Garmin nuvi® 5000 GPS Receiver
#186
3.4
based on 14 reviews
Ratings Distribution
5 star
3
4 star
6
3 star
0
2 star
3
1 star
2
Category Average
4.1
$199.98 - $587.00
from 14 stores
More Images
Pros
  • Compact (3)
  • Easy to read (3)
  • Easy setup (2)
  • Large screen (2)
  • Reliable (2)
  • Simple controls (2)
  • Easy menus (1)
  • Versatile (1)
  • Well built / quality construction (1)
See less See more
Cons
  • Acquires satellites slowly (1)
  • Complicated controls (1)
  • Difficult menus (1)
Best Uses
  • Finding specific address (2)
  • Rural navigation (2)
  • Urban navigation (2)
  • Adventure (1)
  • Auto (1)
  • Faster routes (1)
  • Planning trips (1)
  • Travel (1)
Provided by BoatersWorld.com
Get big-time navigation and mapping with the large screen nüvi 5000. This super-sized navigator is designed for RV and truck drivers and gives a big picture of the route ahead without obstructing your view. It features a whopping 5.2 inch display, preloaded maps, an FM transmitter and lots of entertainment features for fun on the open road.
See Even More
With nüvi 5000's large, clear display, you wont miss a thing. View map detail, driving directions, photos, play games and more in bright, brilliant color. Its sunlight-readable, 5.2-inch display is easy to read and gives you an extended view of your surroundings. nüvi 5000 also includes a composite video input so you can connect it to a rear-view camera for backing up safely.
Navigate With Ease
nüvi 5000 comes with preloaded City Navigator® NT street maps and millions of points of interest (POIs) such as hotels, restaurants, fuel stations, ATMs and more. Touch the color screen to enter a destination, and nüvi takes you there with 2D or 3D maps and turn-by-turn voice directions. It even announces the name of exits and streets so you never have to take your eyes off the road, and its 3D digital elevation map view gives you fair warning of grade changes. nüvi 5000 also accepts custom points of interest, such as school zones and safety cameras and lets you set proximity alerts to warn you of upcoming POIs.
Where Am I?
In the event of an emergency, nüvis "Where Am I?" feature helps find the closest hospitals, police stations, fuel stations, nearest address and intersection. Also see your exact latitude and longitude coordinates.
Plan Ahead
nüvi 5000 includes advanced navigational features to take the worry out of traveling. With route planning, you can save 10 routes, specify via points and preview simulated turns on the 5000's wide screen. In addition, nüvi 5000 automatically sorts multiple destinations to provide an efficient route for errands or deliveries. It also displays speed limits for highways and Interstates. A trip log provides an electronic breadcrumb trail of up to 10,000 points, so you can see where you've been on the map.
Go Beyond Navigation
Navigation is just the beginning. nüvi 5000 includes many "must have" entertainment and travel tools including MP3 player, audio book player (subscription to Audible.com required), JPEG picture viewer, games and more. With nüvi 5000's wireless FM transmitter you can hear audio, including voice prompts, MP3s and audio books, through your vehicle's stereo. It's also compatible with FM traffic alerts or MSN® Direct content (receiver and subscription required). It comes with Garmin Lock™ (an anti-theft feature) and configurable vehicle icons that let you select car-shaped graphics to show your location on the map. Optional plug-in SD cards let you add additional features to enhance your travel experience including language translation and detailed travel guides. Our SaversGuide® provides information on nearby merchants offering discounts to customize your nüvi.
nüvi 5000: Navigation better than life-size
Specification Description
Model 010-00639-10, 0100063910, 753759071431, GRM0063910
UPC 753759071431
2D/3D view Yes
Antenna Built-in
Anti-glare Yes
Anti-theft device Yes
Audio book player Yes
Auto routing/rerouting Yes
Available memory Internal solid state
Backlight Yes
Benefits Preloaded City Navigator® NT street maps and millions of points of interest (POIs)Automatically sorts multiple destinations to pr
Body Material ABS plastic
Cables Included USB cable, Vehicle power cable
Cables Included Vehicle power cable, USB cable
Capacity UOM mAh
Color support Yes
Connections USB (1)MCX (external antenna) input (1)1/8" headphone output (1)RCA composite video input (1)
Connectivity USB
Country Of Origin Taiwan
Description Header Sometimes size really does matter.
