Garmin GPSMAP 276C Portable Navigator
#25
4.4
based on 7 reviews
Ratings Distribution
5 star
3
4 star
4
3 star
0
2 star
0
1 star
0
Category Average
4.2
$499.99 at Kmart
Find it at Amazon
Find it at Ebay
$499.99
from 1 store
More Images
Pros
  • Easy to use (3)
  • Quick signal (3)
  • Simple / intuitive controls (3)
  • Easy to read (2)
  • Reliable reception (2)
  • Durable (1)
  • Good value (1)
  • Reliable (1)
See less See more
Cons
  • Loses signal (1)
  • Poor viewing in sunlight (1)
Best Uses
  • At night (2)
  • Bad weather (1)
  • Lakes (1)
  • Large boats (1)
  • Ocean (1)
  • Small boats (1)
Provided by OutdoorPros.com
Garmin 010-00331-00 GPSMAP 276C Garmin International Inc. is a subsidiary of Garmin Ltd. the global leader in satellite navigation. Since 1989, the Garmin group of companies has designed, manufactured, marketed and sold navigation, communication and information devices and applications – most of which are enabled by GPS technology. Garmin’s products serve automotive, mobile, wireless, outdoor recreation, marine, aviation, and OEM applications. Garmin employees are in the air, on the water, in the woods, behind the wheel and on the run. And they’re always thinking of ways to adapt and improve. At Garmin, you never know how the next great idea will be born. But you know it’s coming soon. The GPSMAP 276C is a versatile color chartplotter and automobile navigator, perfect for land or water. Along with its counterpart, the GPSMAP 376C, this portable navigator features a sunlight-readable 256-color TFT display and a built-in autorouting basemap that can route you on major interstates and highways.Head for the WaterOn water, the GPSMAP 276C is a dependable color chartplotter with built-in basemap enhanced by Garmin's marine cartography. For extra-precise navigation, the 276C has a Course Deviation Indicator (CDI) — a feature normally found on aircraft, but equally practical for the marine environment. The CDI quickly indicates whether your boat has veered off-course and helps you get back on track quickly. The 276C also supports external NMEA sources for water depth, water temperature, and water speed through two serial interfaces.Navigate on LandOn land, the GPSMAP 276C’s autoroute basemap can route you on interstates and major highways. For even more detail, get the optional automotive kit (sold separately), which includes City Navigator® detailed maps, a data card and an automotive mount. With this kit, just load the detailed street maps on your 276C and pop it into the automotive mount for voice-prompted turn-by-turn directions to over six million addresses and points of interest, including restaurants, hotels, gas stations, marinas and other attractions.Add More Marine MapsThe 276C is compatible with BlueChart® maps, which add extra detail when you're out on the seas. It also accepts optional MapSource® data cards, so you can add other types of map data easily. For convenience and easy map transfer, you can connect the 276C to your computer with the included USB cable.GPSMAP 276C: The perfect navigator for water or land Garmin 010-00331-00 GPSMAP 276C Features: • Physical & Performance: • Unit dimensions, WxHxD: 5.7" x 3.2" x 1.9" (14.5 x 8.1 x 4.8 cm) • Display size, WxH: 3.0" x 2.2" (7.6 x 5.6 cm) • Display resolution, WxH: 480 x 320 pixels • Display type: 256-color TFT • Weight: 13.6 oz (385 g) • Battery: rechargeable internal lithium-ion • Battery life: up to 15 hours • Waterproof: yes (IPX7) • Antenna: detachable • NMEA input/output: NMEA 0183 • RoHS version available: yes • Maps & Memory: • Basemap: yes • Preloaded maps: no • Ability to add maps: yes • Built-in memory: none (cannot load maps to internal memory) • Accepts data cards: Garmin data cards • Waypoints/favorites/locations: 3,000 • Routes: 50 • Track log: 10,000 points; 20 saved tracks • Features: • Garmin radar compatible: no • Garmin sonar compatible: yes • CANet® compatible: no • Garmin Marine Network™ compatible: no • Touchscreen: no • Supports AIS (tracks target ships' position): no • Supports DSC (displays position data from DSC capable VHF radio): yes • Audible alarms: yes • Tide tables: yes • Hunt/fish calendar: yes • Sun and moon information: yes • 3-D map view: no • Auto Guidance: no • Automatic routing (turn by turn routing on roads): yes • XM WX Weather & Radio for U.S. compatible: no • Voice prompts (e.g. "Turn right in 500 ft."): no • Remote control: no • Headphone jack/audio line-out: yes • Audio/video input/output: no • Portable: yes • Automotive/motorcycle-friendly: yes • GPSMAP 276C • One basemap below • Americas: Americas Autoroute • Europe: Atlantic Autoroute • Pacific: Pacific Autoroute • • USB cable • Power/data cable • Marine mount • AC charger • Trip & Waypoint Manager • Owner's manual • Quick reference guide
Specification Description
Model 010-00331-00, 0100033100, 753759044138, GRM0033100
UPC 753759044138
Accuracy WAAS enabled: less than 9 feet; GPS only: less than 15 feet
Acquisition time, cold 45.0
Acquisition time, cold UOM seconds
Acquisition time, warm 15.0
Acquisition time, warm UOM seconds
Alarms Marine: Course Deviation Indicator, Next Turn, Distance, Arrival, Anchor Drag, Shallow/Deep Water
Antenna Removable quad-helix
Auto routing/rerouting Yes
Backlight Yes
Battery Average Run Time 15
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits Stores up to 3,000 user waypoints, 50 reversible routes (300 waypoints per route)10,000 point automatic track log; 15 saved tracks
Body Material Plastic
Cables Included USB-PC interface cable, Power/data cable
Capacity UOM mAh
Chemistry Lithium Ion
Color support Yes
Country Of Origin Taiwan
Datums Yes
Description Header Navigate the roadways and waterways.
