G Technology 500GB G-Drive Q Quad Interface External Hard Drive
#100
4.4
based on 37 reviews
Ratings Distribution
5 star
28
4 star
4
3 star
0
2 star
2
1 star
3
Category Average
4.1
$159.95 at Adorama
Find it at Amazon
Find it at Ebay
$159.95
from 1 store
More Images
Pros
  • Easy setup (18)
  • Easy to use (17)
  • Quiet (14)
  • Fast (13)
  • Reliable (13)
  • Large capacity / good size (12)
  • Fast connectivity (8)
  • Durable (7)
  • Versatile (7)
  • Portable (6)
See less See more
Cons
  • Unreliable (3)
  • 6 month live span (1)
  • Can not hot swap (1)
  • Difficult to set up (1)
  • Freezes easily (1)
  • Kind of heavy for size (1)
  • Lack of power (1)
  • Poor power connection to (1)
  • Power brick is clunky (1)
Best Uses
  • Back-up (15)
  • Additional storage (11)
  • Video (8)
  • Music (5)
  • Photo storage (5)
  • File transfer (4)
  • Laptops (4)
  • Large projects (4)
  • Multimedia (4)
  • Travel (3)
Provided by Buzzillions.com
G-DRIVE Q Hard Drive
Specification Description
Model 913003-01, 91300301, GDQ 35/500, GDQ35500
UPC 185148000409
Buffer 16MB
Computer Compatibility PC and Macintosh
Connection External
Data Transfer Rate 300MBps Maximum External
Drive Capacity 500GB
Hard Drive Capacity 500 GB
Interface 4-pin USB 2.0 USB
Port Compatibility USB / Firewire / SATA
Rotational Speed 7200 rpm
Select Portable Drives
Select Interface Firewire,Serial / eSATA,USB
Select Platform Windows,Macintosh
Storage Capacity 500GB
Type of Drive Hard Drive
G Technology 500GB G-Drive Q Quad Interface External Hard Drive Questions
Questions and Answers
Where to Buy
$159.95
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Aug 25, 2009
G Technology 500GB G-Drive Q Quad Interface External Hard Drive Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Tried and true
"I am a photographer and I use G-Tech drives to archive my images. I own two of these G-Drive Q's in particular. Very reliable. Quiet. Quick. Easy to use...just plug it in and go! Firewire 800 is great and there's always the option of using them in a RAID system. Can't go wrong with this drive...." Read Full Review »
Jun 09, 2008 by dd photography
See more positive G Technology 500GB G-Drive Q Quad Interface External Hard Drive reviews
1.0
"I bought two of these drives, Im on a shooting Bangladesh and don't need the stress of failing drives... Well thats what I thought.. The unit was on a UPS all the time it was used. I get to 340gb of work and thats it.. Its DEAD.. the drive spins but will not mount in finder or Disc Utility. [...] SO I must not have one then.. [...] MAN am I one unhappy camper..I now have no choice but to buy from the local Ban..." Read Full Review »
Aug 01, 2008 by mckeeimaes
See more negative G Technology 500GB G-Drive Q Quad Interface External Hard Drive reviews
Displaying 1 - 5 of 37 Reviews
Show
Sort by
1.0
    Pros
  • Easy To Setup
    Cons
  • 6 month live span
  • Can Not Hot swap
  • Unreliable
    Best Uses
  • Door stop
  • Paper Weight
"I bought two of these drives, Im on a shooting Bangladesh and don't need the stress of failing drives... Well thats what I thought.. The unit was on a UPS all the time it was used. I get to 340gb of work and thats it.. Its DEAD.. the drive spins but will not mount in finder or Disc Utility. [...] S …"  Read Full Review »
Was this External Computer Hard Drive review on the G Technology 500GB G-Drive Q Quad Interface External Hard Drive helpful to you?
 Report Abuse  (2)  (0)  0 comments
Aug 1 2008
mckeeimaes
Dhaka,Bangladesh,
I am:
  • Power user
Tried and true
5.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Fast
    Cons
  • None
    Best Uses
  • Photo Archiving
  • Work directly off of
"I am a photographer and I use G-Tech drives to archive my images. I own two of these G-Drive Q's in particular. Very reliable. Quiet. Quick. Easy to use...just plug it in and go! Firewire 800 is great and there's always the option of using them in a RAID system. Can't go wrong with this drive. "
 Report Abuse  (4)  (0)  0 comments
Jun 9 2008
dd photography
Los Angeles, CA
I am:
  • Quality Oriented
Reviewed at:
[1 of 1 customers found this review helpful]
Excellent drive
5.0
    Pros
  • Easy To Setup
  • Easy to use
  • Fast
  • High Capacity
  • More durable thn portable
  • More »
    Cons
    Best Uses
  • Additional Storage
  • Backup
  • File Transfer
  • Music
  • Video
"I'm a professional multimedia artist and was directed to purchase this drive from a trusted editor friend. The drive is very fast, extremely quiet and quite affordable. I bought two 500 gigs. Then was at a fashion shoot and noticed that they did all of their digital capture as well as backup on s …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 8 2008
Fredo Viola
New York, NY
I am:
  • Power user
Reviewed at:
A work horse with style!
5.0
    Pros
  • Easy To Setup
  • Easy to use
  • High Capacity
  • Portable
  • Reliable
    Cons
  • None
    Best Uses
  • Backup
  • PC & Mac
  • Photo Storage
  • Video
"The G-Drive Qs are blazing fast: Use the FireWire 800 port and (if you're on a Mac) format it to be unjournaled and it will keep up with even the most demanding video work. Although it's a little chatty (lots of "chewing on data" sounds), it makes up for that minor annoyance both by its performance …"  Read Full Review »
Dec 30 2008
artschoolcasualty
Portland, OR
I am:
  • Power user
Reviewed at:
High quality device for audio
4.0
    Pros
  • Easy To Setup
  • Easy to use
  • Fast
  • High Capacity
  • Reliable
    Cons
  • None
    Best Uses
  • Music
"This drive is great for working with audio. It allows me to stream a lot of channels from my Motu Ultralite and my Motu 828 MKII at the same time. I tested it with the USB and the FW400 and FW800 interfaces, and all have great transfer rates and stability. It is a very quiet device, but not a comple …"  Read Full Review »
Jun 29 2008
Alan
Buenos Aires, Argentina
I am:
  • Power user
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
