Gigaware Wrap-Around USB Headset/Microphone-Skype/VOIP
#313
3.7
based on 39 reviews
from $26.99
Ratings Distribution
5 star
15
4 star
12
3 star
3
2 star
2
1 star
7
Category Average
4.0
$26.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Great sound quality (27)
  • Easy to use (25)
  • Quality microphone (25)
  • Comfortable (20)
  • Lightweight (12)
  • Added features (2)
  • Durable (2)
  • Good value (2)
  • High quality (2)
  • Needs to be recalled (1)
See less See more
Cons
  • Uncomfortable (9)
  • Poor microphone (7)
  • Bulky design (3)
  • Difficult to use (3)
  • Poor sound quality (2)
  • Hard to open (1)
  • Hurts your ears (1)
  • Manual is short (1)
  • No sound at all (1)
  • Not the best 4 music (1)
Best Uses
  • Typing & talking (20)
  • Mobility (7)
  • Relieving neck pain (6)
  • Skype (3)
  • Chewing on (1)
  • Don't bother with it (1)
  • Gaming (1)
  • Listening to music (1)
  • Long distance on skype (1)
  • Online play (1)
Provided by RadioShack
Versatile headset provides great clarity and the design is ideal for VOIP calling.
Specification Description
Model 43-203
Benefits Compatible with Windows 98SE, ME, 2000 and XPOmni-directional microphone ensures clear communicationVersatile stereo headset
Capacity UOM mAh
Country Of Origin China
Description Header Why just e-mail when you can chat?
Display Catalog Number 43-203
End Product Indicator Yes
Included in the Box USB headsetSkype software CD
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 43-203
New Date Mon Jan 07 00:00:00 CST 2008
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 2.5
Product Length 7
Product Type Headsets
Product Weight 0.2
Product Weight UOM pounds
Product Width 6.5
Recommended Use VoIP/Skype applications
Supported Languages English
Gigaware Wrap-Around USB Headset/Microphone-Skype/VOIP Questions
Questions and Answers
Where to Buy
$26.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 8, 2009
Gigaware Wrap-Around USB Headset/Microphone-Skype/VOIP Reviews
Most helpful positive review
[10 of 10 customers found this review helpful]
Most helpful negative review
5.0
great headset, just love it
"Got this headset from R.S. last week. Price was great. I needed a good headset to use on lowratevoip so i can call my fiance in Africa. Installation was easy, its plug and play. I had a problem using it in the beginning. After talking for about 10 minutes, it will automaticly mute on me, i tried to unmute it but nothing happened. Then i will have to unplug it and call back. I took it back to R.S. and exchange..." Read Full Review »
May 03, 2008 by ADYMASS
See more positive Gigaware Wrap-Around USB Headset/Microphone-Skype/VOIP reviews
1.0
Horrible. Stopped working after a month.
"I got this microphone a few months ago to use on Ventrilo for online RPGs. You would think for [$] it would be a decent microphone. It worked well in the beginning, but eventually the microphone slowly started dying out. Friends in-game said I sounded like I was in a wind tunnel or a tornado was at my house. Just a few more cons. The "wrap-around" design hurts your ears only after an hour or two of wear. The mut..." Read Full Review »
Nov 08, 2009 by Mal
See more negative Gigaware Wrap-Around USB Headset/Microphone-Skype/VOIP reviews
Displaying 1 - 5 of 39 Reviews
Show
Sort by
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Great Sound Quality
  • Quality Microphone
    Cons
  • None
    Best Uses
  • None
I had a problem using it in the beginning. After talking for about 10 minutes, it will automaticly mute on me, i tried …"  Read Full Review »
Was this Computer Speaker & Headphones review on the Gigaware Wrap-Around USB Headset/Microphone-Skype/VOIP helpful to you?
 Report Abuse  (10)  (0)  0 comments
May 3 2008
ADYMASS
Virginia
Reviewed at:
Price: $26.99
1.0
    Pros
  • Easy To Use
    Cons
  • Poor Microphone
  • Poor Sound Quality
  • Uncomfortable
    Best Uses
"I got this microphone a few months ago to use on Ventrilo for online RPGs. You would think for [$] it would be a decent microphone. It worked well in the beginning, but eventually the microphone slowly started dying out. Friends in-game said I sounded like I was in a wind tunnel or a tornado was at …"  Read Full Review »
Nov 8 2009
Mal
I am:
  • Value Oriented
Reviewed at:
Price: $26.99
[4 of 4 customers found this review helpful]
Great sound, but uncomfortable
3.0
    Pros
  • Easy To Use
    Cons
  • Bulky Design
  • Uncomfortable
    Best Uses
  • Skype
"I bought the product to use with Skype and you just plug it in to the computer and go. The sound quality is great, as all my friends said I sound clear and understandable... better than the cell phone.
However, the headset rests on your ears. The part that wraps around your head is not adjustab …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Apr 3 2008
Average Joe tech user
Cincinnati, OH
I am:
  • Quality Oriented
Reviewed at:
Price: $26.99
[1 of 1 customers found this review helpful]
Great headset, definitely worth it!
5.0
    Pros
  • Comfortable
  • Easy To Use
    Cons
  • None
    Best Uses
  • Typing & Talking
"This thing is awesome. It's simple to use (I just plugged it in and Vista started detecting it right away!). There's a green light that means it's plugged in and speakers are working, the flashing green means you're using your mic and all for a call in skype, and an orange one that means you're mu …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Nov 4 2009
Eskimo Penguins
Huntington Beach, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $26.99
Not worth it even at 15.00.
1.0
    Pros
  • Compact Design
  • Easy To Use
    Cons
  • Poor Microphone
  • Uncomfortable
    Best Uses
  • Typing & Talking
"I've gone through 3 of these headsets and I ONLY used it to talk through SKYPE and listen to music. I didn't abuse it whatsoever. As a matter of fact, I've been pretty cautious in taking care of it yet each one that I've owned managed to break within a two - three month period.
1st headset, the …"  Read Full Review »
Sep 6 2009
Taylor
Centreville, VA
I am:
  • Quality Oriented
Reviewed at:
Price: $26.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
