 star
4
1 star
4
Category Average
4.4
More Images
Pros
  • Sharp image (48)
  • Vivid colors (48)
  • Adjustable (34)
  • Lightweight (34)
  • Versatile (17)
  • Adjustable viewing angles (1)
  • Easy hook-up (1)
  • Easy setup (1)
  • Easy to read fonts (1)
  • Great picture quality (1)
See less See more
Cons
  • Inaccurate colors (2)
  • An error has occured (1)
  • And i don't know why (1)
  • Blurry desktop (1)
  • Colors are not bright (1)
  • Driver issues wvista (1)
  • Flicker (1)
  • Found things off color (1)
  • Little detail (1)
  • Little glare (1)
Best Uses
  • Multimedia (24)
  • Gaming (14)
  • Hooked to a laptop (4)
  • Dorm room (3)
  • Home office (2)
  • Home use (2)
  • Conserves space (1)
  • Desktop (1)
  • Entertainment (1)
  • Family computer (1)
Provided by Sears
LCD Panel Type19 diagonal Widescreen Thin-Film Transistor LCD active matrixNative Resolution (recommended)1440 x 900 @ 60 HzContrast Ratio (typical)1000:1 (typical)(typical)Brightness (typical)300 nits (typical)Pixel Pitch0.285 mmResponse Time (typical)5 ms (on-off)(typical)Signal Input ConnectorsConnectorsVGA and DVI-D connections and HDCPVGA cable includedResolution Formats640 x 480 @ 60 Hz, 70 Hz, 75 Hz720 x 400 @ 70 Hz800 x 600 @ 60 Hz, 75 Hz832 x 624 @ 75 Hz1024 x 768 @ 60 Hz, 75 Hz1152 x 720 @ 60 Hz1152 x 870 @ 75 Hz1152 x 900 @ 65 Hz1280 x 768 @ 60 Hz1280 x 960 @ 60 Hz1280 x 1024 @ 60 Hz, 75 Hz1440 x 900 @ 60 HzPower SupplyInternal AC AdapterMaximum Power RatingRating49 WEnergy Saving Mode2 W in sleep modeTilt-5 to +25 degreesDetachable BaseYesVESA MountingStandard 4 hole pattern 100 mm x 100 mm screw-mountingscrew-mounting option; pedestal is removable
Specification Description
Model HP W1907, RK283AA#ABA, W1907, w1907
UPC 882780774636
Benefits Get crisp detail with the maximum resolution of 1440x900Get razor-sharp video from your PC and external HDTV sourcesWatch mo
Capacity UOM mAh
Compliant Standards Microsoft certified, UL listed, Energy Star Compliant
Country Of Origin China
Description Header Open a new Vista into Cyberspace with this display!
Display Catalog Number 55025429
Display Languages English, French, German, Dutch, Italian, Simplified Chinese and Japanese
Dot Pitch / Pixel Pitch 0.285mm
End Product Indicator Yes
Flat Panel Mount Interface VESA 4-hols standard
Humidity Range Operating 20-80%
Image Brightness 300 nits (typical)
Image Contrast Ratio 1000:1
Image Max H-View Angle -5°
Image Max V-View Angle 25°
Included in the Box W1907 monitorAC cableVGA cableAudio cableDocumentation CD
Interfaces VGA, DVI-D
Manufacturer Labor Warranty 12
Manufacturer Part Number RK283AA#ABA
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 95 Fahrenheit
Min Operating Temperature 41 Fahrenheit
Model W1907
Monitor Screen Size 19 inches
Monitor Type LCD
Monitor Weight 11 lbs
Mounting Kit Pedestal included
Operating Temperature UOM ° F
Outputs 1 x VGA, 1 x DVI-D
Power Consumption Operational Less than 49 watts
Power Consumption Stand by / Sleep Less than 2 watts
Power Form Factor TFT-LCD
Product Type LCD
Response Time 5ms
Speaker(s) Built-in, rear-firing
Supported Languages English, French, German, Dutch, Italian, Simplified Chinese, Japanese
Viewable Size 163.2 sq. inches
HP 19" Widescreen Flat-Panel TFT-LCD Monitor Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 19" Widescreen Flat-Panel TFT-LCD Monitor
See all eBay results
  at eBay.com
Product Reviews
Last update: Apr 5, 2009
HP 19" Widescreen Flat-Panel TFT-LCD Monitor Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
4.0
Terrific value.
"This model seems to have become HP's standard flat screen as it's available in PC packages and solo. It's a terrific value due to competitive price and very good display. Factory preset display settings are a bit bright and harsh; use the excellent "My HP Display" software to adjust them to your preference. Screen glare is not a problem if you point it away from windows and overhead lights. Includes an HDMI cabl..." Read Full Review »
Aug 20, 2008 by Ken
See more positive HP 19" Widescreen Flat-Panel TFT-LCD Monitor reviews
1.0
Look At Other Monitors
"I bought this after Christmas and the price was awesome for the picture and HP generally are a good product. But I have to differ cause my screen went out after a week after buying this, then the HP Customer Service was difficult to get a hold of and the Best Buy I purchased it needed an Approval Code to fix it or Replace it. I spent almost three days getting the runaround and was enough. I took it back to the s..." Read Full Review »
Jan 27, 2008 by DarthVader
See more negative HP 19" Widescreen Flat-Panel TFT-LCD Monitor reviews
Displaying 1 - 5 of 81 Reviews
Show
Sort by
1.0
"I bought this after Christmas and the price was awesome for the picture and HP generally are a good product. But I have to differ cause my screen went out after a week after buying this, then the HP Customer Service was difficult to get a hold of and the Best Buy I purchased it needed an Approval Co …"  Read Full Review »
Was this LCD Monitor review on the HP 19" Widescreen Flat-Panel TFT-LCD Monitor helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jan 27 2008
DarthVader
Shillington,Pa
Reviewed at:
[1 of 1 customers found this review helpful]
A Great Flatscreen, the name say it all.
5.0
"I have had my HP pavilion 19" flatscreen moniter for just over 2 months now and by far it provides the best picture quality based on low end to high end graphic cards. Obviously there is a difference when using different quality of graphic cards, however you put any other monitor next to it using th …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Sep 11 2007
hamman
Northern California, near Shingletown
Reviewed at:
Awsome Display
5.0
    Pros
  • Adjustable Viewing Angles
  • Large Viewing Area
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Gaming
  • Movies
"The w1907 lcd monitor from HP is completly awsome. I got the monitor in a HP computer bundle that I bought. I cant believe the image quality the image details are so pure. While at times I wonder about the quality of my new HP computer my monitor never stops amazing me with it's awsome video perform …"  Read Full Review »
May 11 2008
cals06gt.
Louisville Ky
I am:
  • Casual User
Reviewed at:
[2 of 2 customers found this review helpful]
Just bought this...
5.0
"and a custom laptop. I gave this monitor 5 stars all around. The screen quality is bright but not too bright. Amazing picture quality. Also, I am a gamer and the wide screen is perfect(It's more of a preference whether or not you like wide screen over regular). I am also a graphics artist and did no …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
May 15 2008
Sarahs
Undisclosed
Reviewed at:
[4 of 6 customers found this review helpful]
It lacks too much
2.0
"I wouldn't recommend this item to anyone that does multimedia or graphic arts . It's too short in height and the sound is nonexistant. I have more than one HP monitor and this is surely the worst of the 4 I have . The blackness of it is definitely not a plus for those with impaired vision like mysel …"  Read Full Review »
 Report Abuse  (4)  (2)  0 comments
May 2 2008
BewitchedFae
Undisclosed
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
