Harman Kardon HS 300 Integrated Home Theater System
2.5
based on 2 reviews
from
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
1
Category Average
4.1
More Images
Pros
  • Easy setup (1)
  • Great sound quality (1)
  • Interfaces well with tv (1)
See less See more
Best Uses
  • Living room (1)
  • Movies (1)
  • Surround sound solution (1)
  • Television shows (1)
Provided by B&H Photo Video
Specification Description
Model HARHS300, HS 300
UPC 028292503078
# of AM/FM Tuner Presets 60
AM/FM Radio Yes
Antenna Type Wire FM antennaAM loop antenna
Audio Response Bandwidth 20Hz-20kHz
Battery Type Remote
Benefits 5.1-channel home theater system produces pure, realistic soundProgressive-Scan DVD player with HDMI output upconverts your old DVDs t
Cables Included HDMI cable, RCA cable for subwoofer, 12-ft. speaker cables for center and front satellite speakers (3), 24-ft. speaker cables for rear satellite speak
Capacity UOM mAh
Channels 5.1 Channels
Chemistry Alkaline
Connectivity Technology Wired
Country Of Origin China
Description Header Bring the movies home.
Detachable grille Yes
Digital Audio Format MP3, WMA
Display Catalog Number 55029555
Display Illumination Color Blue
Enclosure Color Black/Silver
End Product Indicator Yes
Included in the Box HS 300 5.1-Channel DVD receiverRemote control"AAA" alkaline batteries (3)AM loop antennaFM wire antenna
Inputs 1 x "F" Plug(FM antenna), 1 x Push Terminal(AM antenna), 1 x Phone 1/8"(Remote IR input), 2 x USB, 2 x RCA(Audio in), 1 x Toslink(Optical audio in), 1
Magnetic Shield Yes
Manufacturer Labor Warranty 12
Manufacturer Part Number HS 300
Manufacturer Parts Warranty 12
MAP Price 0.0
Model HS 300
Operating Temperature UOM ° F
Output Power / Total 375 watts
Outputs 1 x S-Video(S-Video monitor output), 1 x RCA(Composite monitor output), 1 x Component(Component monitor output), 1 x HDMI, 1 x Phone 1/8"(Remote IR ou
Power Consumption Operational 380.0
Power Consumption Stand by / Sleep 3W
Product Depth 15.75
Product Dimensions UOM inches
Product Disclaimer Dolby and Dolby Pro Logic are registered trademarks of Dolby Laboratories Licensing Corporation. DTS is a registered trademark of Digital Theater Syst
Product Height 3.187
Product Type 5.1 channel
Product Weight 10.6
Product Weight UOM pounds
Product Width 17.938
Recommended Amplifier Power 10-120W
Response Bandwidth 35Hz20kHz
Sensitivity 86 dB
Signal-To-Noise Ratio 100 dB
Size AAA
Speaker(s) Four satellite speakers (35W, 3/4" dome tweeter, dual 3" midrange) Center channel speaker (35W, 3/4" dome tweeter, dual 3" midrange) Subwoofer (200W,
Speakers Included 6 Speakers
Supported Languages English
Surround Sound Effects Dolby Digital, EX, Stereo, Surround, Logic II
System Components 6 Speakers
Technology IR
Total Harmonic Distortion 0.5 %
Type LCD and on-screen display
Video quality options Up to 720p upscaling
Voltage 1.5
Voltage UOM Volts
Harman Kardon HS 300 Integrated Home Theater System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: HS 300 Integrated Home Theater System
See all eBay results
  at eBay.com
Product Reviews
Last update: Dec 23, 2008
Harman Kardon HS 300 Integrated Home Theater System Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
HS 300 - alemon?
1.0
"This product is full of software bugs and glitches, such as:a) Clicks and pops when skipping from one track to next.b) Clicks and pops when audio/video format changesc) Upscaling resolution to 1080i doesn't work (blank screen)d) Only a very limited subset of DivX movie resolutions and FPS settings w …"  Read Full Review »
Was this Home Theater review on the Harman Kardon HS 300 Integrated Home Theater System helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jun 13 2008
Disapointed in Singapore
Singapore
I am:
  • Audiophile
HS300 5.1-CHAN HOME THEATER SYSTEM
4.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Surround Sound Solution
  • Television Shows
"The HS300 was easy to install, and the sound quality is excellent. "
Dec 23 2008
Missy
Texas
I am:
  • Practical
  • Technically Challenged
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
