Garmin StreetPilot C340 GPS Unit
#11
4.5
based on 265 reviews
Ratings Distribution
5 star
179
4 star
65
3 star
12
2 star
1
1 star
8
Category Average
4.1
Low Price:
$150.59 at NuGadgets
$239.99 at Gander Mountain
Find it at Amazon
$150.59 - $239.99
from 2 stores
More Images
Pros
  • Easy setup (23)
  • Simple controls (22)
  • Easy to read (21)
  • Easy menus (20)
  • Reliable (20)
  • Acquires satellites quickly (16)
  • Compact (16)
  • Accurate maps (4)
  • Easy to follow directions (4)
  • Nice visual interface (4)
See less See more
Cons
  • Acquires satellites slowly (4)
  • Bulky (2)
  • Charge for updates (1)
  • Flimsy mounting (1)
  • Never worked (1)
  • Newer roads are missing (1)
  • Poor battery life (1)
  • Poor support (1)
  • Uses wrong route (1)
Best Uses
  • Finding specific address (18)
  • Faster routes (16)
  • Urban navigation (13)
  • Rural navigation (12)
  • Planning trips (11)
  • Highway driving (4)
  • Geocaching (2)
  • Larger cars (2)
  • Small cars (2)
  • Anywhere it works (1)
Provided by Buzzillions.com
Beat the Traffic Before it Beats You The StreetPilot c340 provides in-car navigation that is simple for anyone to use directly out of the box. After selecting a destination from the user-friendly touch screen interface, Garmins text-to-speech feature tells users the name of the street, when to turn, and in what direction. If you miss your turn, the c340 automatically calculates a new route to the destination. Notification of traffic delays is a c340 option that lets drivers see congested areas via a color-coded map. This feature lets users avoid traffic by simply pushing a button that will calculate a new route. This traffic awareness is made possible via the new Garmin GTM 10 FM TMC receiver that connects to selected Garmin street navigation products. The GTM 10 receives digital data from specific FM broadcast stations in select major metro areas throughout the United States and Europe. The StreetPilot c340 comes preprogrammed with highly detailed City Navigator NT street data of the entire United States, Canada, and Puerto Rico. The database features nearly six million points of interestincluding hotels, restaurants, gas stations, ATMs, and attractions. As an added benefit, you can now import customized points of interest with the help of Garmin's free POI Loader software. The possibilities are endless upload safety cameras or school zones, and you will receive a warning if you are traveling too fast. In addition, an optional proximity-alert feature notifies you of upcoming custom POIs. The StreetPilot c340 joins Garmins growing line of automotive GPS navigators. It has a bright, 3.5-inch diagonal, TFT display with touchscreen; dual integrated speakers for high-quality voice prompts; and an internal lithium-ion battery for out-of-car route planning. The StreetPilot c-series boasts distinctive and sleek stylingthe units only buttons are a rotary volume knob and an on/off switch. The device is secured by a suction-mount cradle that fastens to the windshield, for easy portability between vehicles. Users can customize their units appearance with an array of colored faceplates (sold separately).
FEATURES
  • WAAS-enabled 12 parallel channel GPS
  • Built-in patch antenna; MCX-type connector for optional external GPS antenna connection
  • Preloaded with detailed U.S., Canada & Puerto Rico maps - no downloading required
  • SD memory card expansion slot for use with other MapSource street-mapping products
  • Traffic alerts with optional GTM 10 FM TMC traffic receiver*
  • Text-to-Speech - unit prompts you to "Turn right on Main St" instead of "Turn right in 500 feet"
  • Audible and visual navigation instructions and warnings
  • Users can set up proximity alerts for school zones, safety cameras, and more with Garmin's POI loader program (free from www.garmin.com)
  • Choose between a three-dimensional mapping perspective or 2D overhead view
  • Display: 2.8"W x 2.1"H (3.5" diag.), 320 x 240 pixels; bright, TFT display, 64K colors, with white backlight and touch screen
  • Unit dimensions: 4.4" W x 3.2" H x 2.8" D
  • Weights just 9.4 ounces
  • Built-in lithium ion battery for trip planning (approximately 4-8 hours battery life)
  • Includes integrated 12-volt power adapter/speaker for external power while in your vehicle
  • Integrated suction-cup mounting system provides easy adjustment and quick release
  • USB interface
  • *NOTE: Traffic services available only in select cities where RDS-TMC coverage exists. Requires the GTM 10 FM TMC traffic receiver and possible subscription to enable traffic capability.
