GE Futura Indoor TV Antenna - Silver Finish
3.3
based on 48 reviews
Ratings Distribution
5 star
10
4 star
17
3 star
6
2 star
7
1 star
8
Category Average
3.6
More Images
Pros
  • Easy setup (39)
  • Strong signal (17)
  • Durable (8)
  • Attractive design (7)
  • Fine-tuning (3)
  • Affordable (1)
  • Bad signal (1)
  • Captures signal well (1)
  • Does not intrude (1)
  • Does the job (1)
See less See more
Cons
  • Poor reception / weak antenna (12)
  • Flimsy (2)
  • From time to time (1)
  • Instructions not clear (1)
  • Junk (1)
  • Marginal reception (1)
  • Needs more gain (1)
  • Needs placement adjustmen (1)
  • Reception varies (1)
Best Uses
  • Living room (18)
  • Bedroom (13)
  • Small rooms (7)
  • Office (5)
  • Portable devices (3)
  • Kitchen (2)
  • Anywhere (1)
  • Attic/roof mount (1)
  • Diining room (1)
  • Garbage can (1)
Provided by Abt Electronics
GE Futura Indoor TV Antenna - TV24746/ Specially Designed To Receive Digital TV Signal/ 20dB Gain Amplification/ Noise Eliminator Circuitry Filter/ Designed To Mount Horizontally Or Vertically
GE Futura Indoor TV Antenna - Silver Finish Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Futura Indoor TV Antenna - Silver Finish
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 13, 2009
GE Futura Indoor TV Antenna - Silver Finish Reviews
Most helpful positive review
Most helpful negative review
5.0
Great Reception
"I have two TVs that use rabbit-ears for local (12 miles away) stations. The reception was fair. After I purchased the digital converter boxes for these TVs, the rabbit ears had difficulty picking up the digital signals...had to keep moving them around and still they dropped signals. I then bought and set up these GE antennas. I am amazed at how well they work. All of the stations are clear, with beautiful color ..." Read Full Review »
Aug 18, 2008 by movie buff
See more positive GE Futura Indoor TV Antenna - Silver Finish reviews
3.0
Where's the reception?
"Antenna does not deliver on the reception. Perhaps something in the building where I live is somehow blocking signals. Good looking design, spotty reception. Strong signals on some channels - snow & static on others. Mostly no reception on broadcast channels. Perhaps the instructions could be made a bit clearer,or perhaps the antenna needs to be specially mounted. Bummer...." Read Full Review »
May 26, 2009 by Frayed Knot
See more negative GE Futura Indoor TV Antenna - Silver Finish reviews
Displaying 1 - 5 of 48 Reviews
Show
Sort by
Great Reception
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Bedroom
  • Living Room
"I have two TVs that use rabbit-ears for local (12 miles away) stations. The reception was fair. After I purchased the digital converter boxes for these TVs, the rabbit ears had difficulty picking up the digital signals...had to keep moving them around and still they dropped signals. I then bought an …"  Read Full Review »
Was this Antenna review on the GE Futura Indoor TV Antenna - Silver Finish helpful to you?
Aug 18 2008
movie buff
Peoria, IL
I am:
  • Practical
Reviewed at:
Kinda disappointing
1.0
    Pros
  • Easy To Set Up
    Cons
  • Poor Reception
    Best Uses
  • None
"This antenna didn't even compare to my old rabbit ears, and I was hoping it would be an upgrade. Sketchy reception and a lot more fiddling with the position of the antenna. The coaxial cable included did not fit into my digital converter box. AND the antenna needs to be plugged in with an adaptor …"  Read Full Review »
Oct 13 2009
Valerie
Washington, DC
I am:
  • Casual User
Reviewed at:
3.0
    Pros
  • Attractive Design
  • Easy To Set Up
    Cons
  • Flimsy
  • Poor Reception
    Best Uses
  • Bedroom
  • Living Room
"Antenna does not deliver on the reception. Perhaps something in the building where I live is somehow blocking signals. Good looking design, spotty reception. Strong signals on some channels - snow & static on others. Mostly no reception on broadcast channels. Perhaps the instructions could be ma …"  Read Full Review »
May 26 2009
Frayed Knot
Arlington, VA
I am:
  • Casual User
Reviewed at:
GE Futura Indoor Antenna Used in a Boat!
4.0
    Pros
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"Completed a LOT of research prior to purchasing and thought a lot about just keeping the old rabbit ears...glad I didn't. This unit has a sleek look & is VERY simple... up and testing in 2 minutes. I was quite surprised since my goal was for use in the cabin/below water level of a boat. Can get the …"  Read Full Review »
Jul 21 2008
KD
Lake Norman Davidson, NC
I am:
  • Professional
Reviewed at:
disappointed.reviews beter than use here
2.0
    Pros
  • Easy To Set Up
    Cons
  • Poor Reception
  • some decent,some very wav
    Best Uses
  • Bedroom
  • Office
  • Small Rooms
"have to keep adjusting for different channels. Don't have to with Terk #4. Tried RCA and it's not much better than GE. VHF 26 miles away ands one UHF 19 are not coming in good. Other three UHF channels are within 15 miles and do o.k. most times, with little adjustments. "
Apr 3 2007
old sarge
Herhsey, Pa.
I am:
  • Practical
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
