Close Login Module
Join
Gigaware 4-Port Retractable USB Hub
3.8
based on 11 reviews
Ratings Distribution
5 star
5
4 star
3
3 star
1
2 star
0
1 star
2
Category Average
4.1
Pros
  • Reliable (4)
  • Durable (3)
  • Highly compatible (3)
  • Small (3)
  • Strong connection points (3)
  • Easily expanded (2)
  • Easy setup (2)
  • Fast (2)
  • Improves performance (2)
  • Good value (1)
See less See more
Cons
  • Flimsy (2)
  • Incompatible (1)
  • Limited by bus power (1)
  • Placement of the 4th port (1)
  • Tight spacing on one side (1)
Best Uses
  • Computer equipment (4)
  • Desktop (3)
  • Home (2)
  • High-end equipment (1)
  • Netbook (1)
  • Networking (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 4-Port Retractable USB Hub
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 12, 2009
Gigaware 4-Port Retractable USB Hub Reviews
Most helpful positive review
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Wonderfully helpful!
"I have a netbook with 3 usb ports. I use a mouse(1), and I have an external drive (2). If I want to add anything else, this lets me do it. I love the fact that it is small and portable, as well...." Read Full Review »
Sep 12, 2009 by Chris
See more positive Gigaware 4-Port Retractable USB Hub reviews
3.0
its ok. no drivers for windows 2000
"retracting cable likes to retract at random times. short cable is not shielded, had problems with one of my usb devices because of this. nice physical design but is somewhat cheap. also, i have a dual boot computer with xp and 2000 pro, and there is no driver download anywhere for this hub, only a manual...." Read Full Review »
Apr 06, 2008 by Rob
See more negative Gigaware 4-Port Retractable USB Hub reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
3.0
    Pros
  • Strong Connection Points
    Cons
  • Flimsy Construction
    Best Uses
  • Computer Equipment
"retracting cable likes to retract at random times. short cable is not shielded, had problems with one of my usb devices because of this. nice physical design but is somewhat cheap. also, i have a dual boot computer with xp and 2000 pro, and there is no driver download anywhere for this hub, only …"  Read Full Review »
Apr 6 2008
Rob
northern virginia
I am:
  • Quality Oriented
Reviewed at:
5.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
  • Netbook
"I have a netbook with 3 usb ports. I use a mouse(1), and I have an external drive (2). If I want to add anything else, this lets me do it. I love the fact that it is small and portable, as well. "
Sep 12 2009
Chris
Omaha, NE
I am:
  • High bandwidth user
Reviewed at:
Great little hub
4.0
    Pros
  • Durable construction
  • Highly Compatible
  • Improves Performance
  • Reliable
    Cons
  • placement of the 4th port
    Best Uses
"This hub is perfect for my cramped office. It's small, light, and easy to take almost anywhere. The only thing i have a problem with is that one of the ports is placed on the back of the thing. WHY?!?! other than that, it's perfect for the traveler and best of all, there's no ac adapter. "
Feb 1 2008
j-records inc.
Rochester, NY
I am:
  • Value Oriented
Reviewed at:
Works Fine.
4.0
    Pros
  • Good Value
    Cons
  • Tight Spacing on one side
    Best Uses
  • None
"Not bad for a bus powered USB hub. It won't handle high power needs, like an external hard drive and an iPod, or charging a BlackBerry. But I'm using it now with 2 thumb drives, charging/syncing iPhone, and charging/syncing iPod 5G. It's holding up like a champ. The spacing on the 3 port side is …"  Read Full Review »
Jan 13 2009
Dave
NJ
Reviewed at:
It's alright but.......
1.0
    Pros
  • Small
    Cons
    Best Uses
  • Desktop
"I used this product on my laptop...It is great but it turns and moves when you move, it won't retract back in once out and it ended up tearing up..The cords just broke apart because the wire isn't protected very well. "
Aug 25 2008
heavensent0826
hephzibah,GA
I am:
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
$22.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
