Garmin StreetPilot C330 Car Navigation System
4.4
based on 117 reviews
Ratings Distribution
5 star
66
4 star
38
3 star
8
2 star
3
1 star
2
Category Average
4.1
More Images
Pros
  • Reliable (27)
  • Easy to read (22)
  • Easy setup (21)
  • Simple controls (21)
  • Good value (16)
  • Easy menus (14)
  • Durable (11)
  • High quality (10)
  • Acquires satellites quickly (9)
  • Compact (8)
See less See more
Cons
  • Heavy / bulky (4)
  • Acquires satellites slowly (3)
  • Flimsy mounting (3)
  • Inaccurate (3)
  • Poor battery life (3)
  • Complicated controls (2)
  • No traffic alerts (2)
  • Difficult menus (1)
  • Difficult to see in sun (1)
Best Uses
  • Auto (10)
  • Finding specific address (10)
  • Planning trips (10)
  • Travel (8)
  • Faster routes (7)
  • Urban navigation (7)
  • Rural navigation (6)
  • Adventure (4)
  • Highway driving (3)
  • Larger cars (3)
Our StreetPilot "c-series" GPS navigators feature a simple touchscreen interface, with automatic route calculation to any destination and turn-by-turn voice-prompted directions along the way. Selecting a destination is straightforward and requires only a limited amount of input from the user. Plus, the StreetPilot c330 allows you to choose between a three-dimensional navigation view or the more traditional “bird’s eye” overhead view.
For the ultimate out-of-the-box convenience, the StreetPilot c330 comes preprogrammed with highly detailed City Navigator® street data. The database features nearly six million points of interest—including hotels, restaurants, gas stations, ATMs, and attractions.
As an added benefit, import customized points of interest with the help of Garmin's free POI Loader software. The possibilities are endless — upload safety cameras or school zones, and you will receive a warning if you are traveling too fast. In addition, an optional proximity-alert feature notifies you of upcoming custom POIs.
The centerpiece of the c330 is a bright, 3.5-inch diagonal, 16-bit color display that makes navigation a snap. The unit also features dual integrated speakers for high-quality voice prompts, and an internal lithium-ion battery for out-of-car route planning.
The new StreetPilot c-series boasts distinctive and sleek styling—the only buttons are a rotary volume knob and an on/off switch. The device is secured by a suction-mount cradle that fastens to the windshield for easy portability between vehicles. Users can customize their unit’s appearance with an array of colored faceplates (sold separately).
Product Features
  • Receiver: WAAS-enabled 12 parallel channel GPS
  • Display: 2.8” W x 2.1” H (3.5” diag.), 320 x 240 pixels; QVGA transflective TFT with 16-bit color; 64K colors; bright white LED backlight and touch screen
  • Unit dimensions: 4.4” W x 3.2” H x 2.8” D
  • Weight: 9.45 ounces
  • Battery life: up to 8 hours
  • Preloaded maps for all of North America or Europe
  • Fingertip touchscreen interface
  • Look up addresses and points of interest
  • Choose 2D or 3D map perspective
  • Upload custom POIs, including alerts for speed zones and safety cams
  • SD memory card expansion slot
Specification Description
Model 010-00401-10, 010-N0401-1, 010-N0401-10, 0100040110
UPC 753759047917
Car & Motorcycle Units 3" Screens
Garmin StreetPilot C330 Car Navigation System Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: StreetPilot C330 Car Navigation System
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 10, 2009
Garmin StreetPilot C330 Car Navigation System Reviews
Most helpful positive review
[22 of 22 customers found this review helpful]
Most helpful negative review
[3 of 4 customers found this review helpful]
5.0
Horray for Garmin!!!!!!
"I am in construction so travel to different places for work. Used Mapquest before I got my Garmin. Day after I got the Garmin used it and shortened my trip 15 miles. Directions are fantastic. Can't say enuff good things about this. I researched all of them and the StreetPilot330 was given highest ratings. 340 and 350 seem to lock up, two friends have them. Would highly recommend it to anyone considering a ..." Read Full Review »
Jan 04, 2007 by petesneat
See more positive Garmin StreetPilot C330 Car Navigation System reviews
3.0
C330
"I got this unit free when I purchased a used car from a Car dealer. Free is always good but this unit, while it works OK, is not nearly as good as my two Magellan's (Maestro 3100 & 3200). I'd pick my Magellan's over the model Garmin any day...." Read Full Review »
Mar 26, 2008 by neax
See more negative Garmin StreetPilot C330 Car Navigation System reviews
Displaying 1 - 5 of 117 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Read
  • Easy To Set Up
  • Reliable Performance
  • Simple Controls
  • Strong Construction
    Cons
  • None
    Best Uses
  • Adventure
  • Auto
  • Travel
"I am in construction so travel to different places for work. Used Mapquest before I got my Garmin. Day after I got the Garmin used it and shortened my trip 15 miles. Directions are fantastic. Can't say enuff good things about this. I researched all of them and the StreetPilot330 was given highes …"  Read Full Review »
Was this Car GPS review on the Garmin StreetPilot C330 Car Navigation System helpful to you?
 Report Abuse  (22)  (0)  0 comments
Jan 4 2007
petesneat
Summit, New Jersey
Reviewed at:
[18 of 19 customers found this review helpful]
Portable and EASY to use!
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"This was my first navigation system and it works great! The screen is large enough to see while the unit is still compact. Perfect for business travel, take this unit wherever you go and plug it in any rental car. If you make a wrong turn it quickly recalculates your map and directions and has an …"  Read Full Review »
 Report Abuse  (18)  (1)  0 comments
Nov 12 2006
DH
Bayville, NJ
Reviewed at:
[8 of 8 customers found this review helpful]
EXCELENT PRODUCT FOR THE MONEY
5.0
    Pros
  • Easy To Read
  • Easy To Set Up
  • Simple Controls
    Cons
  • NONE FOR THAT PRICE
    Best Uses
  • Adventure
  • Auto
  • Travel
"I bought the Garmin C330 few days ago, it comes ready to use right out of the box. No setups no computer downloads required.You take it out and bam you go where you need to go. The maps are very accurate, excelent screen bright colors, easy to use. its just perfect and very inexpensive. I think This …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Jan 27 2007
Luke.P
Brooklyn NYC
Reviewed at:
[3 of 3 customers found this review helpful]
MARRIAGE SAVER
4.0
    Pros
  • Acquires Satellites Quickly
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • Inaccurate
  • TME MAP UPDATES NEED TO B
    Best Uses
  • Faster Routes
  • Finding Specific Address
  • Planning Trips
"WE JUST MADE A TRIP DOWN TO TEXAS AND WOW "LULU" WAS GREAT. SHE ONLY MADE A COUPLE OF MISTAKES WHEN A BYPASS AROUND A TOWN HAD BEEN MADE AND SOME HOTELS WHERE ON THE WRONG SIDE AND SOME GAS STATIONS WHERE NO LONGER. BUT EVEN WITH SOME GILICHES SHE SURE HELPED WITH THE DRIVING AND FOR ONCE BOTH OF US …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
May 23 2008
HOGG
STEINBACH, MB
I am:
  • Frequent Traveler
[13 of 14 customers found this review helpful]
No More Nagging from the Wife
5.0
    Pros
  • Durable
  • Easy to use
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • Car Navigation
"How did I live without this great product. No more stopping in gas stations asking for directions. No more arguments about directions with my wife...Garmin you'e a life saver. "
 Report Abuse  (13)  (1)  0 comments
Nov 15 2006
Thomas
Pittsburg, PA
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
