Gigaware 8GB USB Slider Drive
#308
3.5
based on 4 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.3
$22.99 at RadioShack
Find it at Amazon
Find it at Ebay
$22.99
from 1 store
Pros
  • Easy setup (3)
  • Easy to use (2)
  • Fast (2)
  • Large capacity / good size (2)
  • Portable (2)
  • Reliable (1)
See less See more
Cons
  • Unreliable (1)
Best Uses
  • File transfer (3)
  • Additional storage (1)
  • Back-up (1)
  • Music (1)
  • Video (1)
Provided by RadioShack
This little drive makes it easy to take files with you wherever you go.
Specification Description
Model 25-918
Accessory Indicator Yes
Benefits For storing and transporting photos, music, videos and other digital contentHolds up to 5722 photos, 2000 songs and 15 hours of video
Body Material ABS plastic
Capacity UOM mAh
Country Of Origin China
Description Header Slide your data along with you.
Display Catalog Number 25-918
Enclosure Color Black
Manufacturer Labor Warranty 2
Manufacturer Parts Warranty 2
MAP Price 0.0
Model 25-918
Operating Temperature UOM ° F
Product Depth 4
Product Dimensions UOM inches
Product Disclaimer * Photos based on 4-magapixel camera with JPEG 100% quality files (visually lossless JPRG compression with 1:10 ratio of RAW image); Songs based on 4-
Product Height 0.84
Product Type 8GB
Product Width 2.7
Required to function Windows® 2000 SP4, XP, Vista, Linux and Mac® OS X v10.1.2+Available USB 2.0 high-power to utilize high-speed transfer
Supported Languages English
Gigaware 8GB USB Slider Drive Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 5, 2009
Gigaware 8GB USB Slider Drive Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Works great
4.0
    Pros
  • Easy To Setup
    Cons
  • None
    Best Uses
  • File Transfer
"Works just fine.
As for the last post for it not holding a 5.6GB file. You probably have it formatted in FAT32 format. Which means the largest file it will hold is 4GB. Reformat it in NTFS and you will be good to go. "
Was this Flash Stick review on the Gigaware 8GB USB Slider Drive helpful to you?
Nov 5 2009
Schwy
Marlton, NJ
I am:
  • Power user
Gigaware® 8GB USB Slider Drive
5.0
    Pros
  • Easy To Setup
  • Easy To Use
  • Fast
  • High Capacity
  • Portable
  • More »
    Cons
  • None
    Best Uses
  • File Transfer
"This memory stick is used to transfer files from a laptop to a desktop PC. The performance is as expected. I also like the big ring to attach it to my keyring. "
Oct 14 2009
jx2 Jim
Richland Hills, Tx
I am:
  • Casual user
[1 of 1 customers found this review helpful]
easy to use, fast to copy
4.0
    Pros
  • Easy To Setup
  • Easy To Use
  • Fast
  • High Capacity
  • Portable
    Cons
  • None
    Best Uses
  • Additional Storage
  • Backup
  • File Transfer
  • Music
  • Video
"easy fast to transfer entire 4G video folder. Storage is decent at 7.46GB (exclude some embeded software) "
 Report Abuse  (1)  (0)  0 comments
Oct 17 2009
Meiling
Portalnd, OR
I am:
  • Power user
[1 of 5 customers found this review helpful]
something wrong, will not accept 5.6gb
1.0
    Pros
  • None
    Cons
  • Unreliable
    Best Uses
  • None
"Seemed like a good deal when I purchased today, but when I plug this puppy in and try and copy a 5.6gb file to it, is says there is not enough capacity. 5.6 is not even close to 8. not sure what the problem is. "
 Report Abuse  (1)  (4)  0 comments
Aug 27 2009
sal
lansing, mi
I am:
  • Power user
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
