Garmin eTrex Vista HCx GPS
#5
3.9
based on 82 reviews
Ratings Distribution
5 star
28
4 star
25
3 star
5
2 star
6
1 star
5
Category Average
3.8
$224.00 - $234.99
from 16 stores
More Images
Pros
  • Compact (34)
  • Easy to read (28)
  • Reliable (27)
  • Well built / quality construction (27)
  • Good battery life (25)
  • Accurate (23)
  • Easy setup (23)
  • Simple controls (21)
  • Quick signal (19)
  • Reliable reception (19)
See less See more
Cons
  • Inaccurate (8)
  • Complicated controls (7)
  • Poor battery life (5)
  • Unreliable (5)
  • Buggy software (4)
  • Difficult to read (3)
  • Bulky (2)
  • Difficult to set up (2)
  • Expensive software (2)
  • Hard to read (2)
Best Uses
  • Hiking (55)
  • Adventure (27)
  • Travel (19)
  • Geocaching (18)
  • Boating (11)
  • Cycling (10)
  • In car (9)
  • Auto (4)
  • Backpacking (2)
  • Hunting (2)
Provided by nulime.com
Deep foliage, nor canyons faze the rugged eTrex Vista HCx. Its high-sensitivity receiver holds a GPS signal in the toughest environments. Similar to the Vista Cx, this handheld navigator also has a bright color screen, barometric altimeter, electronic compass, microSD card slot and automatic routing for wherever adventure takes you.
Enjoy Clear Reception: With its high-sensitivity, WAAS-enabled GPS receiver, eTrex Vista HCx locates your position quickly and precisely and maintains its GPS location even in heavy cover and deep canyons. The advantage is clear, whether you're in deep woods or just near tall buildings and trees, you can count on Vista HCx to help you find your way when you need it the most.
Get Your Bearings: The Vista HCx has a built-in electronic compass that provides bearing information even while you're standing still, and its barometric altimeter tracks changes in pressure to pinpoint your precise altitude. You can even use the altimeter to plot barometric pressure over time, which can help you keep an eye on changing weather conditions.
Expand Your Memory: Adding maps is easier than ever with Vista HCx's microSD card slot. Conveniently plug in optional preloaded microSD cards with MapSource data for your land and sea excursions. Just insert a MapSource card with detailed street maps, and Vista HCx provides turn-by-turn directions to your destination. The card slot is located inside the waterproof battery compartment, so you don't have to worry about getting it wet.
Take It Anywhere: Like the rest of the eTrex series, Vista HCx is lightweight and compact, the perfect size for all your travels.
Technical Information
Connectivity Technology: Not Applicable
Number of Channels: 12
Built-in Devices: CompassAltimeter
Platform Support: PC
Memory
Memory Card Support: microSD Card
Display & Graphics
Display Screen: 2.14" Active Matrix TFT Color LCD
Display Resolution: 176 x 220
Color Support: 256 Colors (8-bit)
Interfaces/Ports
Interfaces/Ports: 1 x USB
Software
Software Included:
  • MapSource Trip & Waypoint Manager
Basemap:
  • Americas: Americas Recreational
  • Europe: Atlantic Recreational
  • Pacific: Pacific Recreational
Battery Information
Battery Life: 25 Hour
Physical Characteristics
Dimensions: 2.2" Height x 4.2" Width x 1.2" Depth
Weight: 5.5 oz - with batteries
Miscellaneous
Package Contents:
  • eTrex Vista HCx Portable Navigator
  • USB Cable
  • Wrist Strap
  • Owner's Manual
  • Quick Reference Guide
Warranty
Standard Warranty: 1 Year Limited
Specification Description
Model 010-00439-00, 010-00630-0, 010-00630-00, 01000630-00
UPC 753759049188
Accuracy <15 feet
Alarms Proximity, Anchor Drag, Off Course
Antenna Internal patch
Anti-glare Yes
Auto routing/rerouting Yes
Backlight Yes
Battery Average Run Time 25
Battery Average Run Time UOM HOURS
Battery Type Product
Benefits The Americas Basemap v2 includes the United States, Canada, Mexico, Central & South America256-level color TFT anti-glare display mak
Brand ETREX
Cables Included USB
Capacity UOM mAh
Chemistry Alkaline
Color support Yes
Connectivity USB
Country Of Origin Taiwan
Datums Yes
Day/Night mode Yes
Description Header The eTrex dares to go where some receivers can't.
