Griffin iTrip Auto FM Transmitter and Car Charger for iPod
#75
3.3
based on 74 reviews
Ratings Distribution
5 star
21
4 star
31
3 star
10
2 star
13
1 star
18
Category Average
3.4
Low Price:
$35.88 at J&R Electronics
 Trusted:
$36.95 at B&H Photo Video
Find it at Amazon
$35.88 - $54.99
from 14 stores
More Images
Pros
  • Lightweight (29)
  • Good interface (22)
  • Reliable reception (14)
  • Well built / quality construction (8)
  • Accurate scanning (5)
  • Easy to use (5)
  • Easy setup (4)
  • Good value (3)
  • Adds functionality (2)
  • Good performance (2)
See less See more
Cons
  • Poor reception (10)
  • Flimsy (2)
  • A lot of background noise (1)
  • Auto turn off switch (1)
  • Doesn't lock (1)
  • Little static (1)
  • No shuffle adapter (1)
  • Over priced for what does (1)
  • Poor interface (1)
  • Still hard to find a free (1)
Best Uses
  • Car (28)
  • Travel (10)
  • Daily usage (2)
  • Car radio w/o an input (1)
  • Office (1)
Provided by Staples
Griffin brings exclusive SmartScan technology to its precedent-setting iTrip FM Transmitter/charger. Griffin-exclusive SmartScan automatically finds the clearest frequencies wherever you are, making setup and operation as easy as two button presses (one for your iTrip, and one for your radio). Designed specifically for use in the car, iTrip Auto's large, easy-to-read backlit LCD screen affords quick status at a glance Plugs into the dock connector of your iPod and automatically optimizes output volume Control speaker volume from your car stereo controls; you won't have to touch your iPod to adjust the volume level Selectable stereo and mono modes for best-quality audio under real-world conditions Set it up and start using with a single button click.
Specification Description
Model 10273676, 9501-TRIPC, 9501-TRIPCBL, 9501-TRIPCBL refurbished
UPC 085387995019
color null
Select Accessory Cables & Adapters
size null
sku 153588
skuprice 69.9900
style 9501TRIPCBL
taxable Y
Griffin iTrip Auto FM Transmitter and Car Charger for iPod Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
Griffin iTrip Auto FM Transmitter and Car Charger for iPod Reviews
Most helpful positive review
Most helpful negative review
4.0
Happy with purchase
"I usually listen to music while driving, so I knew I'd want an FM transmitter for my new iPod. I read that the best results come from cassette tape adapters and direct connection (on newer cars). As I had neither, my only option was an FM transmitter. FM transmitters only work when set to an empty station--quite hard to find in as radio-rich a place as the tri-state region. You'll need a little patience, and..." Read Full Review »
Dec 01, 2007 by CF
See more positive Griffin iTrip Auto FM Transmitter and Car Charger for iPod reviews
3.0
Pretty Good...
"I use this for an older ipod as well as for an iphone 3G. A common question I came across when researching products like this online was "will this work with an iphone"? Yes, it will. However, be aware that the phone will ask if you want it to go into "Airplane Mode". Selecting "no" will allow it to play mp3s as well as stream media from popular apps but phone ringtones, text tones and anything else that nor..." Read Full Review »
Jul 27, 2009 by Jacob
See more negative Griffin iTrip Auto FM Transmitter and Car Charger for iPod reviews
Displaying 1 - 5 of 74 Reviews
Show
Sort by
Great Overall
4.0
    Pros
  • Accurate Scanning
  • Good interface
  • Lightweight
  • Strong Construction
    Cons
  • Poor Reception
    Best Uses
  • Car
"I use this with my 4th gen nano and it works great. It is very easy to use and no hassle to learn how to use. It is hard to find a clear signal but I do live in the city so I was expecting this. But the auto search makes it easy to switch between stations. "
Was this MP3 Player / iPod Radio Transmitter review on the Griffin iTrip Auto FM Transmitter and Car Charger for iPod helpful to you?
Nov 11 2009
Toocooldg
Charlotte, NC
I am:
  • Gear Head
  • Student
Reviewed at:
Price: $36.95
Pretty Good...
3.0
    Pros
  • Easy to use
  • Good interface
    Cons
  • Volume Fade
    Best Uses
  • Car
"I use this for an older ipod as well as for an iphone 3G. A common question I came across when researching products like this online was "will this work with an iphone"? Yes, it will. However, be aware that the phone will ask if you want it to go into "Airplane Mode". Selecting "no" will allow i …"  Read Full Review »
Jul 27 2009
Jacob
Elkhart, IN
I am:
  • Former Club DJ
  • Music Junkie
Reviewed at:
Price: $36.95
Happy with purchase
4.0
    Pros
  • Adds Functionality
  • Easy to Set Up
  • Lightweight
    Cons
  • None
    Best Uses
  • Daily Usage
"I usually listen to music while driving, so I knew I'd want an FM transmitter for my new iPod. I read that the best results come from cassette tape adapters and direct connection (on newer cars). As I had neither, my only option was an FM transmitter. FM transmitters only work when set to an empt …"  Read Full Review »
Dec 1 2007
CF
Brookhaven, NY
I am:
  • Casual User
Sound quality was not good
1.0
    Pros
  • Good interface
  • Lightweight
    Cons
  • Poor Reception
    Best Uses
  • Car
"After reading several positive reviews I thougt this would be the best device for me. Unfortunately the reception was really bad. The smart scan option would select station that was clear but the sound quality of my iPhone was poor. No bass, and it sounded muffled. I also have Sirius radio in my car …"  Read Full Review »
Jan 29 2009
iPhone 3g
Boston
I am:
  • Audiophile
  • Frequent Traveler
Reviewed at:
Price: $36.95
Excellent Choice
5.0
    Pros
  • Good interface
  • Lightweight
  • Reliable Reception
    Cons
  • No Shuffle Adapter
    Best Uses
  • Car
  • Travel
"I've tried other brand transmitters, and returned them all. Living in NYC where there are few available FM frequencies, I reluctantly purchased the iTrip as a last resort and was plesantly surprised. It is a no brainer to set up, in one minute it completed the scan and I was listening to my iPod i …"  Read Full Review »
Jun 22 2009
KEN
NYC
I am:
  • Frequent Traveler
  • Technically Challenged
Reviewed at:
Price: $36.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
