Gigaware Wireless Laser Mouse with Ultra-Compact Dongle
#299
3.2
based on 33 reviews
from $39.99
Ratings Distribution
5 star
10
4 star
7
3 star
3
2 star
2
1 star
10
Category Average
4.3
$39.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Fast (19)
  • Comfortable design (16)
  • Glides smoothly (15)
  • Accurate tracking (14)
  • Works on any surface (11)
  • Good battery life (5)
  • Great features (4)
  • Lightweight (2)
  • 24ghz wirless technology (1)
  • Compact usb receiver (1)
See less See more
Cons
  • Uncomfortable design (4)
  • Inaccurate tracking (3)
  • Catches easily (2)
  • Short battery life (2)
  • Cant do tons of clicks (1)
  • Cheap (1)
  • Doesnt always work (1)
  • Limited surface compatibility (1)
  • Mediocre construction (1)
  • Might lose receiver (1)
Best Uses
  • Everyday (15)
  • Web browsing (12)
  • Travel (10)
  • Professional (9)
  • Gaming (8)
  • Graphic design (3)
  • Video and photo editing (1)
Provided by RadioShack
Experience the convenience of a wireless mouse with this 1600dpi laser mouse.
Specification Description
Model 26-990
Accessory Indicator Yes
Benefits Laser sensor provides amazing tracking abilities and works on most surfaces2.4GHz for improved range and performanceDongle c
Capacity UOM mAh
Country Of Origin China
Description Header Support clutter-free desktops!
Display Catalog Number 26-990
Enclosure Color Black
Included in the Box MouseReceiverCarrying pouch
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 26-990
New Date Sun Oct 19 00:00:00 CDT 2008
Operating Temperature UOM ° F
Product Depth 3.8
Product Dimensions UOM inches
Product Height 1.3
Product Type Wireless
Product Weight 1.3
Product Weight UOM ounces
Product Width 2.4
Required to function "AAA" batteries (2)
Required to function SKU 2300661
Supported Languages English
Gigaware Wireless Laser Mouse with Ultra-Compact Dongle Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 12, 2009
Gigaware Wireless Laser Mouse with Ultra-Compact Dongle Reviews
Most helpful positive review
Most helpful negative review
4.0
The Poor Man's Logitech Nano
"A family member was looking for a new wireless mouse; she has broken her last one when she knocked into the USB dongle. That said, a priority was finding a mouse with a compact USB receiver. This very feature is the shining highlight of this mouse. It has a compact USB receiver that only protrudes a few centimeters out. Incidentally, it also fits nicely into the underside battery compartment for on-the-go ..." Read Full Review »
Nov 28, 2008 by Neo the Mouse Afficionado
See more positive Gigaware Wireless Laser Mouse with Ultra-Compact Dongle reviews
3.0
Usually great
"This mouse is usually great, especially with a laptop. The pouch is nice and provides protection in my bag. The dongle is small enough so it can be left in your computer and you don't have to worry about it breaking. The on/switch on the mouse is easy to access. With turning the mouse off when not in use I get about 2 months 40 hrs per week on a set of batteries. Everything on the mouse almost always works well...." Read Full Review »
Aug 20, 2009 by Bartwick
See more negative Gigaware Wireless Laser Mouse with Ultra-Compact Dongle reviews
Displaying 1 - 5 of 33 Reviews
Show
Sort by
4.0
    Pros
  • Compact USB Receiver
  • Handy travel case
  • Lightweight Slim Design
  • Receiver fits in mouse
    Cons
  • Mediocre Construction
    Best Uses
  • Everyday Use
  • Traveling
This very feature is the shining highlight of this mouse. It has a compact USB receiver that only prot …"  Read Full Review »
Was this Computer Mice review on the Gigaware Wireless Laser Mouse with Ultra-Compact Dongle helpful to you?
Nov 28 2008
Trenton, NJ
I am:
  • Power user
Excellent Mouse
5.0
    Pros
  • Accurate Tracking
  • Comfortable Design
  • Fast Response
  • Glides Smoothly
  • Works On Any Surface
    Cons
  • None
    Best Uses
  • Everyday Use
"I have had this mouse for a year and I love it. It works great, the receiver is ultra small which means I never have to worry about hitting it or breaking it and the batteries last a really long time. "
Nov 22 2009
MM
Boston, MA
I am:
  • Casual User
Usually great
3.0
    Pros
  • Accurate Tracking
  • Glides Smoothly
    Cons
  • Inaccurate Tracking
    Best Uses
  • Everyday Use
  • Professional
  • Traveling
"This mouse is usually great, especially with a laptop. The pouch is nice and provides protection in my bag. The dongle is small enough so it can be left in your computer and you don't have to worry about it breaking. The on/switch on the mouse is easy to access. With turning the mouse off when not i …"  Read Full Review »
Aug 20 2009
Bartwick
Brooklyn, NY
I am:
  • Power user
Awesome Product
5.0
    Pros
  • Accurate Tracking
  • Fast Response
  • Glides Smoothly
  • Great Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Traveling
  • Web Browsing
"This is the best mouse I have ever had! It fits comfortably in my hand, and I have pretty big hands too. I really like how tiny the receiver is. It barely sticks out of my laptop so I just keep it plugged in. The battery life is great on it too! I am on the computer for a few hours a day, and even …"  Read Full Review »
Aug 21 2009
Aaron
Minnesota
I am:
  • Casual User
WORKS GREAT AT FIRST BUT THEN.....
1.0
    Pros
  • Fast Response
  • Glides Smoothly
    Cons
  • Poor Battery Life
    Best Uses
  • Everyday Use
"I bought this when it was a Black Friday deal in November 2008. It worked great initially and was really speedy (glided fast...almost tooooooo fast). Starting in March though, it began having problems and I had to keep replacing the batteries. Today, it is "stuck" in the on position (something in …"  Read Full Review »
May 6 2009
Mert
Kathleen, GA
I am:
  • Power user
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