    Specifications
    Moving Map Features Storage Pre-programmed with City Navigator, providing street-level detail and addresses, plus listings of nearest restaurants, hotels, ATMs, etc., throughout the U.S.,Canada and Puerto Rico
    Map Scale Screen-width scale 640 feet to 4,000 miles
    Navigation Features Routes Automatically calculated with turn-by-turn instructions; custom road preference allows user to prioritize choice of back roads or major highways; automatic off-route recalc shows how to get back on track if you miss a turn or exit; a detour function enables routing around traffic problems or road construction
    Voice Navigation instructions and warnings
    Waypoints 500 with name and graphic symbol
    Trip computer Resettable odometer, timers, average and maximum speeds
    GPS Performance Receiver WAAS-enabled;12 parallel channel GPS receiver continuously tracks and uses up to 12 satellites to compute and update your position
    Acquisition times Warm: Approximately 15 seconds
    Cold: Approximately 45 seconds
    AutoLocate: Approximately 2 minutes
    Update rate: 1/second, continuous
    GPS Accuracy Position: < 15 meters (49 feet), 95% typical
    Velocity: 0.05 meter/sec steady state
    GPS (WAAS) Accuracy:
    Position: < 3 meters, 95% typical
    Interfaces: 1/second, continuous
    Antenna Built-in patch; MCX-type connector for optional external GPS antenna connection
    Physical Size 4.4" W x 3.2" H x 2.8" D (11.3 x 8.2 x 7.2 cm)
    Weight .59 pounds (269 g)
    Display 2.8" W x 2.1" H (7.2 x 5.4 cm); 320 x 240 pixels; bright, 16-bit LCD, with white backlight and touch screen
    Case Not waterproof or IPX0
    Temp. range 32F to 140F (0C to 60C)
    Data storage Indefinite; no memory battery required
    Power Input 12/24 Vdc
    Usage 15w max. @ 13.8 Vdc
    Battery Life up to 8 hours
    Package Includes
    Items StreetPilot c340 receiver w/built-in antenna
    Americas Lite Routable basemap
    City Navigator North America NT preprogrammed
    Dual internal speaker system for voice guidance and alerts
    Vehicle suction cup mount w/12-24 volt adapter
    Dashboard disk
    USB interface cable
    Quick-reference guide
    Accessories
    A/C Adapters 010-10618-00 A/C charger
    Antennae 010-10052-05 GA 27C low profile remote automobile antenna
    010-10702-00 GA 25MCX low profile remote GPS antenna (integrated magnetic mount, 9.5 ft. cable, MCX connector)
    Antennas - Accessories 010-10061-00 GA 26/27 series trunk lip antenna mount
    010-10062-00 GA 26/27 series flange antenna mount
    010-10139-00 GA 26/27 series antenna suction cup mount (replacement)
    010-10157-00 8 ft. Extension cable for GA 27 series antenna
    Bracket Mounts 010-10609-00 Vehicle suction mount with 12/24-volt adapter
    010-10613-00 Dash mount
    Cables 010-10477-03 PC/USB cable (replacement)
    010-10682-00 GTM 10 Install cable, FAKRA F to Motorola M/F (replacement)
    010-10682-01 GTM 10 Install cable, FAKRA F to ISO M/F (replacement)
    010-10682-02 GTM 10 Install cable, FAKRA only, 2-pack (replacement)
    010-10682-03 GTM 10 Install cable, FAKRA F to GM M/F (replacement)
    Datacards 010-10636-00 128 MB SD memory card
    010-10636-01 256 MB SD memory card
    010-10636-02 512 MB SD memory card
    Other 010-00396-10 GTM 10, FM TMC traffic receiver (Americas version includes 15 mo service)
    010-00396-60 GTM 11, FM TMC traffic receiver (Americas version includes 15 mo service)
    010-10608-00 Faceplate, 5-pack
    010-10608-01 Faceplate, 5-pack
    010-10646-00 Dashboard disk (small), 2-pack
    010-10704-00 Carry case
    010-10705-00 Protective cover
    Software 010-10359-00 MapSource City Select Europe
    010-10373-00 MapSource City Navigator Europe
    010-10389-00 MapSource City Navigator Australia
    010-10400-00 MapSource City Select South Africa
    010-10473-00 MapSource City Select North America
    010-10474-00 MapSource City Navigator North America
    010-10560-00 MapSource City Navigator Middle East
    Note: MapSource Trip and Waypoint management functions are compatible with most GARMIN GPS units. The map download feature is compatible with several select GARMIN GPS units. Please see the MapSource Page for complete compatibility details
  • Specification Description
    Model 010-00401-20, 010-00401-73, 010-N0401-20, 0100040120
    UPC 753759050658
    Backlit Display Yes
    Battery Life Up to 6 to 8 Hours
    Brand Name Garmin
    Car Navigation Units 3" Screens
    Card Slot for upgrades Yes
    color null
    Computer Connectivity USB
    Country Of Origin United States
    Display Color
    Display Screen 320 x 240 Pixels
    Display Screen Height 2.1 inches
    Display Screen Width 2.8 inches
    GPS Style Vehicle - Car
    Included Map North America
    Manufacturer Garmin, Ltd
    Manufacturer Website Address www.garmin.com
    Number of Channels 12
    Power Source Rechargeable Lithium-Ion Battery
    Rechargeable Battery Pack Yes
    Screen Size (Approximate) 3.5" Inch Diagonal
    size null
    sku 103981
    skuprice 399.9900
    style GRM0040173
    taxable Y
    Type of GPS Vehicle
    Type: GPS Automotive
    Unit Depth 2.8 inches
    Unit Height 3.2 inches
    Unit Width 4.4 inches
    Voice Guidance Included
    Garmin StreetPilot C340 GPS Unit Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Jun 13, 2009
    Garmin StreetPilot C340 GPS Unit Reviews
    Most helpful positive review
    [6 of 6 customers found this review helpful]
    Most helpful negative review
    5.0
    Great Product, Great Price!!!!
