Garmin Leather Carry Case for nuvi 660
#7
4.3
based on 20 reviews
Ratings Distribution
5 star
45
4 star
15
3 star
6
2 star
4
1 star
2
Category Average
4.1
$11.00 - $17.99
from 16 stores
More Images
Pros
  • Well made (54)
  • Easy to use (52)
  • Works well with gps (46)
  • Improves functionality (13)
  • Compact (1)
  • Convenient (1)
  • Fits in center console (1)
  • Fits like a glove (1)
  • Good protection (1)
  • Gps cannot fall out (1)
See less See more
Cons
  • Hinders functionality (6)
  • Difficult to use (1)
  • Does not hold accessories (1)
  • Flimsy (1)
  • I don't have any cons (1)
  • Needs room for stand clip (1)
  • Nothing about it (1)
  • Poor quality (1)
  • Sometimes turns unit on (1)
  • The price is high (1)
Best Uses
  • Travel (39)
  • Auto (38)
  • Adventure (5)
  • Boating (2)
  • Appointment based travel (1)
  • Fits in purse (1)
  • Protective case for gps (1)
Provided by Staples
Durable case protects your GPS and keeps all accessories together Fits 4.3" Garmin units Travel with your nuvi using this carrying case.
For use with:
nuvi Seriesnuvi 200W, nuvi 205W, nuvi 250W, nuvi 255W, nuvi 260W, nuvi 610, nuvi 650, nuvi 660, nuvi 670, nuvi 680, nuvi 710, nuvi 750, nuvi 760, nuvi 770, nuvi 780, nuvi 850, nuvi 880
Specification Description
Model 010-10823-0, 010-10823-01, 0101082301, GRM1082301
UPC 753759061678
color null
Product Type Portable Navigator Case
Select Accessory Carry & Storage
size null
sku 109339
skuprice 19.9900
style GRM1082301
taxable Y
Garmin Leather Carry Case for nuvi 660 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 2, 2009
Garmin Leather Carry Case for nuvi 660 Reviews
Most helpful positive review
Most helpful negative review
[2 of 4 customers found this review helpful]
5.0
Great protection for my Garmin nuvi 775T
"Nice tight fit around my Garmin nuvi 775T so it doesn't slip out accidentally and get scratched while inside my travel go-bag. I haven't figured out what the rather deep sleeve on the side does yet (it's too big and deep for one SD card but while more than one SD card would fit, extracting one without pouring them all out would be difficult). I did discover a trick to using it effectively with my 775T: Slide the..." Read Full Review »
Jun 21, 2009 by Tanster
See more positive Garmin Leather Carry Case for nuvi 660 reviews
2.0
Disappointed
"Garmin had a novel idea in making a protective carrier for the wide screen nuvi series GPS units. The black leather surrounding this holder is pretty good, however the front and back section(s) seem to be leather wrapped cardboard. The sides are pliable...the entire half inch or so, but after placing my nuvi 760 within the pocket, I found that with a slight tilt, the GPS unit will fall to the ground. In looking ..." Read Full Review »
Nov 10, 2007 by StillinSaigon
See more negative Garmin Leather Carry Case for nuvi 660 reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Use
  • Well Made
  • Works Well With GPS
    Cons
  • None
    Best Uses
  • Auto
"Nice tight fit around my Garmin nuvi 775T so it doesn't slip out accidentally and get scratched while inside my travel go-bag. I haven't figured out what the rather deep sleeve on the side does yet (it's too big and deep for one SD card but while more than one SD card would fit, extracting one witho …"  Read Full Review »
Was this GPS Accessory review on the Garmin Leather Carry Case for nuvi 660 helpful to you?
Jun 21 2009
Tanster
New York, NY
I am:
  • Casual User
[2 of 2 customers found this review helpful]
Great Case
5.0
"Not sure why the other person had a problem with his Nuvi 760 falling out. I have just the opposite problem with my Nuvi 650.
The unit fits nice and snug inside the case and doesn't slip or slide in the least bit. In fact, I have to be sure that I insert it so that I don't press the power button whe …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 28 2008
VinInCT
CT
Disappointed
2.0
"Garmin had a novel idea in making a protective carrier for the wide screen nuvi series GPS units. The black leather surrounding this holder is pretty good, however the front and back section(s) seem to be leather wrapped cardboard. The sides are pliable...the entire half inch or so, but after placin …"  Read Full Review »
 Report Abuse  (2)  (2)  0 comments
Nov 10 2007
StillinSaigon
Richmond, VA
good, inexpensive case
4.0
    Pros
  • Easy To Use
  • Well Made
    Cons
  • None
    Best Uses
  • Auto
  • Travel
"simple, well-made case that protects entire GPS unit and especially the screen from scratches. Also protects from heat while storing in car on a hot day and from peeping eyes that might want to steal your GPS unit "
Apr 30 2009
Dr. AKB
Newark, dE
I am:
  • Casual User
Reviewed at:
Price: $17.00
OK, but falls a bit short
3.0
    Pros
  • Easy To Use
    Cons
  • Won't hold GPS with Clip
    Best Uses
  • Travel
"Good protection for GPS when storing it. Downside is that it holds only the GPS and not the clip that attaches to the GPS which must be removed each time for storage in the case.
I would probably buy it again. "
Feb 16 2009
The Transplanter
Chicago
I am:
  • Casual User
Reviewed at:
Price: $17.00
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
