General Brand 67mm Linear Polarizer Glass Filter
3.7
based on 3 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$17.36 at B&H Photo Video
 Trusted:
$18.10 at Adorama
Find it at Amazon
$17.36 - $18.10
from 2 stores
More Images
Pros
  • Clear optics (2)
  • Consistent effect (1)
  • Easy to use (1)
  • Firm mount (1)
  • Well built / quality construction (1)
See less See more
Cons
  • Inconsistent effect (1)
Best Uses
  • Artwork (1)
  • Color correction (1)
  • Image manipulation (1)
  • Lens protection (1)
  • Prevent glare (1)
  • Uv protection (1)
Provided by B&H Photo Video
The Tiffen 67mm Linear Polarizer - Light rays which are reflected become polarized. Polarizing filters are used to select which light rays enter your camera lens. They can remove unwanted reflections from non-metallic surfaces such as water or glass and also saturate colors providing better contrast. The effect can be seen through the viewfinder and changed by rotating the filter. The filter factor varies according to how the filter is rotated and its orientation to the sun.
Specification Description
Model 67POL, B67PLGB
UPC 024066012029
Thread Size (Round) 67mm
Type Linear Polarizers
General Brand 67mm Linear Polarizer Glass Filter Questions
Questions and Answers
Where to Buy
$17.36
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$18.10
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Oct 1, 2009
General Brand 67mm Linear Polarizer Glass Filter Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Not really good
1.0
    Pros
  • Easy To Use
    Cons
  • Inconsistent Effect
    Best Uses
  • None
"I 've rotate the circular filter to find a better effect, but I think this is not an enought stronger polarize filter... I always see the glass flare on my picture, always see the water reflection and sky is not more blue on my picture.
Maybe I need to buy a real expensive one. "
Was this Camera Filter review on the General Brand 67mm Linear Polarizer Glass Filter helpful to you?
Oct 1 2009
Digicrea
Tahiti - French Polynesia
I am:
  • Semi-pro Photographer
exactly what I wanted at the right price
5.0
    Pros
  • Clear Optics
  • Strong Construction
    Cons
  • None
    Best Uses
  • Artwork
  • Image Manipulation
  • Lens Protection
  • UV Protection
"As a filter to protect my 18-135 Nikor AF lens this product works perfectly. Further it polarizes as it should reducing glare when shooting water surfaces and glass windows or into the Sun. "
Aug 29 2008
Bubba
Orlando FL
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $17.36
Good filter
5.0
    Pros
  • Clear Optics
  • Consistent Effect
  • Firm Mount
    Cons
  • None
    Best Uses
  • Color Correction
  • Prevent Glare
"Early morning shoots to prevent glare and enhance colors. "
May 20 2008
Al
Greenville, SC
I am:
Reviewed at:
Price: $17.36
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
