Gigaware Wireless Optical Mouse
#354
2.5
based on 11 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
4
2 star
1
1 star
4
Category Average
4.3
$18.99 at RadioShack
Find it at Amazon
Find it at Ebay
$18.99
from 1 store
Pros
  • Comfortable design (4)
  • Fast response (4)
  • Great features (4)
  • Accurate tracking (3)
  • Glides smoothly (3)
  • Great for editing photos (1)
  • Works on any surface (1)
See less See more
Cons
  • Limited surface compatibility (3)
  • Slow response (3)
  • Inaccurate tracking (2)
  • Poor battery life (2)
  • Catches easily (1)
  • Last less than two months (1)
  • No driver (1)
  • Uncomfortable design (1)
Best Uses
  • Everyday (4)
  • Web browsing (3)
  • Gaming (2)
  • Professional (2)
  • Designing (1)
  • Drawing (1)
  • Photo editing (1)
  • Travel (1)
Provided by RadioShack
Experience the freedom a wireless mouse offers with this Gigaware model
Specification Description
Model 26-1145
Accessory Indicator Yes
Benefits Reduces desktop clutter by eliminating the cable and its restrictions on movementHas an ergonomic design for more comfort and maneuve
Capacity UOM mAh
Country Of Origin China
Description Header Don't keep your mouse on a leash!
Display Catalog Number 26-1145
Enclosure Color Black/Silver
Included in the Box Wireless mouseReceiver
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 26-1145
New Date Tue Apr 28 00:00:00 CDT 2009
Operating Temperature UOM ° F
Product Depth 1.38
Product Dimensions UOM inches
Product Height 4.65
Product Type Wireless
Product Weight 3.2
Product Weight UOM ounces
Product Width 2.6
Supported Languages English
Gigaware Wireless Optical Mouse Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 1, 2009
Gigaware Wireless Optical Mouse Reviews
Most helpful positive review
Most helpful negative review
4.0
Awesome Deal!
"This Is a great Deal!, i got it in store (i believe it was cheaper in store) I do lots of photoshop and Web browsing on my netbook. Iv'e had it for bout 2 Months, and it's still in perfect shape, and the battery died only once, it ridiculous at how long the battery lasts, and i use this thing almost everyday for long extended times. All you do is insert the USB stick, click the mouse to turn it on, and theres no..." Read Full Review »
Aug 13, 2009 by veilx
See more positive Gigaware Wireless Optical Mouse reviews
1.0
Terrible tracking, horrible battery life
"I have a Microsoft Laser Mouse 5000 on my primary PC. I bought this Gigaware thing for my other computer on a whim. This mouse is NO GOOD. It very often "lags" so that the cursor won't move until a second or two until I have moved the mouse. Also, the two thumb buttons are not programmable with any program or game that I've found, which means they are only good for "back" and "forward" buttons in your browse..." Read Full Review »
Nov 01, 2009 by Mister Inexpensive Tech
See more negative Gigaware Wireless Optical Mouse reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
1.0
    Pros
  • None
    Cons
  • Inaccurate Tracking
  • Poor Battery Life
  • Slow Response
    Best Uses
  • None
"I have a Microsoft Laser Mouse 5000 on my primary PC. I bought this Gigaware thing for my other computer on a whim. This mouse is NO GOOD. It very often "lags" so that the cursor won't move until a second or two until I have moved the mouse. Also, the two thumb buttons are not programmable with …"  Read Full Review »
Was this Computer Mice review on the Gigaware Wireless Optical Mouse helpful to you?
Nov 1 2009
San Jose, CA
I am:
  • Power user
Awesome Deal!
4.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
    Cons
  • Limited Surface Compatibility
  • Uncomfortable Design
    Best Uses
  • Everyday Use
  • Gaming
  • Professional
  • Web Browsing
"This Is a great Deal!, i got it in store (i believe it was cheaper in store) I do lots of photoshop and Web browsing on my netbook. Iv'e had it for bout 2 Months, and it's still in perfect shape, and the battery died only once, it ridiculous at how long the battery lasts, and i use this thing almost …"  Read Full Review »
Aug 13 2009
veilx
California
I am:
  • Casual User
a trick to install, but so far so good
3.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
    Cons
  • None
    Best Uses
  • None
"Ok, after an initial bad review since vista won't install the device properly, i wasted a lot of time looking for a driver which doesn't exist.
It turns out that this is vista's fault after all, since an update to the generic usb mouse drivers keeps this thing from working.
To solve this pro …"  Read Full Review »
May 30 2009
hrmm
Pop. MS
I am:
  • Power user
[1 of 1 customers found this review helpful]
One Of A Kind Product
5.0
    Pros
  • Accurate Tracking
  • Comfortable Design
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Designing
  • Drawing
  • Everyday Use
  • Gaming
  • Photo Editing
  • More »
"What I like most about this Product is that Gigaware has done away with the old Ball that wasn't good when it came down to Editing Pictures and doing Designs like building Houses and so on. This is the first time ever that I got the chance to use a Mouse with 5 Keys and it's just Amazing. It's not e …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 2 2009
DJ High Tek
Williamston, N.C.
I am:
  • Power user
CHANGE battery if red LED FLASHES
3.0
    Pros
  • Great Features
    Cons
  • Poor Battery Life
    Best Uses
  • Everyday Use
"CHANGE the batteries when the red LED on mouse flashes!
I just find out why this mouse worked perfect for weeks but turns bad later. This mouse seems malfunctional when the battery has a little bit low voltage. The red light on mouse will flash when low battery as the guidebook says. In that cas …"  Read Full Review »
Aug 18 2009
Timothy
New York, NY
I am:
  • Power user
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
