Garmin nuvi 1350T Portable GPS Unit
#179
3.3
based on 1 review
from $214.00 - $269.99
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
1
Category Average
4.1
More Images
Pros
  • Compact (2)
  • Easy menus (2)
  • Easy to read (2)
  • Large clear lcd (2)
  • Acquires satellites quickly (1)
  • Reliable (1)
See less See more
Cons
  • Acquires satellites slowly (1)
  • Early failure (1)
  • Poor battery life (1)
Best Uses
  • Faster routes (1)
  • Finding specific address (1)
Provided by WolfCamera.com
The widescreen nuvi 1350T adds free traffic alerts to the nüvi 1350. In addition, this ultra-thin GPS has preloaded maps for North America or Europe, announces streets by name, guides you to the proper lane for navigation, offers pedestrian navigation options and calculates a more fuel-efficient route with ecoRoute.
Navigate City Transit
With its enhanced pedestrian navigation capabilities, nuvi 1350T is the perfect travel companion for getting around town. Download optional cityXplorer content to help you navigate city public transit. Know where to walk, where to catch the bus, subway, tram or other transportation and how long it will take to get there. cityXplorer maps are available for select cities throughout North America and Europe. And with prices as low as $9.99, you'll have money left over to spend in the big city.
Take It With You
Twenty-five percent slimmer than other nuvis, you can take the ultra-thin 1350T anywhere. It easily fits in your pocket or purse, and its rechargeable lithium-ion battery makes it convenient for navigation by car or foot.
Know the Lane Before It’s Too Late
No more guessing which lane you need to be in to make an upcoming turn. Lane assist guides you to the correct lane for an approaching turn or exit, making unfamiliar intersections and exits easy to navigate.
See More
With nuvi 1350T's widescreen display, you'll always get the big picture. View map detail, driving directions, photos and more in bright, brilliant color. Its sunlight-readable, 4.3-inch display is easy to read - from any direction.
Get Turn-by-Turn Directions
nuvi 1350T's intuitive interface greets you with two simple questions: "Where To?" and "View Map." Touch the color screen to easily look up addresses and services and get voice-prompted, turn-by-turn directions that speak street names to your destination. It comes preloaded with detailed City Navigator NT street maps, nearly 6 million points of interest (POIs), 2-D or 3-D maps and the speed limit for most major roads. Its digital elevation maps show you shaded contours at higher zoom levels, giving you a big picture of the surrounding terrain. With the 1350T's enhanced user interface, you can slide your finger to conveniently scroll between screens. You can also upload custom points of interest (POIs). And with HotFix satellite prediction, nüvi calculates your position faster to get you there quicker.
Receive Free Traffic Alerts
Steer clear of traffic with nuvi 1350T's integrated FM traffic receiver and free lifetime¹ traffic updates. Receive alerts about traffic delays and road construction that lie ahead on your route. Next, simply touch nüvi's screen to view traffic details or detour around the problem area.
Go Beyond Navigation
Navigation is just the beginning. nuvi 1350T saves you gas and money with ecoRoute - a green feature that calculates the most fuel-efficient route, tracks fuel usage and more. The 1350T includes many travel tools including JPEG picture viewer, world travel clock with time zones, currency converter, measurement converter, calculator and more. With photo navigation, you can download pictures from Garmin Connect Photos and navigate to them. It's also compatible with MSN Direct (receiver purchase and subscription required). With its "Where Am I?" emergency locator, you always know your location. Simply tap the screen to get your exact latitude and longitude coordinates, the nearest address and intersection, and the closest hospitals, police stations and fuel stations. The 1350T features Garmin Lock, an anti-theft feature, and is compatible with our free Garmin Garage where you can download custom custom voices and vehicles. Enhance your travel experience with optional plug-in microSD cards.
Specification Description
Model 010-00782-26, 0100078226, NUVI 1350T
UPC 753759095352
Antenna Internal
Anti-theft device Yes
Auto routing/rerouting Yes
Backlight Yes
Battery Average Run Time 4
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits WQVGA 4.3-inch color touchscreen displays maps and more in bright detailLane assist guides you to the correct lane for an approaching
Cables Included Vehicle power cable, USB cable
Capacity UOM mAh
Chemistry Lithium Ion
Color support Yes
Connections Power (1)
Country Of Origin Taiwan
Description Header Always know the way.
Display Catalog Number 55032607
Display size (diagonal) 4.3 inches
End Product Indicator Yes
Expandable Memory microSD
Features Features nearly 6 million points of interest and 1,000 waypoints"Where Am I?" emergency locator helps you find your exact location
GPS type Car
Included in the Box Nuvi 1350TCity Navigator NTLifetime trafficFM traffic receiver with vehicle power cableVehicle suction cup
Manufacturer Labor Warranty 12
Manufacturer Part Number 010-00782-26
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps City Navigator
Menu navigation Touchscreen
Model NUVI 1350T
MSN Direct capability Yes
Number of waypoints 1000
Operating Temperature UOM ° F
Photo viewer Yes
Points of interest 6 million
Power Device Battery, vehicle power cable
Product Depth 0.6
Product Dimensions UOM inches
Product Disclaimer *Lifetime traffic extends for the useful life of your Garmin traffic receiver (as long as you own a compatible Garmin GPS) or as long as Garmin receiv
Product Height 2.9
Product Type Car
Product Weight 5.7
Product Weight UOM ounces
Product Width 4.8
Rechargeable Yes
Resolution 480X272
Routing options Faster time, shorter distance, off road, off-route, detour recalculation, avoid highways, tolls
Size Specialty
Spoken street names Yes
Supported Languages English
Touchscreen Yes
Traffic/Weather Yes
Type WQVGA TFT
Updatable Maps Yes
Uploadable Maps microSD
Voice Guidance Yes
Waypoints Yes
Garmin nuvi 1350T Portable GPS Unit Questions
Questions and Answers
Where to Buy
$269.95
Sign up for GearMail to save 15% on REI or Novara
BizRate Rating Outstanding 9.1
$214.00
$216.87
Show all 15 stores
_
Product Reviews
Last update: Oct 27, 2009
Garmin nuvi 1350T Portable GPS Unit Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Do Not Buy!
1.0
"I have purchased 1 unit. The unit would not find the traffic module via the including power cord. Abes sent out a 2nd model. The traffic worked until I attempted to update the garmin online. The update bricked the 2nd Garmin. The power will not turn on.
The update process is causing numerou …"  Read Full Review »
Was this Car GPS review on the Garmin nuvi 1350T Portable GPS Unit helpful to you?
Nov 18 2009
netdoctor
FL
I am:
  • Power User
Reviewed at:
Price: $239.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
$269.95
$214.00
$216.87
$219.99
$1.99 Shipping On Orders Over $100 at TigerDirect
$236.99
$236.99
$239.99
$239.99
$241.47
$244.47
BizRate Rating Outstanding 9.2
$247.00
BizRate Rating Outstanding 9.4
$249.99
$269.99
$269.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$269.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
