Gateway XHD3000 30" Widescreen HD LCD Monitor
3.8
based on 24 reviews
Ratings Distribution
5 star
13
4 star
5
3 star
0
2 star
0
1 star
6
Category Average
4.4
Pros
  • Great picture quality (13)
  • Vivid colors (8)
  • Adjustable (5)
  • Large viewing area (3)
  • Versatile (3)
  • Easy setup (2)
  • Reliable (2)
  • Adjustable viewing angles (1)
  • Big (1)
  • Copious screen realestate (1)
See less See more
Cons
  • Constant black outs (1)
  • Constant brown outs (1)
  • Huge power brick (1)
  • Inaccurate colors (1)
  • It's big (1)
  • Manditory startup music (1)
  • No apple support (1)
  • Rare in retail stores (1)
  • Very pricey (1)
Best Uses
  • Gaming (6)
  • Multimedia (6)
  • Movies (3)
  • Spreadsheets (2)
  • As a door stop (1)
  • Home computer (1)
  • Hooked to a laptop (1)
  • Pc (1)
  • Pc workstation (1)
  • Throw it out the window (1)
Provided by Best Buy
This massive 30" monitor displays high-definition signals all the way to 1080p, is equipped with multiple inputs for connectivity with your home theater system and features 6 USB ports for easy connection to your peripherals.
Specification Description
Model XHD3000
UPC 827103123791
Aspect Ratio 16:10
Connector - Analog Yes
Connector - Digital Yes
Contrast Ratio 1000:1
Response Time (Milliseconds) 6
Screen Resolution - Maximum 2560x1600
Screen Size (Inches/Diagonal) 30
Table Stand Yes
Unit Weight (Approximate Pounds) 27
Gateway XHD3000 30" Widescreen HD LCD Monitor Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: XHD3000 30" Widescreen HD LCD Monitor
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 13, 2009
Gateway XHD3000 30" Widescreen HD LCD Monitor Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Georgeous!
"If you have the bucks, need lots of screen real estate and need versatile inputs, get this monitor! The good reviews across the Net are spot on and I encourage every prospective buyer of large LCDs to do lots of research before buying. This monitor is $200-$300 higher than most other 30 inchers, but the versatility makes a big difference and the quality IS there. But my decision to take time to write a review is..." Read Full Review »
Oct 09, 2008 by Pat
See more positive Gateway XHD3000 30" Widescreen HD LCD Monitor reviews
1.0
Gateway XHD3000 Monitor has known defect
"I purchased one of their 30" HD displays model XHD3000 and it blacked out every hour. So I called them for a replacement and after telling me to try other computers (because I have spare computers to test their broken junk) and after screwing around with me for a week, they told me to send it back and they would replace it. Well, I'll just STARE AT THE WALL for two weeks while they wait for the return and shi..." Read Full Review »
Feb 20, 2009 by I'll Never Buy Another Gateway
See more negative Gateway XHD3000 30" Widescreen HD LCD Monitor reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
Georgeous!
5.0
    Pros
  • Sharp Image
  • Versatile
  • Vivid Colors
    Cons
    Best Uses
  • PC workstation
"If you have the bucks, need lots of screen real estate and need versatile inputs, get this monitor! The good reviews across the Net are spot on and I encourage every prospective buyer of large LCDs to do lots of research before buying. This monitor is $200-$300 higher than most other 30 inchers, but …"  Read Full Review »
Was this LCD Monitor review on the Gateway XHD3000 30" Widescreen HD LCD Monitor helpful to you?
 Report Abuse  (4)  (0)  0 comments
Oct 9 2008
Pat
Woodbury, CT
I am:
  • Quality Oriented
Reviewed at:
1.0
    Pros
  • Big
    Cons
  • Constant Brown outs
    Best Uses
  • As a Door Stop
"I purchased one of their 30" HD displays model XHD3000 and it blacked out every hour. So I called them for a replacement and after telling me to try other computers (because I have spare computers to test their broken junk) and after screwing around with me for a week, they told me to send it back a …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 20 2009
San Jose, CA
I am:
  • Quality Oriented
Reviewed at:
[3 of 4 customers found this review helpful]
Not For Gaming
4.0
    Pros
  • Large Viewing Area
  • Reliable Performance
    Cons
  • None
    Best Uses
  • Movies
  • Spreadsheets
"I bought this monitor to replace my broken desktop LCD and to pull double duty as a T.V. in my room for movies and gaming.
It does all my graphics programs beautifully, Photoshop, 3D Studio Max, Maya, etc. I love watching movies on it, they look terrific.
However, I bought this monitor because …"  Read Full Review »
 Report Abuse  (3)  (1)  0 comments
Jun 18 2008
Mic
San Francisco, CA
I am:
  • Graphics Enthusiast
Reviewed at:
A Really Good Monitor But.......
4.0
    Pros
  • Adjustable
  • Easy Setup
  • Sharp Image
    Cons
  • Inaccurate Colors
  • No Apple Support
    Best Uses
  • Multimedia
  • PC
  • Tv
"The Gateway XHD3000 is a great monitor in that it has all the hook ups you will need for a complete platform. I use the HDMI for my PS3, the S-Video for DirectTV, The DB25 standard VGA for my old Windows NT box and the DVI input for my MacBook Pro.
The DVI with MacBook Pro is were the problems s …"  Read Full Review »
Apr 8 2009
TyComm
MN
I am:
  • Quality Oriented
Reviewed at:
XHD3000
4.0
    Pros
  • Adjustable
  • Sharp Image
  • Vivid Colors
    Cons
    Best Uses
  • Gaming
  • Multimedia
"I did all of the research, and after waffling back and forth I finally came back to the Gateway. This is the monitor you want if you are going to do anything else but the dual-link 2560X1600 connection from your modern graphics card.
If you only need a monitor for your PC and nothing else, there a …"  Read Full Review »
Apr 1 2009
joshsstuff
Pittsburgh, Pa
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
