Gigaware 27MHz Wireless Keyboard and Laser Mouse Combo
#146
2.2
based on 23 reviews
from $49.99
Ratings Distribution
5 star
3
4 star
4
3 star
2
2 star
0
1 star
14
Category Average
4.0
$49.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Easy connectivity (6)
  • Fast connection (5)
  • Versatile (5)
  • Durable (2)
  • Ergonomic (2)
  • Quiet (2)
  • Comfortable design (1)
  • Cool (1)
  • Great features (1)
  • Love the short cut keys (1)
See less See more
Cons
  • Poorly designed (6)
  • Difficult to set up (4)
  • Unreliable performance (4)
  • Flimsy (3)
  • Slow connection (3)
  • Inadequate features (2)
  • Uncomfortable design (2)
  • Choppy signal (1)
  • Doesn't work properly (1)
  • Don"t get it (1)
Best Uses
  • Multimedia (6)
  • Gaming (5)
  • Home (5)
  • Office (5)
  • Dorm room (3)
  • Financial (1)
  • Fire fuel (1)
  • Garbage (1)
  • Walking around typing (1)
  • Web browsing (1)
Provided by RadioShack
Free your desk from clutter when you use this wireless keyboard/mouse combo.
Specification Description
Model 26-985
Accessory Indicator Yes
Benefits Keyboard and mouse have no restrictive wires so desktop clutter is reducedLaser sensor provides amazing tracking abilities and works
Capacity UOM mAh
Country Of Origin China
Description Header Join the wireless revolution.
Display Catalog Number 26-985
Included in the Box MouseKeyboardReceiver
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 26-985
Operating Temperature UOM ° F
Power Device "AA" batteries
Product Type Keyboard/mouse combos
Required to function "AA" batteries (4)
Required to function SKU 2300885
Supported Languages English
Gigaware 27MHz Wireless Keyboard and Laser Mouse Combo Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 15, 2009
Gigaware 27MHz Wireless Keyboard and Laser Mouse Combo Reviews
Most helpful positive review
Most helpful negative review
5.0
Who are these people????
"I've read the comments of others and honestly I'm not sure what planet I brought mine from, but it must have been an alternate reality or something....This combo works just fine, the receiver has a long USB cord so u can set it at an optimum range for use. I'm a certified network engineer, and I've worked with all sorts of wireless devices that suck...this isn't one of those, and I've never heard of this company..." Read Full Review »
Nov 15, 2009 by KALIM
See more positive Gigaware 27MHz Wireless Keyboard and Laser Mouse Combo reviews
1.0
nice to look at, that's all...
"Take your $50 and spend it towards a name brand with a history of customer satisfaction. like logitech. The mouse isn't even "laser", it's just a cheap "optical" mouse. The transmitter easily looses connection from interference from other electrical devices including your monitor. Everytime I use my PC I gamble with the chance that my peripherals are going to lock up and I'll have to hard-reset my system...." Read Full Review »
Jun 18, 2009 by Tonytone
See more negative Gigaware 27MHz Wireless Keyboard and Laser Mouse Combo reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
5.0
    Pros
  • Cool
  • Easy Connectivity
  • Fast Connection
  • Versatile
    Cons
  • None
    Best Uses
  • Dorm Room
  • Gaming
  • Home
  • Multimedia
  • Office
  • More »
"I've read the comments of others and honestly I'm not sure what planet I brought mine from, but it must have been an alternate reality or something....This combo works just fine, the receiver has a long USB cord so u can set it at an optimum range for use. I'm a certified network engineer, and I've …"  Read Full Review »
Was this Computer Keyboard & Mouse Set review on the Gigaware 27MHz Wireless Keyboard and Laser Mouse Combo helpful to you?
Nov 15 2009
KALIM
Huntsville, AL
I am:
  • Power user
Works very well
4.0
    Pros
  • Durable
  • Easy Connectivity
  • Ergonomic
  • Fast Connection
  • Versatile
    Cons
  • Difficult To Set Up
    Best Uses
  • Dorm Room
  • Gaming
  • Home
  • Multimedia
  • Office
"The mouse and keyboard are actually very easy to use however, the mouse does have pretty bad range, if the receiver is not close to it, the mouse will lose connection. The battery life is outstanding, havent changed the batteries since i bought these, over a month ago! also, for the people claiming …"  Read Full Review »
Nov 4 2009
Shadow The Unforgiven
Atlants, Georgia
I am:
  • Power user
I was worried, but it works PERFECTLY
5.0
    Pros
  • Ergonomic
  • Fast Connection
  • Versatile
    Cons
  • None
    Best Uses
  • Gaming
  • Multimedia
"I got this because I have a 40 inch in my bedroom that I use to play FPS games on from my bed, and I want to sit far enough back with my keyboard/mouse and play as though in a movie environment. It works perfectly! CONS: 1.The initial hookup and frequency linking of the keyboard/mouse to the USB …"  Read Full Review »
Sep 24 2009
Jin
Joliet, IL
I am:
  • Power user
1.0
    Pros
  • None
    Cons
  • Flimsy
  • Poorly Designed
  • Slow Connection
    Best Uses
  • Home
  • Office
"Don't even consider buying this.The mouse never worked and the keyboard has died after about a month. [...] "
Nov 15 2009
Seattle, Wa
I am:
  • Power user
1.0
    Pros
  • Pretty sleek design
    Cons
  • Flimsy
  • Looses connection
  • No status lights
  • Poorly Designed
  • More »
    Best Uses
  • Fire fuel
  • None
"Take your $50 and spend it towards a name brand with a history of customer satisfaction. like logitech. The mouse isn't even "laser", it's just a cheap "optical" mouse. The transmitter easily looses connection from interference from other electrical devices including your monitor. Everytime I use …"  Read Full Review »
Jun 18 2009
Tonytone
Rapid City, SD
I am:
  • Power user
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
