Gary Fong P4 Lightsphere II Inverted Dome Clear Diffusion System
#61
4.3
based on 20 reviews
from $39.95
Ratings Distribution
5 star
9
4 star
8
3 star
1
2 star
1
1 star
0
Category Average
4.1
Low Price:
$39.95 at B&H Photo Video
 Trusted:
$39.95 at Adorama
Find it at Amazon
Pros
  • Lightweight (14)
  • Softens light (11)
  • Reliable (8)
  • Convenient interface (6)
  • Well built / quality construction (6)
  • Durable (3)
  • Easy to clean (3)
  • Easy to use (3)
  • Consistent output (2)
  • Easily interchangeable (2)
See less See more
Cons
  • Heavy / bulky (3)
  • Dome sometimes pops off (1)
  • Unreliable storage (1)
Best Uses
  • Fill flash (9)
  • Night photography (9)
  • Lighting (7)
  • Photography (6)
  • Photojournalism (6)
  • Portraits (4)
  • Shooting indoors (3)
  • Weddings (3)
  • General purpose (2)
  • Close -ups (1)
Provided by B&H Photo Video
The Gary Fong P4 Lightsphere II Inverted Dome Flash Diffusion System (Clear) - for Canon 580EX Sony HVL-F32X & Vivitar 730AF Flash Units is a large round soft and flexible diffuser that slips over the front of compatible flash units. The inside of the Lightsphere is completely textured to make the light dispersion even more soft than it would be otherwise. And because of this design it is possible to make the material more translucent keeping the unit from losing a lot of light while actually increasing the diffusion and softness of light. The included inverted dome allows you to softly diffuse direct light with a large soft source without creating flare on the front of your lens. This clear version is ideal for fast action large groups and dimly lit scenes.
Gary Fong P4 Lightsphere II Inverted Dome Clear Diffusion System Questions
Questions and Answers
Where to Buy
$39.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$39.95
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Aug 11, 2009
Gary Fong P4 Lightsphere II Inverted Dome Clear Diffusion System Reviews
Most helpful positive review
Most helpful negative review
4.0
Fillup the whole room
"Very nice design diffuser dome. Fill the whole room with light and greatly reduce shadow behind subject. Excellent buy...." Read Full Review »
Jan 01, 2009 by Flooder
See more positive Gary Fong P4 Lightsphere II Inverted Dome Clear Diffusion System reviews
2.0
Not quite
"I've had this diffuser since last October. It kept falling off the Canon 580EX speedlite during the first wedding I used it at....not good. The "teeth", it grips with, should be longer to cover more of the flash. I had to tape it onto the flash. The next wedding, I had problems with my flash firing and was very upset at some of the shots I missed. Later I realized that the hotfoot was separating due to the heav..." Read Full Review »
May 01, 2009 by Looking for a new diffuser
See more negative Gary Fong P4 Lightsphere II Inverted Dome Clear Diffusion System reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
4.0
    Pros
  • Consistent Output
  • Durable
  • Easily Interchangeable
  • Easy To Clean
  • Lightweight
    Cons
  • None
    Best Uses
  • Fill Flash
  • General Use
  • Night Photography
  • Photojournalism
  • Portraits
  • More »
"Very nice design diffuser dome. Fill the whole room with light and greatly reduce shadow behind subject. Excellent buy. "
Great smile!
Great smile!
  • Using Product
  • Made with Product
Was this Camcorder Accessory review on the Gary Fong P4 Lightsphere II Inverted Dome Clear Diffusion System helpful to you?
Jan 1 2009
Flooder
Dallas, TX
I am:
  • Semi-Professional
Reviewed at:
Price: $39.95
[6 of 7 customers found this review helpful]
Gary Fong's Lightsphere Cloud - The BEST
5.0
    Pros
  • Convenient Interface
  • Reliable
  • Softens Light
  • Strong Construction
    Cons
  • None
    Best Uses
  • Fill Flash
  • Lighting
  • Night Photography
  • Photography
  • Photojournalism
"I’ve been using the Lightsphere for a while now and have owned seven Lightsphere units in various versions since the Lightsphere II came out. Of the seven, I still have three for use with my Nikon SB-800’s and Vivitar 283’s. Currently, I’m using the Lightsphere Cloud on the SB-800’s (with and with …"  Read Full Review »
 Report Abuse  (6)  (1)  0 comments
Sep 14 2006
Nikonguy59
Schaumburg, IL
Reviewed at:
Price: $39.95
[4 of 4 customers found this review helpful]
Studio Quality Lighting on the Run
5.0
    Pros
  • Easy to Use
  • Lightweight
  • Makes images look GREAT
  • Reliable
  • More »
    Cons
  • None
    Best Uses
  • Fill Flash
  • Lighting
  • Night Photography
  • Photography
  • Photojournalism
  • More »
"I have used Gary Fong's Lightsphere Inverted Dome System since it came out. I use it for ALL of my lighting situations. We shoot Weddings full time and the Lightsphere is used at over 50 Weddings per year. It works wonderfully in intimate settings as well as giving great light output in dark recepti …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Sep 14 2006
southern girl
Tampa, FL
Reviewed at:
Price: $39.95
Great product, fantastic results!
5.0
    Pros
  • Easy To Use
  • Improves Performance
  • Lightweight
  • Quality Construction
    Cons
  • None
    Best Uses
  • Group Photos
  • Limited available light
  • Portraits
  • Shooting Indoors
"I decided to purchase the Lightsphere 2 clear as I already own and love the Lightsphere Cloud. These diffusers work wonderfully with my Canon 580EX Flash. The LS-2 clear extends my flash range for excellent subject coverage and color detail. The new slip on design is a nice improvement from the e …"  Read Full Review »
Nov 19 2009
A. Bowman
Atlanta, GA
I am:
  • Semi Pro Photographer
  • Tech Savvy
Reviewed at:
Price: $39.95
Great diffuser
5.0
    Pros
  • Consistent Output
  • Durable
  • Easy To Clean
  • Fast Recycling
  • Lightweight
  • More »
    Cons
  • None
    Best Uses
  • General Use
  • Night Photography
  • Portraits
"It works as described. I have no experience with any other diffuser, but here's my experience with this one. It greatly improves indoor shots, and also works well for outdoor fill lighting. I use it whenever I use my flash. The diffuser cone is a flexible plastic, which makes it nigh invincible, …"  Read Full Review »
Jan 21 2008
mikez0r
Davis, CA
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $39.95
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
