Close Login Module
Join
Garmin Nuvi 205 GPS Navigation System
#8
4.5
based on 186 reviews
Ratings Distribution
5 star
145
4 star
63
3 star
11
2 star
4
1 star
5
Category Average
4.1
$109.99 - $142.99
from 16 stores
More Images
Pros
  • Easy setup (80)
  • Compact (79)
  • Easy to read (79)
  • Easy menus (72)
  • Simple controls (69)
  • Acquires satellites quickly (68)
  • Reliable (62)
  • Large screen (29)
  • Quality construction (2)
  • Affordable (1)
See less See more
Cons
  • Acquires satellites slowly (12)
  • Poor battery life (6)
  • Difficult menus (5)
  • Flimsy mounting (3)
  • Inaccurate (3)
  • Depending on where you ar (1)
  • Like to hear street names (1)
  • Limited business listings (1)
  • No auto reroutes (1)
  • No compass rose (1)
Best Uses
  • Finding specific address (67)
  • Planning trips (47)
  • Faster routes (43)
  • Urban navigation (42)
  • Rural navigation (37)
  • Geocaching (6)
  • Auto (2)
  • Adventure (1)
  • Boating (1)
  • Door stop (1)
Where to Buy
$109.99
$116.99
$119.00
Show all 16 stores
Product Reviews
Last update: Oct 20, 2009
Garmin Nuvi 205 GPS Navigation System Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[22 of 28 customers found this review helpful]
5.0
good entry level car gps
"i use the nuvi 205 everyday in my delivery van. i find it easy to use even while driving. it has all the features that a casual user would need at a great price. i dont agree with the last reviewer, my gps always recalculates new routes quickly and it does not try to make you go back to the original route. (maybe a difference between the 205 and the 205W ??) anyway a great first gps for anyone..." Read Full Review »
May 11, 2009 by scoots in hawaii
See more positive Garmin Nuvi 205 GPS Navigation System reviews
1.0
Garmin Nuvi 205W
"This is one of those "BAD" models. I've owned many Garmin products over many years and was a sales rep with REI, but in my opinion this model has a horrible software problem. In short, the 205 will NOT recalculate a new route if you stray from the original route programed by the GPS. It will ONLY want to return you to the original route! And the very annoying message "recalculating" is repeated over and over unt..." Read Full Review »
Nov 24, 2008 by Jerry
See more negative Garmin Nuvi 205 GPS Navigation System reviews
Displaying 1 - 5 of 186 Reviews
Show
Sort by
5.0
    Pros
  • Acquires Satellites Quickly
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"i use the nuvi 205 everyday in my delivery van. i find it easy to use even while driving. it has all the features that a casual user would need at a great price. i dont agree with the last reviewer, my gps always recalculates new routes quickly and it does not try to make you go back to the origi …"  Read Full Review »
gps in use
gps in use
Was this Car GPS review on the Garmin helpful to you?
 Report Abuse  (2)  (0)  0 comments
May 11 2009
scoots in hawaii
kailua, hi
I am:
  • Power User
Garmin Nuvi 205W
1.0
    Pros
  • Easy Menus
  • Easy To Read
    Cons
  • NO auto Reroutes
    Best Uses
  • Door stop
"This is one of those "BAD" models. I've owned many Garmin products over many years and was a sales rep with REI, but in my opinion this model has a horrible software problem. In short, the 205 will NOT recalculate a new route if you stray from the original route programed by the GPS. It will ONLY wa …"  Read Full Review »
 Report Abuse  (22)  (6)  0 comments
Nov 24 2008
Jerry
Fountain Valley, Ca.
I am:
  • Power User
Near Perfect For Beginning GPS User.
4.0
    Pros
  • Affordable
  • Compact
  • Easy Menus
  • Easy To Read
  • More »
    Cons
  • No Compass Rose
  • No Paperless Caching
  • Short Battery Life
    Best Uses
  • Faster Routes
  • Finding Specific Address
  • Geocaching
  • Learning To Use A GPS
  • Rural Navigation
  • More »
"The 205 family is a VERY good choice for the beginning GPS user. But that doesn't mean that it's ONLY for beginners. While this GPS doesn't have all the bells & whistles of the more sophisticated units, it's also 1/3 the price of most of them. But with the right 3rd-party applications & a bit of exp …"  Read Full Review »
Oct 11 2009
AstroDav
Yell County, Arkansas
I am:
  • Power User
Reviewed at:
Price: $129.88
[5 of 5 customers found this review helpful]
Far exceeded my expectations
4.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Planning Trips
  • Rural Navigation
  • Urban Navigation
"I just wanted something very basic for finding my way to new places or for getting around other towns. This is the entry level Nuvi, but I was very pleased to discover that it does nearly everything the more expensive models do. Plus with the software updates available from the Garmin website it doe …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
May 11 2009
Manniac
Seattle
I am:
  • Power User
[9 of 9 customers found this review helpful]
This nuvi 205 is awesome!
5.0
    Pros
  • Compact
  • Easy Menus
  • Easy To Read
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Faster Routes
"I bought this gamin nuvi 205 after careful review of consumer report... rates high. It was a b-day gift for my husb. He loved it, so do I . It's so easy to use. I always had a hard time finding destinations but not anymore! This is so awesome.
plug in the address and go. If putting in a house addre …"  Read Full Review »
 Report Abuse  (9)  (0)  0 comments
Aug 15 2008
Char
Delta,Ohio
I am:
  • Bad With Directions
  • Frequent Traveler
  • Technically Challenged
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$109.99
$116.99
$119.00
$119.97
$119.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
BizRate Rating Outstanding 9.4
$124.00
5% off orders at Abt.com
$129.88
$129.99
$129.99
20% Off Any Single Item at Modell's!
BizRate Rating Outstanding 9.2
$134.99
$139.73
Shop CameraWorld with FREE Shipping/No Sales Tax!
$139.73
Shop WolfCamera with FREE Shipping & No Sales Tax!
$139.73
$139.73
Shop RitzCamera with FREE Shipping & No Sales Tax!
$142.99
$142.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
