Gigaware ® Wireless Optical Mouse
#363
2.5
based on 78 reviews
Ratings Distribution
5 star
21
4 star
8
3 star
3
2 star
1
1 star
45
Category Average
4.3
$19.99 at RadioShack
Find it at Amazon
Find it at Ebay
$19.99
from 1 store
More Images
Pros
  • Comfortable design (41)
  • Glides smoothly (35)
  • Fast response (29)
  • Accurate tracking (28)
  • Works on any surface (23)
  • Great features (18)
  • Good battery life (2)
  • A decent projectile (1)
  • Battery life is good 4 me (1)
  • Comfort design good (1)
See less See more
Cons
  • Inaccurate tracking (12)
  • Slow response (10)
  • Catches easily (6)
  • Inadequate features (5)
  • Limited surface compatibility (5)
  • Uncomfortable design (3)
  • Doesn't work (2)
  • Doesn't work at all (2)
  • Incompatible with vista (2)
Best Uses
  • Web browsing (31)
  • Travel (27)
  • Professional (21)
  • Gaming (16)
  • Graphic design (10)
  • Everyday (8)
  • Paper weight (3)
  • All day work (1)
  • As a weapon (1)
  • Crushing under foot (1)
Provided by RadioShack
Mac and PC compatible wireless optical mouse.
Specification Description
Model 26-339, N530
Battery Type Charger
Benefits Mac and PC compatible via USBCompact wireless dessign with hideaway USB great for travelAmbidextrous mini-optical mouse, 100
Capacity UOM mAh
Chemistry Lithium
Country Of Origin China
Description Header Help stamp out cluttered desk syndrome!
Display Catalog Number 26-284
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model N530
New Date Mon Jun 18 00:00:00 CDT 2007
Operating Temperature UOM ° F
Product Type Wireless
Required to function SKU 2301304
Size AAA
Supported Languages English
Voltage 1.5
Gigaware ® Wireless Optical Mouse Questions
Questions and Answers
Where to Buy
$19.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 11, 2009
Gigaware ® Wireless Optical Mouse Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Works Great, Even on Vista!
"I use this mouse all the time. On the go and when at home surfing the net or playing games! It has a VERY long battery life when compared to most other units that I have tried recently. Unlike many reviews, this unit IS Vista compatible (especially when you wait for the computer to auto-install the device), it doesn't have any lag that I've been able to notice, and is small enough to go anywhere [I've even mi..." Read Full Review »
Mar 11, 2008 by Stefani
See more positive Gigaware ® Wireless Optical Mouse reviews
3.0
Good mouse.
"Very nice mouse. It's small enough to fit comfortably in my hand without being too small, and works with the usb reciever better than my old mouse. The only complaint I would have is that the stand-by comes on a little too quickly. It feels almost like I have to have the mouse moving all the time, or it'll shut off. Very annoying if you're watching something on the computer. Other than that, it's a better m..." Read Full Review »
Jan 22, 2008 by Sere
See more negative Gigaware ® Wireless Optical Mouse reviews
Displaying 1 - 5 of 78 Reviews
Show
Sort by
5.0
    Pros
  • Accurate Tracking
  • Comfortable Design
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Gaming
  • Graphic Design
  • Professional
  • Traveling
  • Web Browsing
"I use this mouse all the time. On the go and when at home surfing the net or playing games! It has a VERY long battery life when compared to most other units that I have tried recently. Unlike many reviews, this unit IS Vista compatible (especially when you wait for the computer to auto-install t …"  Read Full Review »
Was this Computer Mice review on the Gigaware ® Wireless Optical Mouse helpful to you?
 Report Abuse  (1)  (0)  0 comments
Mar 11 2008
Stefani
Alabama
I am:
  • Power user
Reviewed at:
Price: $19.99
Garbage item
1.0
    Pros
  • None
    Cons
  • Inaccurate Tracking
    Best Uses
  • None
"I can not begin to tell you how violently angry this mouse has made me.
My last mouse broke over years of use, so I decided to replace it with this sack of stuff.
It worked great, "FOR A DAY", and then the scroll wheel just went nuts, it bounces all over the place.
I now need to get another …"  Read Full Review »
Oct 30 2009
Storm
Ny
I am:
  • Power user
Reviewed at:
Price: $19.99
This mouse is the best!!!
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
    Cons
  • None
    Best Uses
  • Everyday Use
  • Professional
  • Traveling
  • Web Browsing
"This mouse is the best!! It has a nice look and it is so small you can put it in your pocket. The scroll button is made of all rubber so it has a nice feel to it. Another great thing about this mouse is how the usb drive goes into the mouse so you don't loose it. Great product! P.S. i know that some …"  Read Full Review »
Jun 14 2009
Kyle
Sparta NJ
I am:
  • Power user
Reviewed at:
Price: $19.99
Love the Mouse
4.0
    Pros
  • Fast Response
  • Glides Smoothly
    Cons
  • None
    Best Uses
  • Everyday Use
"Love this mouse especially the size is perfect for my small hand. It is so very comfortable and stands up to traveling very well. Would only use this type of mouse. "
Nov 11 2009
VCH Consultant
Southampton, NY
I am:
  • Power user
Reviewed at:
Price: $19.99
Good mouse.
3.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Works On Any Surface
    Cons
  • None
    Best Uses
  • Gaming
  • Web Browsing
"Very nice mouse. It's small enough to fit comfortably in my hand without being too small, and works with the usb reciever better than my old mouse. The only complaint I would have is that the stand-by comes on a little too quickly. It feels almost like I have to have the mouse moving all the time …"  Read Full Review »
Jan 22 2008
Sere
Tulsa, OK
I am:
  • Power user
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
