#292
based on 24 reviews
Ratings Distribution
| 5 star |
10 |
| 4 star |
8 |
| 3 star |
4 |
| 2 star |
1 |
| 1 star |
1 |
Category Average
Pros
Cons
Best Uses
Where to Buy
| 5% off orders at Abt.com |
BizRate Rating
Outstanding 9.4
Product Reviews
"Put the 9V. battery, connect the preamp between the turntable (know what that is?) and the PC using a "y" connector with 2 RCA's and a 3.5mm banana jack a the other (extra accessory cable), launch "Audacity" (free at http://audacity.sourceforge.net) and you are cooking. So simple, even I can do it... The sound quality is good but bear in mind that it will not make a worn LP sound new, and that I could not pass ..." Read Full Review »
Nov 15, 2007 by The Humanist Rev, D.D.
See more positive GE Pre-Amplifier For Stereo Turntable reviews
"No instructions, but after tinkering with it I found and removed the two screws that hold the cover on. Battery goes inside. Once that was done, the item worked fine. Very small amount of distortion on some very high notes, probably because there's no "de-emphasis circuit" (as I remember it being called), but otherwise sounds goood...." Read Full Review »
Nov 02, 2009 by Ken
See more negative GE Pre-Amplifier For Stereo Turntable reviews
Displaying 1 - 5 of 24 Reviews
GE Pre-Amplifier For Stereo Turntable Review
Pros
Cons
Best Uses
"No instructions, but after tinkering with it I found and removed the two screws that hold the cover on. Battery goes inside. Once that was done, the item worked fine. Very small amount of distortion on some very high notes, probably because there's no "de-emphasis circuit" (as I remember it being …" Read Full Review »
Pros
Cons
Best Uses
"Put the 9V. battery, connect the preamp between the turntable (know what that is?) and the PC using a "y" connector with 2 RCA's and a 3.5mm banana jack a the other (extra accessory cable), launch "Audacity" (free at http://audacity.sourceforge.net) and you are cooking. So simple, even I can do it. …" Read Full Review »
Pros
Cons
Best Uses
"This unit take a nine volt battery. It has a port to accept a 9 volt AC/DC power adapter but does not come with one. The port is an odd size so it is difficult to find one also. Once installed as one my system it is hard to access to change the batteries. You really should have a power adapter. "
Pros
Cons
Best Uses
"My only criticism of this pre-amp is that I didn't read the description closely enough. It is battery operated. It does have a connection for DC power, but you have to buy your own power adapter.
On the positive end, set up is extremely easy and it works!
Pros
Cons
Best Uses
"The quality of the product is quite poor, there was some static noise, sounded like it's picking up 60 HZ from the mains.
The product just screams "Made to be the cheapest"
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
