Haier HL22F1 22-inch LCD TV
#140
5.0
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$219.00 - $439.99
from 15 stores
More Images
Pros
  • Attractive design (1)
  • Fast setup (1)
  • Good connection options (1)
  • Great picture quality (1)
  • High resolution (1)
  • Simple controls (1)
See less See more
Best Uses
  • Bedroom (1)
Provided by Overstock.com
*Manufacturer: Haier America *Manufacturer Part Number: HL22F1 *Manufacturer Website Address: www.haieramerica.com *Product Model: HL22F1 *Product Name: HL22F1 22" LCD TV *Product Type: LCD TV *Actual Screen Size: 22" *Compatible Technology: HDTV *Aspect Ratio: 16:9 *Horizontal Viewing Angle: 170°, 170 *Vertical Viewing Angle: 160, 160° *Maximum Response Time: 5ms *Features: Favorite Channel Selection *HDTV Tuner: Yes *Digital Tuner: ATSC *Analog Tuner: NTSC *Contrast Ratio: 800:1 *Maximum Resolution: 1366 x 768 *Brightness: 400 Nit *Comb Filter: 3D Y/C *Scan Format: 720p *Audio Decoding: Stereo *Sound System: Surround *Number of Speakers: 2 *Total Output Power: 3W *Ports: 1 x USB *Language Support: Spanish *Input Voltage: 110V AC *Color: White *Dimensions: 6.5" Height x 21" Width x 15.38" Depth *Weight: 9.75 lb *Package Contents: *HL22F1 22" LCD TV *Remote control *Batteries *User manual *Warranty card *Green Compliance: Yes *Green Compliance Certificate/Authority: Energy Star
Specification Description
Model 96F1A629, HL22F1
UPC 688057324401
16:9 Mode Yes
Audio Controls Bass, treble, balance, sound surround, equalizer, auto volume level
Battery Type Remote
Benefits 22" (diagonal) LCD display delivers great high-definition images in 1366x900 resolutionIntegrated ATSC/NTSC tuner for analog and over
Brightness 300 cd/m2
Capacity UOM mAh
Chemistry Alkaline
Closed Caption Capability Yes
Color Depth 16.7 million colors
Color Temperature Control Yes
Compliant Standards UL, CUL, FCC, FDA, Energy Star 3.0
Connections HDMI (1)VGA (1)Antenna (1)RCA composite video in (1)RCA component video in (1)RCA analog audio in
Controls / Adjustments Standard, vivid, mild, custom
Country Of Origin China
Description Header Put a home theater in your bedroom.
Display Catalog Number 55032408
Display Languages English, Spanish, French
Display Menu Language English, Spanish, French
Display Size 22 inches
Enclosure Color Black
End Product Indicator Yes
Humidity Range Operating 20%~80%
Image Aspect Ratio 16:9
Included in the Box Haier® HL22F1 22" Widescreen LCD HDTV with removable tilt standRemote control"AA" batteries (2)User's guide
Manufacturer Labor Warranty 90
Manufacturer Part Number HL22F1
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model HL22F1
Operating Temperature UOM ° F
Output Power / Total 3 watts
Parental controls Yes
Pixel Response Time 5 ms
Power Consumption Operational 60W
Product Depth 8.5
Product Dimensions UOM inches
Product Height 19.5
Product Type Flat-panel TVs
Product Weight 12
Product Weight UOM pounds
Product Width 22.75
Reception System NTSC/ATSC(8VSB, Clear QAM)
Screen Size Range 21-30"
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 1.5W + 1.5W
Speakers Included 2 Speakers
Supported Languages English
Technology IR
TV Diagonal Size 22 inches
TV Image Contrast Ratio 1000:1
TV Resolution 1366x900
TV Technology LCD
Type LCD
V-Chip Control Yes
Viewing Angle 170 Degrees
Viewing Angle (Vertical) 160 Degrees
Voltage 1.5
Voltage Required 120V AC ± 10%, 60Hz
Voltage UOM Volts
Widescreen Modes 1080i, 720p & below
Haier HL22F1 22-inch LCD TV Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 2, 2009
Haier HL22F1 22-inch LCD TV Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[9 of 9 customers found this review helpful]
Haier 22" tv
5.0
"Just got this tv in yesterday and very impressive picture.
was very easy to setup thanks to the first time wizard that runs on first startup. Color and picture was very sharp and I ran the audio through my home theater that was also very good.
all in all a great buy and You can't go wrong. "
Was this LCD TV review on the Haier HL22F1 22-inch LCD TV helpful to you?
 Report Abuse  (9)  (0)  0 comments
Oct 22 2009
stevenb1
Undisclosed
Reviewed at:
Price: $219.00
I would buy this TV again and again!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Bedroom
"I bought this product for my grand daughter and she loves it. "
Oct 2 2009
Parkay
Philadelphia
I am:
  • Casual User
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
