Garmin Handle Bar Mount (Model #0101026700)
#334
3.5
based on 13 reviews
from $10.76 - $17.98
Ratings Distribution
5 star
7
4 star
1
3 star
2
2 star
0
1 star
4
Category Average
4.1
More Images
Pros
  • Easy to use (4)
  • Improves functionality (4)
  • Well built / quality construction (3)
  • Works well with gps (3)
  • Easy setup (2)
  • Reliable (2)
  • Well made (2)
  • Compact (1)
  • Easy to install (1)
  • Fits only older hcx model (1)
See less See more
Cons
  • Flimsy (1)
  • Just ok (1)
  • No interface wnew hcx (1)
  • Poor quality (1)
Best Uses
  • Adventure (5)
  • Cycling (3)
  • Biking (2)
  • Mountain biking (2)
  • Auto (1)
  • Boating (1)
  • Golf cart (1)
  • Hiking (1)
  • Recumbents (1)
  • Travel (1)
Provided by Staples
Snap your GPS unit into this secure handlebar mount and it's ready to ride Mount fits up to a one-inch diameter bar and is perfect for your bike, motorcycle or ATV Includes hardware and instructions See below for compatibility
For use with:
eTrex SerieseTrex, eTrex Camo, eTrex H, eTrex Legend, eTrex Legend C, eTrex Legend Cx, eTrex Summit, eTrex Venture, eTrex Venture Cx, eTrex Vista, eTrex Vista C, eTrex Vista Cx
Specification Description
Model 010-10267-00, 0101026700
UPC 753759025168
Accessory Indicator Yes
Benefits Mount your GPS eTrex model on your bicycle, motorcycle or ATVFits up to 1-inch diameter handlebarsColor: black
Body Material Multi
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Snap to it.
Display Catalog Number 55000074
Included in the Box GPS receiver bicycle mount bracketHardwareInstructions
Manufacturer Part Number 010-10267-00
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 010-10267-00
Operating Temperature UOM ° F
Product Type Mounts
Recommended Use Bicycle, Motorcycle, ATV mount for Garmin eTrex
Required to function Garmin eTrex GPS systemOne-inch diameter bar - bike, motorcycle or ATV.
Supported Languages English
Garmin Handle Bar Mount (Model #0101026700) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 8, 2009
Garmin Handle Bar Mount (Model #0101026700) Reviews
Most helpful positive review
Most helpful negative review
[14 of 15 customers found this review helpful]
5.0
simply perfect
"I have been using it for past three years with no problems, including some crashes too.I do keep lanyard wrapped around handlebars just in case, but it never came loose. As someone mentioned earlier not all batteries are same length so watch out for those shorter ones. And yes the battery door it comes with will not fit all models. It did not fit my legend cx (because of card slot next to batteries)..." Read Full Review »
Apr 19, 2009 by magic71
See more positive Garmin Handle Bar Mount (Model #0101026700) reviews
3.0
does not work with eTrex Vista HCx
"The Garmin eTrex bicycle mount does not work with the Garmin eTrex Vista HCx (and other newer eTrex GPS). You need to buy the Garmin "rail mount adapter kit" instead (around $11). The rail mount kit comes in either small or large sizes. The large size fits road bikes with fatter handlebars...." Read Full Review »
May 10, 2008 by johnny99
See more negative Garmin Handle Bar Mount (Model #0101026700) reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
3.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Bicycling
"The Garmin eTrex bicycle mount does not work with the Garmin eTrex Vista HCx (and other newer eTrex GPS). You need to buy the Garmin "rail mount adapter kit" instead (around $11). The rail mount kit comes in either small or large sizes. The large size fits road bikes with fatter handlebars. "
Was this GPS Accessory review on the Garmin Handle Bar Mount (Model #0101026700) helpful to you?
 Report Abuse  (14)  (1)  0 comments
May 10 2008
johnny99
San Frsncisco, CA
I am:
  • Technically Savvy
Note this is for "older" models
1.0
    Pros
  • Easy To Use
  • Improves Functionality
  • Works Well With GPS
    Cons
  • None
    Best Uses
  • Adventure
  • Biking
  • Boating
"The product is fine; the 1-star is just so people double check if this is what they need. If you have a current etrex model (which comes with a screw-in clip), you want the "Rail mount adapter" only (i.e. you don't need the battery cover that comes with this unit, and in fact it won't work if you ha …"  Read Full Review »
Oct 22 2009
bikehikeski
Redwood City, CA
I am:
  • Enthusiast
Great on bicycles
5.0
    Pros
  • Easy To Use
  • Well Made
    Cons
  • None
    Best Uses
  • Adventure
  • Bicycling
  • Recumbents
"This works great on all of my bicycles and recumbents. I use the GPS as my bike computer on nearly every ride. "
Nov 8 2009
Sig in Arkansas
I am:
  • Power User
[2 of 2 customers found this review helpful]
NO Fit for new HCx models
1.0
    Pros
  • Fits only older HCx model
    Cons
  • No Interface wNew HCx
    Best Uses
  • None
"I could not use the product because it didn't fit my new eTrex HCx. I am returning the product. New HCx owners must get the bicycle mount from Garmin, [$]. The bicycle mount from Garmin fits the small plastic clip that came with the new HCx. Attach the clip to the back of the HCx case and you are go …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
May 3 2009
active 60
South Bend, IN
I am:
  • Enthusiast
Risky to use
1.0
    Pros
  • None
    Cons
  • Low Quality
    Best Uses
  • Auto
"This handlebar mount is risky to use. I owned a Etrex Vista CX which fell off my bike as I was riding across a bridge and into a river. I then bought another eTrex. I now use the lanyard to attach the unit to the bike in addition to the mount. A few months a ago I discovered that the clip, which …"  Read Full Review »
Sep 4 2009
MikeC
Waltham, MA
I am:
  • Power User
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
