Hitachi 50" UltraVision Plasma 1080P HDTV with SD Card Input (Model #P50V702)
#61
2.8
based on 4 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
2
Category Average
4.6
Low Price:
$2,199.99 at RadioShack
$3,199.99 at Amazon
Find it at Amazon
$2,199.99 - $3,199.99
from 2 stores
More Images
Pros
  • Attractive design (2)
  • Great picture quality (2)
  • Durable (1)
  • Easy setup (1)
  • Good for stomping on (1)
  • Great sound quality (1)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Difficult to set up (1)
  • Difficult to use (1)
  • Everything (1)
Best Uses
  • Movies (2)
  • Dorm room (1)
  • Fire material (1)
  • Home (1)
  • Large rooms (1)
  • Office (1)
  • Small rooms (1)
Provided by GainSaver
Hitachi P50V702 1920 x 1080 pixel resolution. Full hi-def 1080p with Reel60 film processing . PictureMaster HD VI processor digital video processor optimizes picture performance on all incoming source material. Dynamic contrast MPEG noise reduction. TV Guide On Screen program . 3 HDMI, 2 component, 1 S-Video and 3 A/V inputs. ATSC/NTSC/QAM tuning. Cinema48 for 24p HDMI inputs with dynamic histogram processing . 2 IR output ports and 1 RS-232 control port allows control of components with remote connected externally. SD Card photo viewer with slide show and rotate functions. 4 HD (16:9) formats and 6 SD (4:3) formats . 48 3/16' W x 31 5/8' H x 4 1/8' D (without stand). Includes remote and motorized powered swivel stand. UPC Code: 050585127067
Specification Description
Model P50V702
UPC 050585127067
16:9 Mode Yes
Battery Type Remote
Benefits 50" (diagonal) widescreen display delivers great 16:9 aspect ratio and up to 1280x1080 resolutionMotorized power swivel stand rotates
Capacity UOM mAh
Channel Labeling Yes
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16 Bit/281Trillion Color Processing
Compliant Standards UL Listed, FCC/DHHS Certificated
Country Of Origin Mexico
Description Header Clearly the best.
Display Catalog Number 55029720
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 50 inches
Enclosure Color Black
End Product Indicator Yes
Image Aspect Ratio 16:9
Included in the Box Hitachi P50V702 50" Plasma HDTVRemote control"AAA" batteriesPower cordIR out cableUser's guide
Inputs 1 x HDMI(HDMI V.1.3 with xv Color, CEC), 2 x Component(Wideband Component), 3 x RCA(Video), 3 x RCA(Audio), 1 x "F" Plug(Antenna), 1 x S-Video, 1 x Di
Manufacturer Labor Warranty 12
Manufacturer Part Number P50V702
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model P50V702
Operating Temperature UOM ° F
Output Power / Total 20 watts
Outputs 1 x Digital(Optical audio out), 2 x Phone 1/8"(IR Output port), 1 x Digital(RS-232)
Parental controls Yes
Power Consumption Operational 398W
Product Depth 14.9
Product Dimensions UOM inches
Product Height 33.9
Product Type Flat-panel TVs
Product Weight 96.5
Product Weight UOM pounds
Product Width 48.8
Program Guide Features TV Guide On Screen Interactive Program Guide V9
Reception System ATSC/NTSC/QAM
Screen Size Range 41-50"
Secondary Audio Program (SAP) Yes
Size AAA
Sound Output Mode Stereo
Speaker(s) Built-in, 10W + 10W
Stereo Reception System MTS
Supported Languages English
Surround Sound Effects Surround Sound
Technology IR
TV Diagonal Size 50 inches
TV Resolution 1280x1080
TV Technology Plasma
Type Plasma
V-Chip Control Yes
Voltage 1.5
Voltage Required 120V AC +/- 10%, 60Hz +/- 0.5%
Voltage UOM Volts
Widescreen Modes 480i, 480p, 720p, 1080i
Hitachi 50" UltraVision Plasma 1080P HDTV with SD Card Input (Model #P50V702) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 25, 2009
Hitachi 50" UltraVision Plasma 1080P HDTV with SD Card Input (Model #P50V702) Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
AMAZING
4.0
    Pros
  • Attractive Design
  • Great Picture
    Cons
  • Difficult to Setup
  • Difficult to Use
    Best Uses
  • Home
  • Movies
"Amazing, it's a little hard to set up but great in the long run. "
Was this Plasma TV review on the Hitachi 50" UltraVision Plasma 1080P HDTV with SD Card Input (Model #P50V702) helpful to you?
 Report Abuse  (3)  (0)  0 comments
Apr 25 2009
Dude
Rochester, New York
I am:
  • Casual User
[0 of 3 customers found this review helpful]
Just TERRIBLE
1.0
    Pros
    Cons
  • Everything
    Best Uses
  • Fire material
"My son knocked it over, and the piece of junk broke! [...] Do not buy this terrible cheap piece of garbage. "
 Report Abuse  (0)  (3)  0 comments
Aug 25 2009
TV Smasher
San Jose, CA
I am:
  • Casual User
[0 of 2 customers found this review helpful]
Poor quality Poor documentation
1.0
"two thousand and two years...forget about it...
$800 minimum to fix...
Service manual is the worst I've ever senn. "
 Report Abuse  (0)  (2)  0 comments
Jul 5 2009
Allthebetter
Cleveland
[2 of 2 customers found this review helpful]
YEA BUDDY!!!
5.0
    Pros
  • Attractive Design
  • Clear Audio
  • Clear Picture
  • Durable
  • Easy Controls
  • More »
    Cons
  • None
    Best Uses
  • Dorm Rooms
  • Large Rooms
  • Movies
  • Office
  • Small Rooms
"This thing ROCKS!!! "
 Report Abuse  (2)  (0)  0 comments
Apr 13 2009
Bigpoppa
Orem, Ut
I am:
  • Enthusiast
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