Digital music capability MP3 player
Display Catalog Number 20-339
Display Catalog Number 55027355
Display size (diagonal) 5.0 inches
Display size (diagonal) 5.2 inches
End Product Indicator Yes
Expandable Memory SD card
External antenna connection Yes
Features 5.2" anti-glare WVGA color TFT with auto-dimming backlightVoice Guidance/Text-to-Speech featureDigital elevation maps show s
FM radio capability Yes
GPS type Car
Included in the Box nüvi 5000 preloaded City Navigator® NT for North AmericaVehicle suction cup mountVehicle power cableDashboard d
Inputs 1 x RCA(Composit video in), 1 x MCX(External antenna)
Manufacturer Labor Warranty 12
Manufacturer Part Number 010-00639-10
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps Preloaded City Navigator® NT
Maps Preloaded City Navigator® NT street maps of North America
Menu navigation Touchscreen
Model 0100063910
Model Nuvi 5000
Mounting options Windshield
Number of waypoints 3000
Operating Temperature UOM ° F
Other features This USB mass storage device is compatible with Windows® 2000 or later and Mac® OS X 10.4 or later.
Outputs 1 x Phone 1/8"(Headphone/line-out)
Photo viewer Yes
Points of interest Millions preloaded
Power Device USB cable, vehicle power cable
Product Depth 0.8
Product Dimensions UOM inches
Product Disclaimer *Subscription to Audible.com required Drivers in California and Minnesota should not use the suction mount on their windshield or side or rea
Product Disclaimer *Subscription to Audible.com required.
Product Height 3.71
Product Type Car
Product Weight 9.29
Product Weight UOM ounces
Product Width 5.65
Required to function This USB mass storage device is compatible with Windows® 2000 or later and Mac® OS X 10.4 or later.
Resolution 800x480
Resolution 800x480 pixels
Routes 10
Routing options Auto sort multiple destinations, auto re-route, choice of route setup (faster time, shorter distance, off road), route avoidance (avoid highways, toll
Supported Languages English
Touchscreen Yes
Type WVGA
Type WVGA color TFT with auto dimming backlight
Updatable Maps Yes
Uploadable Maps SD card
Voice Guidance Yes
Waypoints Yes
Garmin nuvi® 5000 GPS Receiver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 28, 2009
Garmin nuvi® 5000 GPS Receiver Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[15 of 21 customers found this review helpful]
4.0
Pros the self diming ...
"Pros the self diming feature transitions nicely, and adjusts well so that you can always see it without being too bright, however is a little anoying when driving under street lights, as bightness fluctuates. although i havent used any of the other features such as audio book, mp3 player, storing pictures, composit vidio input for a rear view camera, the camera input will be nice for a blind spot camera on my s..." Read Full Review »
Dec 04, 2008 by freespirit
See more positive Garmin nuvi® 5000 GPS Receiver reviews
1.0
Very Unhappy With This Device
"Pros Size and that is about it. Cons Will not operate without power source (No Battery!!!) Update to software is impossible...you have to keep going from your computer to your car. Garmin support hold time 60 min.+ and no followup or answer to email. I dumpted this and ordered a Navigon 7100 within 24 hours of getting the Garmin. Will never get Garmin again...." Read Full Review »
Jul 02, 2008 by jtnaustin
See more negative Garmin nuvi® 5000 GPS Receiver reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
1.0
"Pros
Cons
Will not operate without power source (No Battery!!!) Update to software is impossible...you have to keep going from your computer to your car. Garmin support hold time 60 min.+ and no followup or answer to email. I dumpted this and ordered a Navigon 7100 with …"  Read Full Review »
Was this Car GPS review on the Garmin nuvi® 5000 GPS Receiver helpful to you?
 Report Abuse  (15)  (6)  0 comments
Jul 2 2008
jtnaustin
Austin, TX
4.0
"Pros
although i havent used any of the other features such as audio book, mp3 player, storing p …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Dec 4 2008
freespirit
Spokane Wa
I would buy this again
4.0
    Pros
  • Compact
  • Easy To Read
  • Large Screen
    Cons
  • Complicated Controls
  • Difficult Menus
    Best Uses
  • Finding Specific Address
  • Rural Navigation
  • Urban Navigation
"Nice to have a larger screen, love the voice commands when in a large metro area. Colors are great. Don't like the menu set-up and that it still doesn't know my home street after it has been in existence 25 years. "
Oct 28 2009
Captain
Iowa
I am:
  • Enthusiast
Reviewed at:
Price: $249.00
[2 of 3 customers found this review helpful]
If you want a big screen, THIS IS IT!!!
4.0
"I really fell in love with this Nuvi 5000 when I saw this for the first time at the store. The size of the screen (5.2 inches diagonal) was what made me purchase this. I owned a Nuvi 350 that always met my expectation but I needed an upgrade which enables me to connect to MSN Direct and was looking …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Feb 18 2008
Manakachan
Los Angeles, CA
[2 of 2 customers found this review helpful]
Wide screen makes viewing easier.
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • Large Screen
  • More »
    Cons
  • Acquires Satellites Slowly
    Best Uses
  • Faster Routes
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"The user interface is easy to use and helps when finding specific locations in a city. "
 Report Abuse  (2)  (0)  0 comments
Jun 24 2009
Game to Be
Jeffersonville, IN
I am:
  • Casual User
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
