Hawking Technologies USB to PS/2 Adapter
#1052
4.2
based on 10 reviews
Ratings Distribution
5 star
5
4 star
4
3 star
0
2 star
0
1 star
1
Category Average
4.1
$2.00 - $8.88
from 13 stores
More Images
Pros
  • Simple (5)
  • Durable (4)
  • Durable and reliable (3)
  • Lightweight (3)
  • Consistent performance (1)
  • Easy to configure (1)
  • Easy to use (1)
  • Reliable (1)
  • Saves a ubs slot (1)
  • Strong connection points (1)
See less See more
Cons
  • Key sometimes difficult (1)
  • Not versatile enough (1)
Best Uses
  • Replacement (3)
  • Computer equipment (2)
  • Home (1)
  • Travel (1)
Provided by ClubMac
USB To PS/2 Adapter, Green Converts USB keyboard or mouse to a PS/2 port. USB A Female, Mini-DIN 6 Male Connectors The USB to PS/2 Adapter helps you connect your USB keyboard or mouse to a PS/2 port on your computer. Simply plug this compact adapter into any PS/2 port, then connect your mouse or keyboard.Note: the adapter only functions with items that are compatible with both USB and PS/2 signal types.Works with Windows 98SE, Me, 2000, XP; Apple Mac OS 8, OS 9 and OS X.
Specification Description
Model 35700
UPC 757120357001
Type 6-pin mini-DIN (PS/2) Female to 4-pin USB - Type A Female
Hawking Technologies USB to PS/2 Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Hawking Technologies USB to PS/2 Adapter Reviews
Most helpful positive review
Most helpful negative review
5.0
USB Adaapter
"The product was very well made, it would probably last forever under normal useage. My application was to be able to run two computers using one switchable Keyboard. Unfortunately I didn't realize that one of the computers couldn't use the keyboard that the other one used even though they were both Dell Computers, so the A/B Switch and the adapter I bought were all for nought...." Read Full Review »
Nov 11, 2009 by Gary the Flyboy
See more positive Hawking Technologies USB to PS/2 Adapter reviews
1.0
Product not compatible with keyboard.
"I needed to convert my usb keyboard to a ps/2 connection. However, the service rep told me that it may not be compatible, but bought it anyway. Have been pleased with technical support on the many other I have purchased for my needs...." Read Full Review »
May 14, 2009 by ABC
See more negative Hawking Technologies USB to PS/2 Adapter reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
USB Adaapter
5.0
    Pros
  • Durable construction
  • Reliable
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Computer Equipment
"The product was very well made, it would probably last forever under normal useage. My application was to be able to run two computers using one switchable Keyboard. Unfortunately I didn't realize that one of the computers couldn't use the keyboard that the other one used even though they were both …"  Read Full Review »
Was this Computer Cable & Connection review on the Hawking Technologies USB to PS/2 Adapter helpful to you?
Nov 11 2009
Gary the Flyboy
Farmingdale, NJ
I am:
  • Quality Oriented
Reviewed at:
Price: $7.99
1.0
    Pros
  • Lightweight
  • Simple
    Cons
  • Not Versatile Enough
    Best Uses
  • None
"I needed to convert my usb keyboard to a ps/2 connection. However, the service rep told me that it may not be compatible, but bought it anyway. Have been pleased with technical support on the many other I have purchased for my needs. "
May 14 2009
ABC
Hanover Park, Ill.
I am:
  • Tech Savvy
Reviewed at:
Price: $7.99
just what i needed
4.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • Home
"perfect, just what i needed, with all the new mouses and keyboards out all have usb, and i need all the usb on my pc. went out to the stores to buy, but no one had it, checked the internet, cables to go is the place to go. "
May 5 2009
lennyrd
farmington,MN
I am:
  • Casual User
Reviewed at:
Price: $7.99
Highly Recommend
5.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • None
"Product is compact and works great for what we needed without taking up lots of room. Much better (and less bulky) than the cables I've found elsewhere. "
May 4 2009
AMEC Geomatrix
Sacramento, CA
I am:
  • Power User
Reviewed at:
Price: $7.99
Even the color was great!
5.0
    Pros
  • Durable and Reliable
  • Lightweight
  • Simple
    Cons
  • None
    Best Uses
  • None
"It was great to find the right adapter to connect my pc keyboard to my music system, and for it to be so reasonable. [...] "
Aug 4 2009
Robert the tech-know-nothing
Phila. Pa
I am:
  • Technically Challenged
Reviewed at:
Price: $7.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