Display Catalog Number 55000034
Display size (diagonal) 3.5 inches
Enclosure Color Black
End Product Indicator Yes
Equivalent to 010-10517-00
Expandable Memory SD card
External antenna connection Yes
Features Provides separate serial and USB interfaces2 NMEA serial portsOffers BlueChart night mode for easier viewing at nighttime
GPS type 12-parallel-channel
Grids Yes
Hunting/Fishing/Tides tables Yes
Included in the Box GPSMAP 276CAmericas Autoroute basemapUSB-PC interface cablePower/data cableMarine mountRechargeab
Inputs 1 x (Power), 1 x (USB)
Manufacturer Labor Warranty 12
Manufacturer Part Number 010-00331-00
Manufacturer Parts Warranty 12
MAP Price 699.99
Maps Americas Autoroute
Max Operating Temperature 140 Fahrenheit
Min Operating Temperature 5 Fahrenheit
Model GPSMAP 276C
Mounting options Marine, car, motorcycle
Number of waypoints 3000
Number of waypoints per route 300
Operating Temperature UOM ° F
Other features Garmin sonar compatible, displays position data from DSC capable VHF radio, sun and moon info, NMEA 0183, tide tables, headphone jack, can be used in
Outputs 1 x (Headset)
Power Device Rechargeable lithium-ion battery
Product Dimensions UOM inches
Product Disclaimer Accuracy subject to degradation to 100m 2DRMS under the U.S. Department of Defense imposed Selective Availability Program.
Product Height 3.2
Product Length 1.9
Product Type Marine
Product Weight 13.8
Product Weight UOM ounces
Product Width 5.7
Rechargeable Yes
Required to function chartplotter chart plotter
Resolution 480x320
Reversible tracklog Yes
Routes 50
Routing options Auto-reroute on land only, Man Overboard, Faster Time, Shorter Distance, Off Road, Avoid
Supported Languages English
Tracklogs 15
Type 256-color TFT
Updatable Maps Yes
WAAS, DGPS or USCG-enabled Yes
Water resistance IPX7
Waypoints Yes
Garmin GPSMAP 276C Portable Navigator Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 6, 2009
Garmin GPSMAP 276C Portable Navigator Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
EASY NAVIGATOR
4.0
    Pros
  • Easy To Read
  • Intuitive Menu
  • Quick Signal
  • Reliable Reception
    Cons
  • None
    Best Uses
  • At Night
  • Bad Weather
  • Lakes
  • Large Boats
  • Ocean
  • More »
"The Garmin 276 is very easy to read and makes boating much more enjoyable "
Was this Marine GPS review on the Garmin GPSMAP 276C Portable Navigator helpful to you?
 Report Abuse  (2)  (0)  0 comments
Oct 6 2009
dave
brick,new jersey
I am:
  • Power User
Reviewed at:
I recommend it all every drivers
4.0
    Pros
  • Easy To Read
  • Easy To Use
  • Intuitive Menu
  • Quick Signal
    Cons
  • Loses Signal
  • Poor Viewing In Sunlight
    Best Uses
  • At Night
"Good to have it in each car, it is simple, easy to use, and acurate "
Aug 8 2009
al
virginia, USA
I am:
  • Casual User
garmin is good
4.0
    Pros
  • Easy To Use
  • Intuitive Menu
  • Quick Signal
    Cons
  • None
    Best Uses
  • None
"Its a really great product and we've never had trouble with this brand "
Feb 13 2009
austen
medina, oh
I am:
  • Casual User
[1 of 1 customers found this review helpful]
Great for Auto and Boat ...
5.0
    Pros
  • Durable
  • Easy to use
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Great for Auto and Boat A+++ Had it for almost a year and it is Great!!!! "
 Report Abuse  (1)  (0)  0 comments
Dec 29 2005
Michael G
Long Island, New York
Great
4.0
"This item is great but you need to order the extra program from the company. The extra program gives small streets not just the main ones. Easy to use and operate. My husband loved it. "
Jan 9 2008
Momofboys
WV
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
