Haier 20" ATSC Color Tube Television - HTR20
#2
4.1
based on 14 reviews
Ratings Distribution
5 star
8
4 star
3
3 star
1
2 star
0
1 star
2
Category Average
3.9
$154.00 - $169.99
from 10 stores
More Images
Pros
  • Fast setup (11)
  • Simple controls (11)
  • Attractive design (10)
  • Great picture quality (9)
  • Clear picture (2)
  • Easy setup (2)
  • Great sound quality (2)
  • Durable (1)
  • For old tube tv excellent (1)
  • Good picture (1)
See less See more
Cons
  • Bad interface (1)
  • Heavy (1)
Best Uses
  • Home (10)
  • Movies (4)
  • Video (3)
  • Office (2)
  • Dorm room (1)
Provided by CompSource
20inch Crt Tv: 20inch Television Crt. Integrated Atsc/Ntsc - Qam Tuner. Display Capability 480i. Digital Comb Filter. Video Noise Reduction. V- Chip Parental Control. Trilingual On Screen Display. Sleep Timer. Multiple Picture Modes. Multiple Audio Modes. Full-Function Remote Control. Component / Av Inputs. A/V Outputs
Specification Description
Model HERHTR20, HTR20
UPC 688057322438
Age Teen,Adult
Battery Type Remote
Benefits Integrated NTSC/ATSC tuner delivers analog and over-the-air digital broadcasts (antenna required)V-Chip Parental Control so you can d
Capacity UOM mAh
Chemistry Alkaline
Closed Caption Capability Yes
Compliant Standards UL, CUL, FCC, FDA
Controls / Adjustments Standard, vivid, custom, mild
Country Of Origin China
Description Header The perfect TV for dorm or bedroom.
Display Catalog Number 55028649
Display Menu Language English, French, Spanish
Display Size 20 inches
Enclosure Color OFF White
End Product Indicator Yes
Gender Either
Image Aspect Ratio 4:3
Included in the Box Haier HTR20 20" CRT TVRemote control"AA" alkaline batteries (2)User's guide
Inputs 1 x "F" Plug(Antenna in), 1 x RCA(Video), 2 x RCA(Audio in), 1 x Component(YPbPr), 1 x S-Video
Interest Home Entertainment
Manufacturer Labor Warranty 90
Manufacturer Part Number HTR20
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model HTR20
Operating Temperature UOM ° F
Output Power / Total 4 watts
Outputs 1 x RCA(Audio out)
Parental controls Yes
Product Depth 19.41
Product Dimensions UOM inches
Product Height 18.82
Product Type Flat-panel TVs
Product Weight 45
Product Weight UOM pounds
Product Width 20.71
Reception System ATSC/NTSC
Recipient Mom,Dad,Daughter,Son,Significant Other,Myself
Screen Size Range 10-20"
Secondary Audio Program (SAP) Yes
Size AA
Sound Output Mode Stereo
Speaker(s) Built-in, 2W+2W
Supported Languages English
Technology IR
TV Channel Qty 181 Channels
TV Diagonal Size 20 inches
TV Technology CRT
Type CRT
V-Chip Control Yes
Voltage Required 120V AC +/- 10%, 60Hz +/- 0.5%
Web Availability ONLINE ONLY
Haier 20" ATSC Color Tube Television - HTR20 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 2, 2009
Haier 20" ATSC Color Tube Television - HTR20 Reviews
Most helpful positive review
Most helpful negative review
[3 of 6 customers found this review helpful]
5.0
Great for anyone who hates LCD screens
"I don't have cable and needed to transition to digital. I tried and returned two LCD TVs. One of them actually blinded me for 10 minutes! No stores I visited even mentioned that new CRT (cathode ray tube) TVs exist that are ready for the digital transition. I found this TV through an Internet search and love it. Great picture, with no harsh effects of looking at an LCD screen. Plus the CRT TV costs a third of ..." Read Full Review »
May 28, 2009 by CRT Enthusiast
See more positive Haier 20" ATSC Color Tube Television - HTR20 reviews
1.0
This tv sucks!!
"I bought this tv in September 2008. It is the beginning of January and it no longer turns on. It is just over the 90 day warranty, so I am out of luck!! I have read similar reviews(now) on other web sites. The picture was decent, but the time to turn on and change channels was sloooooowwww! Didn't bother me to bad for I thought it was a decent tv! Go with name brand!..." Read Full Review »
Jan 03, 2009 by jkb
See more negative Haier 20" ATSC Color Tube Television - HTR20 reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • Heavy
    Best Uses
  • Home
  • Movies
  • Video
"I don't have cable and needed to transition to digital. I tried and returned two LCD TVs. One of them actually blinded me for 10 minutes! No stores I visited even mentioned that new CRT (cathode ray tube) TVs exist that are ready for the digital transition. I found this TV through an Internet searc …"  Read Full Review »
Was this Standard TV review on the Haier 20" ATSC Color Tube Television - HTR20 helpful to you?
May 28 2009
CRT Enthusiast
Pittsburgh, PA
I am:
  • Casual User
Reviewed at:
Works great
4.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
  • Movies
"For a low priced tube TV, this one was a good deal. I wasn't looking for anything high end, just a plain ol' TV. This one does the job. The picture looks good, easy to set up, plenty of inputs. It has the cable input, RGB inputs and audio/video inputs and outputs on the back, and another set …"  Read Full Review »
May 7 2008
rphilla
Philadelphia, PA
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $154.00
This tv sucks!!
1.0
    Pros
  • Clear Audio
  • Clear Picture
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"I bought this tv in September 2008. It is the beginning of January and it no longer turns on. It is just over the 90 day warranty, so I am out of luck!! I have read similar reviews(now) on other web sites. The picture was decent, but the time to turn on and change channels was sloooooowwww! Didn't b …"  Read Full Review »
 Report Abuse  (3)  (3)  0 comments
Jan 3 2009
jkb
oklahoma
Reviewed at:
Price: $169.99
What a great value!
5.0
    Pros
  • Attractive Design
  • Fast Setup
  • Great Picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I purchased this unit for my 73 yr old. father - and I needed easy controls and set up as I was not going to be there to help. It was set up and running in less than 30 minutes and Dad is VERY pleased. The easy of use and great picture meant the world to me. "
Apr 21 2009
Sul
Mt. Prospect, IL
I am:
  • Enthusiast
Reviewed at:
Price: $154.00
Fits my needs
3.0
    Pros
  • Fast Setup
  • Good picture
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
"I am a senior citizen. My children bought me this set. I've only had the set for 3 weeks but it was easy to set up, the picture is clear, the sound is fine, and the controls are easy to follow. I use the set in my bedroom and have no complaints. "
Jan 2 2008
Ziggy
New Jersey
I am:
  • Technically Challenged
Reviewed at:
Price: $154.00
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
