Gary Fong C2 Cloud Lightsphere II Inverted Dome Flash Diffusion System.
#24
4.5
based on 47 reviews
from $39.95
Ratings Distribution
5 star
27
4 star
16
3 star
4
2 star
0
1 star
0
Category Average
4.3
Low Price:
$39.95 at B&H Photo Video
 Trusted:
$39.95 at Adorama
Find it at Amazon
More Images
Pros
  • Lightweight (32)
  • Easy to use (28)
  • Durable (22)
  • Softens light (17)
  • Consistent output (16)
  • Reliable (11)
  • Well built / quality construction (9)
  • Convenient interface (7)
  • Versatile (4)
  • Diffuses light (1)
See less See more
Cons
  • Heavy / bulky (18)
  • Not interchangeable (2)
  • Weak output (2)
  • Fitting in camera bag (1)
  • Odd looking (1)
  • Pricey (1)
  • Slow recycling (1)
  • Top-heavy (1)
  • Unreliable (1)
  • Unreliable storage (1)
Best Uses
  • Fill flash (33)
  • Portraits (29)
  • General purpose (18)
  • Photojournalism (11)
  • Photography (10)
  • Lighting (9)
  • Night photography (9)
  • Close -ups (3)
  • Special events (3)
  • Nighttime (2)
Provided by B&H Photo Video
C2 Lightsphere II Inverted Dome Cloud Diffusion System
Gary Fong C2 Cloud Lightsphere II Inverted Dome Flash Diffusion System. Questions
Questions and Answers
Where to Buy
$39.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$39.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Nov 14, 2009
Gary Fong C2 Cloud Lightsphere II Inverted Dome Flash Diffusion System. Reviews
Most helpful positive review
Most helpful negative review
4.0
Great diffuser! Got the job done!
"I did alot of looking at various diffusers and read a number of reviews before finally selecting this Gary Fong product. The Lightsphere Inverted Dome works wonderfully, softly and evenly illuminating not only the subject, but the surroundings as well (thus getting rid of that harsh flash look on the subject with resulting black or dark background). The Lightsphere II Inverted Dome is easy to put on and take o..." Read Full Review »
Jul 18, 2009 by Montana Becky
See more positive Gary Fong C2 Cloud Lightsphere II Inverted Dome Flash Diffusion System. reviews
3.0
Heavier than expected
"I found that this product does a nice job of diffusing my external flash. However, I was surprised to find it heavier than I expected. In fact, I am rarely able to use my flash at a 45-degree angle (from straight up); the diffuser's weight pulls the flash down to a 90-degree angle. It can be difficult if I am moving my camera quickly from horizontal to vertical (and vice versa) and rotating the flash. The weight..." Read Full Review »
Feb 11, 2009 by Triathlete in Training
See more negative Gary Fong C2 Cloud Lightsphere II Inverted Dome Flash Diffusion System. reviews
Displaying 1 - 5 of 47 Reviews
Show
Sort by
4.0
    Pros
  • Durable
  • Easy To Use
  • Flexible enough to pack
    Cons
  • Top-Heavy
    Best Uses
  • Fill Flash
  • General Use
  • Photojournalism
  • Portraits
"I did alot of looking at various diffusers and read a number of reviews before finally selecting this Gary Fong product. The Lightsphere Inverted Dome works wonderfully, softly and evenly illuminating not only the subject, but the surroundings as well (thus getting rid of that harsh flash look on t …"  Read Full Review »
Wedding Photographer Self Portrait
  • Made with Product
Was this Camera Flash review on the Gary Fong C2 Cloud Lightsphere II Inverted Dome Flash Diffusion System. helpful to you?
Jul 18 2009
Montana Becky
Angleton, TX
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $39.95
So far so good
4.0
    Pros
  • Consistent Output
  • Durable
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Fill Flash
  • General Use
  • Portraits
"This really tames the harsh light of direct flash. If you don't have the means to get your flash off camera and diffused by some other method then this is the way to go. "
This is one of my first shots with the diffuser.
  • Made with Product
May 4 2009
Andrew from NYC
NYC
I am:
Reviewed at:
Price: $39.95
Excellent Diffuser
5.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
    Cons
  • Bulky
    Best Uses
  • Fill Flash
  • General Use
  • Night Photography
  • Photojournalism
  • Portraits
"Does a great job at evenly lighting the area. Some photographers will tilt it at a 45 degree angle but I've noted that this will significantly brightly your photos which may cause them to be overexposed, depending on the subject's distance. I usually just leave it straight up or pointed at the subje …"  Read Full Review »
Nov 14 2009
Miguel
Vancouver, WA
I am:
  • Semi-Professional
Reviewed at:
Price: $39.95
Does what it should
5.0
    Pros
  • Consistent Output
  • Durable
  • Easy To Use
  • Lightweight
    Cons
  • None
    Best Uses
  • Fill Flash
  • General Use
  • Portraits
"As an event photographer (weddings, bar & bat mitzvahs) I need well-exposed shots. This allows me to do that in less than ideal situations without harsh shadows. While it looks like a small fruit bowl on your flash it does the job. I am very happy with this product. "
Nov 11 2009
ACME-PHOTOS
West Hartford, Ct
I am:
  • Professional
Reviewed at:
Price: $39.95
Still new to it.
4.0
    Pros
  • Consistent Output
  • Easy To Use
  • Lightweight
    Cons
  • Bulky
    Best Uses
  • Fill Flash
  • General Use
  • Portraits
"I definitely like this lightsphere a LOT better than the attachable softbox I bought about 4 months ago. It spreads the light out nice and even without any open slits where light rays can seep into a shot. I love that it's easy to get on and off and doesn't require you to gunk up your flash with v …"  Read Full Review »
Feb 20 2009
Pete
Germantown, MD
I am:
  • Semi-Professional
Reviewed at:
Price: $39.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