    "This is my first GPS and it is really awesome. I looked far and wide - consumers reports, CNET reviews and opinions, etc. Someone will always say something bad about every model of GPS. I looked at the Magellan brand, and applause to them for linking up with AAA, but the brand overall seemed to have more than its fair share of complaints. The Garmin brand, however, seemed to less than its fair share of complaint..." Read Full Review »
    Mar 24, 2008 by Always Lost John
    See more positive Garmin StreetPilot C340 GPS Unit reviews
    1.0
    Don't trust Garmin
    "The current price for the C340 is great --- I paid [$] in Jan. 2006. However, buyers beware: Garmin no longer supports this GPS. I wanted to up-date the maps (June 2009). Customer service told me that 1. I had to buy an up-date made for their new line of GPS for [$] (check the current price of the unit) and 2. the up-date would not fit into the memory of the C340. Garmin no longer provided up-dated maps for..." Read Full Review »
    Jun 13, 2009 by Ken
    See more negative Garmin StreetPilot C340 GPS Unit reviews
    Displaying 1 - 5 of 265 Reviews
    Show
    Sort by
    5.0
      Pros
    • None
      Cons
    • None
      Best Uses
    • Faster Routes
    • Finding Specific Address
    • Planning Trips
    • Rural Navigation
    • Urban Navigation
    "This is my first GPS and it is really awesome. I looked far and wide - consumers reports, CNET reviews and opinions, etc. Someone will always say something bad about every model of GPS. I looked at the Magellan brand, and applause to them for linking up with AAA, but the brand overall seemed to have …"  Read Full Review »
    Was this Car GPS review on the Garmin StreetPilot C340 GPS Unit helpful to you?
     Report Abuse  (6)  (0)  0 comments
    Mar 24 2008
    Always Lost John
    Edmond, OK
    I am:
    • Bad With Directions
    • Frequent Traveler
    [8 of 8 customers found this review helpful]
    Easy to program
    5.0
      Pros
    • Accurate Maps
    • Easy Controls
    • Easy for electronic idiot
    • Easy To Follow Directions
    • Nice Visual Interface
    • More »
      Cons
    • None
      Best Uses
    • Great for detours
    • Highway Driving
    • Rural Driving
    "I am an "electronic idiot" senior citizen. I didn't have a bit of trouble programming this unit or understanding it's instructions !!!!!
    No more getting lost at unexpected detours. HOORAY !!!!!!!!!! "
     Report Abuse  (8)  (0)  0 comments
    Oct 23 2006
    Grandma wanderer
    Chicago. Ill
    Don't trust Garmin
    1.0
      Pros
    • Easy Menus
    • Easy To Read
    • Easy To Set Up
    • Large Screen
    • Simple Controls
      Cons
    • NO SUPPORT
      Best Uses
    • None
    "The current price for the C340 is great --- I paid [$] in Jan. 2006. However, buyers beware: Garmin no longer supports this GPS. I wanted to up-date the maps (June 2009). Customer service told me that 1. I had to buy an up-date made for their new line of GPS for [$] (check the current price of t …"  Read Full Review »
    Jun 13 2009
    Washington, DC
    I am:
    • Power User
    Great product
    5.0
      Pros
    • Acquires Satellites Quickly
    • Compact
    • Easy Menus
    • Easy To Read
    • Easy To Set Up
    • More »
      Cons
    • None
      Best Uses
    • None
    "I do love my garmin - use with a grain of salt though- does not find new places well, as maps are already outdated when you open it. So best use is with a website of the company to be sure. By that I mean - if you are in orlando and want an outback steakhouse, get on the website, search for the ad …"  Read Full Review »
    Jun 22 2008
    lake worth fl
    I am:
    • Frequent Traveler
    Easy to use, full featured, Great Value
    5.0
      Pros
    • Compact
    • Easy Menus
    • Easy To Read
    • Easy To Set Up
    • Reliable Performance
    • More »
      Cons
    • None
      Best Uses
    • Faster Routes
    • Rural Navigation
    • Urban Navigation
    "I got the 340 for Christmas, but am just getting around to reviewing it. It's really a great choice, a very good value compared to other models. Works right out of the box--gets me to where i am going everytime. Easy to use with your choice of computerized voices, plus either 2D and 3D views.
    Th …"  Read Full Review »
    Mar 24 2008
    GadgetGuy
    Grand Rapids, MI
    I am:
    • Frequent Traveler
    • Gearhead
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