Display Catalog Number 55025467
Display size (diagonal) 2.0 inches
End Product Indicator Yes
Expandable Memory SD card
Features Built-in electronic compass that provides bearing information even while you're standing stillWaterproof, so it can withstand the ele
Hunting/Fishing/Tides tables Yes
Included in the Box eTrex Vista HCxAmericas Recreational Basemap v2MapSource Trip & Waypoint ManagerUSB cableWrist strap<
Inputs 1 x (Power/USB)
Manufacturer Labor Warranty 90
Manufacturer Part Number 010-00630-00
Manufacturer Parts Warranty 12
MAP Price 0.0
Maps Americas Recreational: United States, Canada, Mexico, Central and South America
Menu navigation Menu key, Rocker key
Model eTrex Vista HCx
Mounting options Wrist lanyard, bike mount
Number of waypoints 1000
Operating Temperature UOM ° F
Other features Electronic compass, barometric altimeter, geocaching mode, GPS games, sun/moon tables, area calculation, custom POIs, calendar, calculator, stopwatch,
Outputs 1 x (Power/USB)
Power Device 2 "AA" batteries
Product Dimensions UOM inches
Product Height 1.2
Product Length 4.2
Product Type Outdoor & fitness
Product Weight 5.5
Product Weight UOM ounces
Product Width 2.2
Required to function 2 "AA" batteries
Required to function SKU 2300885
Resolution 176x220 pixels
Routes 50
Size AA
Supported Languages English
Tracklogs 20
Trip computer Yes
Type TFT LCD
Updatable Maps Yes
WAAS, DGPS or USCG-enabled Yes
Water resistance IPX7
Garmin eTrex Vista HCx GPS Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Garmin eTrex Vista HCx GPS Reviews
Most helpful positive review
[22 of 26 customers found this review helpful]
Most helpful negative review
[13 of 19 customers found this review helpful]
4.0
HCx
"After using the Etrex Vista for years, with its dull grey screen, and downright lousy ability to hold on to satellites-in even the lightest of forest cover-I was waiting for a GPS that would acquire satellites quickly and hold on to them through dense forest and deep canyons (something my old Vista, simply would not do). When Garmin introduced Mapsource Topo USA 2008 for Mac, and the ability to "convert" Nationa..." Read Full Review »
Jul 04, 2008 by Seldom Seen
See more positive Garmin eTrex Vista HCx GPS reviews
2.0
Poor Map Transfer and Storage
"My wife and I received this product as a wedding present and I'm really glad we have it, but there are many times when it is really a pain and I wish REI sold a better one. First of all, the Mac support is horrible. It comes with a Windows only DVD and in order to convert it to Mac map format you need a Windows computer, and the fact that I don't have one is exactly why I need to convert it. I finally borrowe..." Read Full Review »
Jul 27, 2008 by Scott M
See more negative Garmin eTrex Vista HCx GPS reviews
Displaying 1 - 5 of 82 Reviews
Show
Sort by
Great product!
5.0
    Pros
  • Accurate
  • Large Screen
  • One Hand Control
  • Quick Navigation
  • Reliable Reception
    Cons
  • None
    Best Uses
  • Hiking
"I am a web designer during the week and hiker/photographer by week-end, so I bought the product for 2 purposes.
1). As a web designer I sometime have to seek out locations or landmarks(for example city parks) in cities are am unfamiliar with to photograph sites to use in websites for clients. Eve …"  Read Full Review »
Long Acre Park, Fairview Heights, Illinois
  • Using Product
Was this Handheld GPS review on the Garmin eTrex Vista HCx GPS helpful to you?
Oct 16 2008
mpolege
St.Louis, Missouri
I am:
  • Enthusiast
HCx
4.0
    Pros
  • Compact
  • Easy To Read
  • Easy To Set Up
    Cons
  • Dismal Documentation
  • No Mac Instructions
    Best Uses
  • Hiking
"After using the Etrex Vista for years, with its dull grey screen, and downright lousy ability to hold on to satellites-in even the lightest of forest cover-I was waiting for a GPS that would acquire satellites quickly and hold on to them through dense forest and deep canyons (something my old Vista, …"  Read Full Review »
 Report Abuse  (22)  (4)  0 comments
Jul 4 2008
Seldom Seen
Northern California
I am:
  • Bad With Directions
  • Gearhead
  • Outdoor Enthusiast
  • Technically Savvy
[12 of 12 customers found this review helpful]
Much Better But NOT Perfect
4.0
    Pros
  • Compact
  • Easy To Read
  • Easy To Set Up
  • Long Battery Life
  • Much Improved Reception
  • More »
    Cons
  • Inaccurate
  • Some Software Faults
    Best Uses
  • Adventure
  • Hiking
  • Travel
"This is my third Garmin GPS unit. Each has been a marked improvement over the previous model.
The HCx has the potential to be a truly great tool. The hardware works flawlessly. Reception sensitivity is very, very good. The new MediaTek chipset really makes a difference in where you can get a usab …"  Read Full Review »
 Report Abuse  (12)  (0)  0 comments
Sep 19 2007
spongebob
Portland, OR
I am:
2.0
    Pros
  • Compact
  • Strong Construction
    Cons
  • Inaccurate
  • Mac Support
  • Map Storage
    Best Uses
  • Hiking
"My wife and I received this product as a wedding present and I'm really glad we have it, but there are many times when it is really a pain and I wish REI sold a better one. First of all, the Mac support is horrible. It comes with a Windows only DVD and in order to convert it to Mac map format you …"  Read Full Review »
 Report Abuse  (13)  (6)  0 comments
Jul 27 2008
Scott M
Santa Cruz, CA
I am:
  • Technically Savvy
[12 of 16 customers found this review helpful]
A Big Disapointment
1.0
    Pros
  • Tracks Well
    Cons
  • Serious Performance Flaws
    Best Uses
  • None
"The unit acquires satellites well and tracks without dropouts. It has, however serious performance flaws that render it unusable for the serious backcountry traveler. The first indication that something was wrong was when I tried to operate the unit with lithium batteries. Yes, I did change the batt …"  Read Full Review »
 Report Abuse  (12)  (4)  0 comments
Feb 3 2008
DRC the Hiker
Hermosa Beach, CA
I am:
  • Technically Savvy
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
