Gigaware Omni-Directional Clip-On PC Microphone
#321
2.2
based on 16 reviews
from $14.99
Ratings Distribution
5 star
3
4 star
1
3 star
1
2 star
2
1 star
9
Category Average
4.0
$14.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Compact design (10)
  • Easy to use (7)
  • Great sound quality (2)
  • Quality microphone (2)
  • Added features (1)
  • Clips to clothes (1)
  • Comfortable (1)
  • Omni-directional (1)
  • Very sensitive (1)
See less See more
Cons
  • Poor sound quality (7)
  • Poor microphone (5)
  • Difficult to use (3)
  • Cable feels thin (1)
  • Doesn't work (1)
  • Lags (1)
  • Mic only (1)
  • On off button (1)
  • Skips (1)
  • Uncomfortable (1)
Best Uses
  • Typing & talking (4)
  • Mobility (3)
  • Bird migration monitoring (1)
  • External microphone (1)
  • Paper weight (1)
  • Relieving neck pain (1)
  • Vs headset (1)
Provided by RadioShack
This clip-on omni-directional microphone is ideal to use with PC multimedia devices.
Specification Description
Model 60139B
Accessory Indicator Yes
Benefits 6-ft. cable accomodates most work stationsAllows you to work hands-freeIdeal for use with multimedia devices
Capacity UOM mAh
Country Of Origin China
Description Header Talk hands-free.
Display Catalog Number 33-119
Features Electret condensor mic with frequency response 30-15,000Hz, impedence 1K ohms 30%Sensitivity: 60dB +/- 4dBClips on clothing
Included in the Box MicrophoneMonitor mount
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 60139B
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 1.5
Product Length 17.1
Product Type Microphones
Product Weight 0.1
Product Weight UOM pounds
Product Width 4.24
Supported Languages English
Gigaware Omni-Directional Clip-On PC Microphone Questions
Questions and Answers
Where to Buy
$14.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 19, 2009
Gigaware Omni-Directional Clip-On PC Microphone Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
perfect for recording night migration
"We use the microphone for recording night migration of bird calls. Our microphones lasted for months in outdoor conditions with minor weather protection. Recording was continuous and we had no failures. Sound quality was good. The microphones were extremely easy to use and adaptable for our use. All in all an excellent choice for this application...." Read Full Review »
Oct 19, 2009 by Dr. Caitlin
See more positive Gigaware Omni-Directional Clip-On PC Microphone reviews
1.0
A deaf microphone
"This microphone does not pick up any sound unless it is within an inch of the source. I maxed out the sensitivity and gain on my computer, but I still had to yell into it from 6 inches away to hear anything. The cord does have a decent length and this was inexpensive...." Read Full Review »
Jun 11, 2008 by The Quiet Yell
See more negative Gigaware Omni-Directional Clip-On PC Microphone reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
5.0
    Pros
  • Compact Design
  • Easy To Use
    Cons
  • None
    Best Uses
"We use the microphone for recording night migration of bird calls. Our microphones lasted for months in outdoor conditions with minor weather protection. Recording was continuous and we had no failures. Sound quality was good. The microphones were extremely easy to use and adaptable for our use. …"  Read Full Review »
Was this Computer Speaker & Headphones review on the Gigaware Omni-Directional Clip-On PC Microphone helpful to you?
Oct 19 2009
Dr. Caitlin
North Dakota
I am:
  • Quality Oriented
Reviewed at:
Price: $14.99
[0 of 1 customers found this review helpful]
Works well with a recording device
4.0
    Pros
  • Omni-Directional
  • Very Sensitive
    Cons
  • Cable feels thin
  • On Off Button
    Best Uses
"I use this for EVP work and it seems to work well when plugged into a digital voice recorder or cassette recorder. It can almost be too sensitive at times. The cable feels thin as if it may not last over a long period of time. For the price this isn't so bad. The on/off button can be difficult at ti …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Aug 4 2008
Big K
Texas
I am:
  • Quality Oriented
Reviewed at:
Price: $14.99
A deaf microphone
1.0
    Pros
  • Compact Design
    Cons
  • Difficult To Use
  • Poor Microphone
  • Poor Sound Quality
  • Uncomfortable
    Best Uses
  • None
"This microphone does not pick up any sound unless it is within an inch of the source. I maxed out the sensitivity and gain on my computer, but I still had to yell into it from 6 inches away to hear anything. The cord does have a decent length and this was inexpensive. "
 Report Abuse  (1)  (0)  0 comments
Jun 11 2008
The Quiet Yell
Minnesota
I am:
  • Value Oriented
Reviewed at:
Price: $14.99
Incredibly poor
1.0
    Pros
  • None
    Cons
  • Poor Microphone
    Best Uses
  • None
"This thing would not register my voice at all unless I was either talking very loudly or holding it a few inches in front of my mouth. It utterly fails as a clip-on microphone and it certainly would be no good if you kept it on the included mount on your monitor or tower. Total waste of money. "
Feb 19 2009
Greg
Agoura Hills, CA
I am:
  • Value Oriented
Reviewed at:
Price: $14.99
Not very good
2.0
    Pros
  • Clips to clothes
  • Compact Design
  • Easy To Use
    Cons
  • Lags
  • Poor Microphone
  • Skips
    Best Uses
  • Typing & Talking
"I used this microphone to record vocals for a song, and when you record with it, it lags very much, I have to practically eat the microphone for it to pick up sound, and it skips very often "
Dec 25 2008
Chenbot (Phi)
Dunedin, FL
I am:
  • Quality Oriented
Reviewed at:
Price: $14.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
