Grace Digital Audio Grace Schooners Weatherproof Wireless Speakers
#912
3.9
based on 10 reviews
Ratings Distribution
5 star
4
4 star
3
3 star
2
2 star
0
1 star
1
Category Average
4.4
Low Price:
$175.99 at ClubMac
 Trusted:
$195.99 at MacMall
$183.84 at pcRUSH
see all stores
$175.99 - $209.00
from 4 stores
More Images
Pros
  • Great sound quality (8)
  • Attractive design (4)
  • Easy to connect (4)
  • Powerful (3)
See less See more
Cons
  • Poor sound quality (2)
  • Mediocre sound (1)
  • Remote unreliable (1)
  • Some static (1)
  • Speaker signal trouble (1)
  • Volume default (1)
Best Uses
  • Outdoors (4)
  • Basic systems (2)
  • Smaller rooms / apartments (2)
Provided by MAGo Enterprise
Schooner Outdoor Wireless Speakers with Transmitter - Schooner Outdoor Wireless Speakers. Includes: 2 x Weatherproof Wireless stereo speakers (each speaker contains 1 X 4 main & 1 x 1.5 tweeter); 1 x Wireless transmitter for iPod/MP3/Stereo/TV; and 1 x Wireless remote control. Audio in 3.5mm jack on transmitter. DC in jack on speaker. Auto on/off on transmitter. 900 MHz analog. Up to 300 foot outside range. Up to 7 hours battery life (depending on volume). Controls on each speaker: volume bass-boost tune and power. Speakers comply to International Weather Proofing Standards. Each speaker power source: 8 x AA batteries or included UL AC wall plug; 7.5 Watts/ch transmiter using included AC power adaptor or 4 +AA batteries not included.
Specification Description
Model SCN300W
UPC 089315300302
Benefits 3.5mm stereo input connects with most stereo systems, MP3 players, CD players, computers and TVsSpeakers comply to international weat
Cables Included RCA audio cable
Capacity UOM mAh
Connectivity technology Wireless
Country Of Origin China
Description Header Unleash your tunes, indoors or out.
Display Catalog Number 55028738
End Product Indicator Yes
Frequency response 50Hz-20KHz
Included in the Box RF transmiterRF speakers (2)AC adapter for transmitterAC adapters for speaker (2)Remote control3.
Manufacturer Labor Warranty 90
Manufacturer Part Number SCN300W
Manufacturer Parts Warranty 90
MAP Price 0.0
Midrange size 4 inches
Model SCN300W
Operating Temperature UOM ° F
Peak power 10 watts
Power Device AC adapter
Product Depth 6.25
Product Dimensions UOM inches
Product Height 8.5
Product Type Home speakers
Product Weight 8.95
Product Weight UOM pounds
Product Width 5.75
Remote Control Features Operating distance up to 150 feet
Sensitivity 65 dB
Speaker type Wireless
Speakers included 2
Supported Languages English
Tweeter size 1.5 inches
Water resistant Yes
Grace Digital Audio Grace Schooners Weatherproof Wireless Speakers Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 18, 2009
Grace Digital Audio Grace Schooners Weatherproof Wireless Speakers Reviews
Most helpful positive review
Most helpful negative review
4.0
As advertised
"I installed speakers on a screened in porch about 35 feet from the amp. Generally work well with better than adequate sound quality. However, the signal is relatively easily interrupted, making for spotty sound. Can be a bit irritating. Overall, however, it gets the job done and meets the need - without having to rewire the house...." Read Full Review »
May 21, 2009 by Jack
See more positive Grace Digital Audio Grace Schooners Weatherproof Wireless Speakers reviews
3.0
Mixed review
"I use these speakers upstairs from the transmitter. There is very little problem with setting up, connecting, or operation. They are adequate for my needs. But the bass sound is nonexistent, and the "bass boost" button on the speakers does absolutely nothing. When the speaker is first turned on, the volume is extremely loud and I have to be ready to pounce on the button to lower it. The remote works great for ad..." Read Full Review »
Feb 20, 2009 by Pinkie
See more negative Grace Digital Audio Grace Schooners Weatherproof Wireless Speakers reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Mixed review
3.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
    Cons
  • Mediocre sound
  • Remote unreliable
  • Volume default
    Best Uses
  • Smaller Rooms
"I use these speakers upstairs from the transmitter. There is very little problem with setting up, connecting, or operation. They are adequate for my needs. But the bass sound is nonexistent, and the "bass boost" button on the speakers does absolutely nothing. When the speaker is first turned on, the …"  Read Full Review »
Was this Speaker & Subwoofer review on the Grace Digital Audio Grace Schooners Weatherproof Wireless Speakers helpful to you?
Feb 20 2009
Pinkie
Grand Blanc, MI
I am:
  • Musically Inclined
  • Practical
  • Tech Savvy
Reviewed at:
Powerful, but sound quality is not good
1.0
    Pros
  • Powerful
    Cons
  • Distorted Sound
  • Poor Sound Quality
    Best Uses
  • Outdoors
"I bought this to use primarily for an indoor space that would be hard to reach with stereo wiring. I planned to occasionally use them outside. While the speakers were very powerful, they sounded awful. The power button will not turn them on unless the speaker detects a signal. Even in same positi …"  Read Full Review »
May 29 2009
KG
Minneapolis
I am:
  • Practical
Reviewed at:
As advertised
4.0
    Pros
  • Easy To Connect
  • Good Sound Quality
    Cons
  • Some static
    Best Uses
  • Basic Systems
  • Outdoors
"I installed speakers on a screened in porch about 35 feet from the amp. Generally work well with better than adequate sound quality. However, the signal is relatively easily interrupted, making for spotty sound. Can be a bit irritating. Overall, however, it gets the job done and meets the need - …"  Read Full Review »
May 21 2009
Jack
North Carolina
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Easy to use.
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Outdoors
"My husband and I connected this product to our television, turned on a musics station and hooked up the speakers outdoors for a barbeque. It was nice to have background music at our Labor Day party. "
Sep 18 2009
Taraneh Tuckey
Middletown, Maryland
I am:
  • Practical
  • Technically Challenged
Reviewed at:
Where's the signal??
3.0
    Pros
  • Attractive Design
  • Crisp Sound
    Cons
    Best Uses
  • Outdoors
  • Smaller Rooms
"Speakers are attractive, They work well when they connect to signal, but one speaker has a terrible time finding signal... must turn on and off 25 times before it finally connects to wireless signal. "
Feb 28 2009
Tom
VA
I am:
  • Practical
  • Tech Savvy
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
