Close Login Module
Join
General Brand Adorama Filter Wrench for 62mm-77mm Filters, Package of 2
3.9
based on 61 reviews
Ratings Distribution
5 star
24
4 star
20
3 star
10
2 star
1
1 star
7
Category Average
4.4
$4.95
from 2 stores
Pros
  • Easy to use (21)
  • Quality construction (8)
  • Affordable (1)
  • Consistent effect (1)
  • Easy to store and carry (1)
  • Excellent accessory (1)
  • Firm mount (1)
  • Functional (1)
  • It works (1)
  • Simple but effective (1)
See less See more
Cons
  • Flimsy (12)
  • Inconsistent effect (3)
  • Poor quality (2)
  • A little large (1)
  • Break easily (1)
  • Don't fit most in range (1)
  • Lightweight and flimsy. (1)
  • Need grip rubber inside (1)
  • Need more than one set (1)
  • Plastic (1)
Best Uses
  • Lens protection (8)
  • Filter protection (5)
  • Remove stuck filters (2)
  • Easy removal of filter (1)
  • Filter removal (1)
  • Filter rescue (1)
  • Filters (1)
  • Last ditch in emergencies (1)
  • On a polarizer (1)
  • Physical equipment repair (1)
Where to Buy
BizRate Rating Outstanding 9.6
$4.95
No Tax Outside NY
BizRate Rating Outstanding 9.1
$4.95
Product Reviews
Last update: Nov 2, 2009
General Brand Adorama Filter Wrench for 62mm-77mm Filters, Package of 2 Reviews
Most helpful positive review
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
Now I can use my polarizing filter.
"What a simple gadget. And what an important job it does. Anyone who has ever put a filter on a lens, and then been unable to remove it will appreciate this product. I always hesitate using my polarizer because it is so hard to remove. Because one part of it rotates, it is almost impossible to get a good grip on the filter. Plain filters also get stuck, and sometimes require pliers to remove, getting scratched in..." Read Full Review »
Jul 14, 2009 by Jerry
See more positive General Brand Adorama Filter Wrench for 62mm-77mm Filters, Package of 2 reviews
3.0
FLIMSY
"These are 3mm thick plastic which bend and wobble. If the filter is not on tight it can remove it. I found that using the pair of them together works much better. However they do have a tendency to slide around on a tight filter. I glued a rubber band to one and it worked better, however it did reduce the max filter size it could be used on. If it came with a rubber grip it would be worth it...." Read Full Review »
May 05, 2008 by fstopmike
See more negative General Brand Adorama Filter Wrench for 62mm-77mm Filters, Package of 2 reviews
Displaying 1 - 5 of 61 Reviews
Show
Sort by
FLIMSY
3.0
    Pros
  • None
    Cons
  • Flimsy easy to break
  • Slides around on filter
    Best Uses
  • None
"These are 3mm thick plastic which bend and wobble. If the filter is not on tight it can remove it. I found that using the pair of them together works much better. However they do have a tendency to slide around on a tight filter. I glued a rubber band to one and it worked better, however it did redu …"  Read Full Review »
Was this Camera Filter review on the General Brand helpful to you?
 Report Abuse  (4)  (0)  0 comments
May 5 2008
fstopmike
Albuquerque, NM
I am:
  • Professional
Reviewed at:
Price: $4.95
[3 of 3 customers found this review helpful]
Should be Sturdier
3.0
    Pros
  • None
    Cons
    Best Uses
  • Removing filters
"I purchased this filter wrench set primarily to help me separate my polarizer filter from step-up rings. The filter and rings have a tendency to stick together, sometimes making it almost impossible to get them apart. I felt the filter wrench might help. So far I haven't had much luck with the wrenc …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jun 11 2008
Woodsguy the Photographer
Grand Marais, MN
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $4.95
[2 of 2 customers found this review helpful]
they "may" be helpful...
1.0
"I think this is a good idea that has been around for as long as I remember. I had difficulty in using this item to remove a filter. Basically, there is not enough friction or traction to do the job efficiently. Ergonomically, if my hands were thinner, had vice-like strength, were able to withstand t …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jun 19 2008
Ron
San Francisco
I am:
  • Professional
Reviewed at:
Price: $4.95
5.0
    Pros
  • Easy to use
  • Inexpensive
    Cons
  • Break easily
    Best Uses
  • Remove stubborn filters
"What a simple gadget. And what an important job it does. Anyone who has ever put a filter on a lens, and then been unable to remove it will appreciate this product. I always hesitate using my polarizer because it is so hard to remove. Because one part of it rotates, it is almost impossible to get a …"  Read Full Review »
Jul 14 2009
Jerry
Suburbs of Philadelphia, PA
I am:
  • Photo Enthusiast
Reviewed at:
Price: $4.95
Low Tech Solution to a Big Problem
5.0
    Pros
  • Easy To Use
    Cons
  • None
    Best Uses
  • Physical Equipment Repair
"My 72mm digital polarizer got "stuck" to my 1A Skylight Filter. The fine threads apparently got "cross-threaded." There was NO WAY to seperate the two filters without using a Filter Wrench ... it's impossible to get a secure, firm grip on the two filters without having the right tool. This set o …"  Read Full Review »
Sep 1 2009
Photo-Matt
Frederick, MD
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $4.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$4.95
No Tax Outside NY
$4.95
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
