GPX ® HI2817 CD Shelf System with Dock for iPod®
3.2
based on 26 reviews
Ratings Distribution
5 star
10
4 star
4
3 star
1
2 star
3
1 star
8
Category Average
4.1
More Images
Pros
  • Easy setup (17)
  • Great sound quality (11)
  • Attractive design (7)
  • Simple / intuitive controls (5)
  • Confusing / difficult controls (4)
  • Thundering bass (4)
  • Interfaces well with tv (3)
  • Powerful (2)
  • Cd sound decent (1)
  • Cheap not a rip-off (1)
See less See more
Cons
  • Poor sound quality (6)
  • Awful radio (1)
  • Buzzing sound alot (1)
  • Cd skipping (1)
  • Difficult to set up (1)
  • Inflexible cd (1)
  • Lack of power (1)
  • No radio programming (1)
  • Poor interface (1)
  • Sound isnt great (1)
Best Uses
  • Smaller rooms / apartments (11)
  • Basic use (3)
  • Large rooms (2)
  • Living room (2)
  • Office (2)
  • Bedroom (1)
  • Movies (1)
  • None sending back (1)
  • Surround sound solution (1)
Provided by Kmart
Top-load CD player plays CD, CD-R/RW Digital display AM/FM radio Backlit LCD display with clock Digital volume control Preset EQ Line-in jack to connect other audio players Aux-in RCA x 2 jacks Audio/video output jacks, headphone jack Subwoofer line-out jack Remote controls volume, EQ, CD player and iPod, mini, nano, Photo and Video players (remote battery included) Wood stereo speakers Center Section Dimensions: 6"L x 8.5"W x 7.25"H Speaker Dimensions: 6"L x 7.25"W x 9"H
Specification Description
Model GPXHI2817, HI2817
UPC 047323228179
Alarm Yes
AM/FM Radio Yes
Battery Type Remote
Benefits Use the built-in alarm to wake up to your iPod, CD, AM/FM Radio or buzzerBacklit LCD Display with Clock Digital Volume Control
Built-in Clock Yes
Capacity UOM mAh
Channels 2 Channels
Chemistry Lithium
Country Of Origin China
Description Header Share your tunes with the world
Display Catalog Number 13-126
Enclosure Color Black
End Product Indicator Yes
Equalizer Yes
Included in the Box GPX HI2817 main unit with iPod dockSpeakers (2)Remote with CR2125 lithium batteryUser's guide
Inputs 1 x Phone 1/8"(Aux in), 1 x Phone 1/8"(FM antenna), 1 x RCA(Aux in)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model HI2817
New Date Sun Oct 19 00:00:00 CDT 2008
Operating Temperature UOM ° F
Output Power / Total 2 watts
Outputs 1 x Phone 1/8"(Headphones), 2 x RCA(Speaker)
Product Depth 5.98
Product Dimensions UOM inches
Product Height 7.24
Product Type Single disc
Product Weight 3.85
Product Weight UOM pounds
Product Width 8.58
Size Coin Cell
Supported Languages English
Technology IR
Type LCD
Voltage 3
Voltage UOM Volts
GPX ® HI2817 CD Shelf System with Dock for iPod® Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: ® HI2817 CD Shelf System with Dock for iPod®
See all eBay results
  at eBay.com
Product Reviews
Last update: May 12, 2009
GPX ® HI2817 CD Shelf System with Dock for iPod® Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
It's great! Don't listen to them!!
"Don't listen to them! This product is great! The only con is that you can't program your favorite radio stations and that you can't tune the radio from the remote. It might have broke for that guy, but it works just fine for me. The sound is great. So is the CD Player. Even the alarm. I use it in my room when I'm bored, or going to sleep. I even use it as my main iPod charging station. I love it. I would definit..." Read Full Review »
Dec 03, 2008 by NASAmir96
See more positive GPX ® HI2817 CD Shelf System with Dock for iPod® reviews
2.0
All show, No go
"I bought this product for christmas but read some reviews on it at other sites and decided to test it out first. Plugging in was easy. It fits well with my older ipod. I turned on the music and was surprised to hear the sound quality not as bad as some of the reviews had said. Stepping out of the room for a moment I came back in to a room full of noise. It sounded great when I was right in front of it, but stand..." Read Full Review »
Nov 28, 2008 by Smith
See more negative GPX ® HI2817 CD Shelf System with Dock for iPod® reviews
Displaying 1 - 5 of 26 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • Powerful
    Cons
  • No Radio Programming
    Best Uses
  • Basic Use
  • Bedroom
  • Larger Rooms
  • LIVING ROOM
  • Offices
  • More »
"Don't listen to them! This product is great! The only con is that you can't program your favorite radio stations and that you can't tune the radio from the remote. It might have broke for that guy, but it works just fine for me. The sound is great. So is the CD Player. Even the alarm. I use it in my …"  Read Full Review »
Was this Home Theater review on the GPX ® HI2817 CD Shelf System with Dock for iPod® helpful to you?
 Report Abuse  (1)  (0)  0 comments
Dec 3 2008
NASAmir96
San Antonio, Texas
I am:
  • Musically Inclined
  • Tech Savvy
All show, No go
2.0
    Pros
  • Attractive Design
  • Easy To Set Up
    Cons
  • Not Very Powerful
  • Poor Sound
    Best Uses
  • Basic Use
"I bought this product for christmas but read some reviews on it at other sites and decided to test it out first. Plugging in was easy. It fits well with my older ipod. I turned on the music and was surprised to hear the sound quality not as bad as some of the reviews had said. Stepping out of the ro …"  Read Full Review »
Nov 28 2008
Smith
Seattle, Washington
I am:
  • Practical
Better deals elsewhere
2.0
    Pros
  • CD sound decent
  • Sounds good with iPod
    Cons
  • Awful radio
  • Inflexible CD
    Best Uses
  • Basic Use
  • Smaller Rooms
"Works as a docking station or basic CD player, but that is it. It that is what you want, this might work. The sound when docked is decent.
Radio is a major problem. It is an analog, dial tuner with a digital display. Hence, no presets. Sorry, but what year is this? It is terrible.
CD will not …"  Read Full Review »
Dec 25 2008
Peter North
Pornvalley, CA
I am:
  • Audiophile
  • Tech Savvy
[0 of 1 customers found this review helpful]
Awsome
5.0
    Pros
  • Attractive Design
  • Clear sound
  • Compact
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • None
"I love love love this it is awsome because you can put any kind of iPod into the dock.Also for me it works great because when I'm in my room I just put the iPod in the dock and find the song and it plays nice and clear. For me it is also good because I have 4 iPods and what ever one I have with me I …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Apr 1 2008
Miley Cyrus
California
[3 of 3 customers found this review helpful]
You can make love songs with this one!
5.0
    Pros
  • Attractive Design
  • Easy Controls
  • Easy To Set Up
  • Great Sound
  • More »
    Cons
  • None
    Best Uses
  • None
"This radio has alot of good things for a GOOD price if i were you i'd hurry up and get one before there gone "
 Report Abuse  (3)  (0)  0 comments
Aug 5 2008
Linds-a-relli aka LEM
Baltimore
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
