Close Login Module
Join
Gary Fong C3 Cloud Lightsphere II, Inverted Dome Flash Diffusion System.
#10
4.4
based on 63 reviews
Ratings Distribution
5 star
36
4 star
18
3 star
6
2 star
2
1 star
1
Category Average
4.1
$39.95
from 2 stores
Pros
  • Lightweight (35)
  • Easy to use (22)
  • Softens light (22)
  • Quality construction (20)
  • Convenient interface (11)
  • Durable (11)
  • Reliable (10)
  • Improves performance (7)
  • Consistent output (5)
  • Easy to clean (5)
See less See more
Cons
  • Bulky (17)
  • Flimsy design (4)
  • Heavy (2)
  • Poor interface (2)
  • Can damage camera (1)
  • Can fall off easily (1)
  • Falls of my 430ex often (1)
  • Falls off tape it (1)
  • Kind of hard to get on (1)
  • Loose fitting (1)
Best Uses
  • Fill flash (22)
  • Lighting (18)
  • Portraits (15)
  • Photography (14)
  • Shooting indoors (11)
  • Night photography (9)
  • Photojournalism (9)
  • Close -ups (6)
  • General purpose (6)
  • Shooting outdoors (6)
Where to Buy
BizRate Rating Outstanding 9.6
$39.95
No Tax Outside NY
BizRate Rating Outstanding 9.1
$39.95
Product Reviews
Last update: Oct 4, 2009
Gary Fong C3 Cloud Lightsphere II, Inverted Dome Flash Diffusion System. Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
5.0
Tupperware move over!
"The first test picture I took was a candid of my 8 year old son doing his homework. Soft shadowless light. One of the best flash pictures I have ever taken. If I could only go back and reshoot all the other pictures taken without a light diffuser...." Read Full Review »
Feb 06, 2007 by Dr Hacnbush
See more positive Gary Fong C3 Cloud Lightsphere II, Inverted Dome Flash Diffusion System. reviews
3.0
Won't stay on my 430EX
"I love the technical abilities of the diffuser, but have been sooo frustrated that the thing falls off all the time. It is true what others have said that combined with how dorky you look with it attached you look even worse chasing it around after it falls off an rolls across the floor. I was a victim of this 3 times today as I shot. Again..effective at producing quality diffusion..when it is ON. One more thi..." Read Full Review »
Feb 08, 2008 by Madphill
See more negative Gary Fong C3 Cloud Lightsphere II, Inverted Dome Flash Diffusion System. reviews
Displaying 1 - 5 of 63 Reviews
Show
Sort by
3.0
    Pros
  • Durable
  • Easy To Use
  • Improves Product Function
    Cons
  • Bulky
  • Loose fitting
    Best Uses
  • Macro Photography
  • Portraits
  • Studio
"I love the technical abilities of the diffuser, but have been sooo frustrated that the thing falls off all the time. It is true what others have said that combined with how dorky you look with it attached you look even worse chasing it around after it falls off an rolls across the floor. I was a vic …"  Read Full Review »
Feb 8 2008
Madphill
Murfreesboro, TN
I am:
  • Semi-Professional
Reviewed at:
Price: $39.95
5.0
    Pros
  • Convenient Interface
  • Lightweight
  • Reliable
  • Softens Light
  • Strong Construction
    Cons
  • None
    Best Uses
  • Lighting
  • Photography
  • Photojournalism
  • Portraits
"The first test picture I took was a candid of my 8 year old son doing his homework. Soft shadowless light. One of the best flash pictures I have ever taken. If I could only go back and reshoot all the other pictures taken without a light diffuser. "
Feb 6 2007
Dr Hacnbush
Dix Hills, NY
Reviewed at:
Price: $39.95
[1 of 1 customers found this review helpful]
Gary Fong is a genious!
5.0
    Pros
  • Easy to Use
  • Reliable
    Cons
  • Bulky
  • Poor Interface
    Best Uses
  • Close -ups
  • Nighttime
  • Special Events
"I have heard in review after review that the "Gary Fong" diffuser is the way to go so I had to try for myself. It really works as advertised. The frosted version produces a very soft exposure great for portraits and close ups. My only complaint is the same as the other reviews, the Lightsphere do …"  Read Full Review »
Nov 19 2008
MIKALI
Wooster, Ohio
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $39.95
[2 of 2 customers found this review helpful]
TupperWare for your flash!
4.0
    Pros
  • Consistent Output
  • Durable
  • Easy To Use
  • Lightweight
    Cons
  • Bulky
    Best Uses
  • Fill Flash
  • General Use
  • Night Photography
  • Photojournalism
  • Portraits
"Yes - it's overpriced. Yes - it's worth it. I love this product and will recommend it. I researched this and was happy to find that the C3 fits the HVL-F56AM external flash for my Sony DSLR. It's snug and *does not come off* unless I remove it. The diffusion is even and smooth. Love it. "
Mar 17 2009
Tutivillus
Utah
I am:
  • Professional
Reviewed at:
Price: $39.95
[3 of 3 customers found this review helpful]
dont be fooled
5.0
    Pros
  • Lightweight
  • Softens Light
    Cons
  • None
    Best Uses
  • Fill Flash
  • Lighting
"when i first opened the pakage i thought " well i just wasted [...] bucks" then after watching the instructional video that came with it, i decided to give it a try on my next shoot. i was blown away by how good it works. come to find out it was the best [...] bucks ive ever spent, not the worst. ca …"  Read Full Review »
Dec 1 2006
Denny's Digital Photography
werren, ar
Reviewed at:
Price: $39.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$39.95
No Tax Outside NY
$39.95
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
